Hi all,
I’m having trouble migrating a DolfinX v0.6.0 code to DolfinX v0.9.0 (nonlinear NS solver with Schur complement as preconditioning).
This MWE runs under fenics-dolfinx 0.6.0 with petsc4py/petsc 3.19.6 (the conda env has been created from conda create -n fenicsx060 python=3.10 fenics-dolfinx=0.6.0 -c conda-forge):
import os
import time
# FEniCS import
from dolfinx.io import gmshio
from dolfinx import fem, mesh
from ufl import derivative, FacetNormal, TestFunctions, sym, dot, nabla_div, nabla_grad, dx, inner, outer
def norm_L2(comm, v):
return np.sqrt(comm.allreduce(fem.assemble_scalar(fem.form(inner(v, v) * dx)), op=MPI.SUM))
def g_expr(x):
return np.vstack((1 - np.exp((Re / 2 - np.sqrt(Re**2 / 4 + 4 * np.pi**2)) * x[0]) * np.cos(2 * np.pi * x[1]),
(Re / 2 - np.sqrt(Re**2 / 4 + 4 * np.pi**2)) / (2 * np.pi) * np.exp((Re / 2 - np.sqrt(Re**2 / 4 + 4 * np.pi**2)) * x[0]) * np.sin(2 * np.pi * x[1])))
def dir_marker(x):
return (
np.isclose(x[0], 0.0)
| np.isclose(x[0], 1.0)
| np.isclose(x[1], 0.0)
| np.isclose(x[1], 1.0)
# VARIABLES
msh = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100)
pts = msh.geometry.x
npts = len(pts)
gdim = msh.geometry.dim
# CONSTANTES
Re = 50
dt = 1e-2
# FEM
return sym(nabla_grad(u))
# Function spaces for the velocity and for the pressure
Ve = ufl.VectorElement("Lagrange", msh.ufl_cell(), 2)
Qe = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
W = fem.FunctionSpace(msh, Ve*Qe)
V, V_map = W.sub(0).collapse()
Q, Q_map = W.sub(1).collapse()
size_V = V.dofmap.index_map.size_local * V.dofmap.index_map_bs
size_Q = Q.dofmap.index_map.size_local * Q.dofmap.index_map_bs
v, q = TestFunctions(W)
wnP1 = fem.Function(W)
wn = fem.Function(W)
bc = fem.Function(W)
unP1, p = ufl.split(wnP1)
un, _ = ufl.split(wn)
A = ( dot(unP1 - un, v) / dt * dx
- inner(outer(unP1, unP1), nabla_grad(v)) * dx
+ dot(q, nabla_div(unP1)) * dx
- dot(nabla_div(v), p) * dx
+ inner(epsilon(unP1), epsilon(v))/Re * dx
# Boundaries
u_D = fem.Function(W)
u_D.sub(0).interpolate(g_expr)
dir_points = mesh.locate_entities_boundary(msh, msh.topology.dim - 1, dir_marker)
dir_vel_dofs = fem.locate_dofs_topological(W, msh.topology.dim - 1, dir_points)
bc_u = fem.dirichletbc(u_D, dir_vel_dofs)
bc = [bc_u]
problem = NonlinearProblem(A, wnP1, bcs=bc)
ksp = solver.krylov_solver # Handle for PETSc interaction
ksp.setType("gmres")
pc = ksp.getPC() # Preconditioning object
pc.setType("fieldsplit") # Different preconditioning for different blocks
# Split fields for applying different preconditioners
u_dofs = V_map
p_dofs = Q_map
ISu = PETSc.IS().createGeneral(u_dofs, msh.comm)
ISp = PETSc.IS().createGeneral(p_dofs, msh.comm)
pc.setFieldSplitIS(("u",ISu))
pc.setFieldSplitIS(("p",ISp))
# Set preconditioner options
opts = PETSc.Options()
opts.clear()
print(f"Option prefix: {option_prefix}")
opts[f"{option_prefix}ksp_pc_side"] = "right" # Use right preconditioning: ( K M^-1 ) M x = b. This preserves the residual.
opts[f"{option_prefix}pc_fieldsplit_type"] = "schur" # Based on schur complement of K: possible since only two blocks
opts[f"{option_prefix}pc_fieldsplit_schur_fact_type"] = "upper" # Different flavors: diag, lower, upper or full
opts[f"{option_prefix}pc_fieldsplit_schur_preconditioning"] = "user" # Default preconditioner for one of the schur blocks.
opts[f"{option_prefix}fieldsplit_u_ksp_type"] = "preonly" # Precondition only once in Newton iterations
opts[f"{option_prefix}fieldsplit_u_pc_type"] = "jacobi" # Jacobi (diagonals) preconditioning for u-block
opts[f"{option_prefix}fieldsplit_p_ksp_type"] = "preonly" # Precondition only once in Newton iterations
opts[f"{option_prefix}fieldsplit_p_pc_type"] = "hypre" # Hypre (algebraic multigrid) preconditioning for p-block
opts[f"{option_prefix}fieldsplit_p_pc_hypre_type"] = "boomeramg" # Choice of implementation
opts[f"{option_prefix}fieldsplit_p_pc_hypre_boomeramg_coarsen_type"] = "pmis" # Grid coarsening strategy
opts[f"{option_prefix}fieldsplit_p_pc_hypre_boomeramg_interp_type"] = "FF1" # Projection on to coarser grid
opts[f"{option_prefix}fieldsplit_p_pc_hypre_boomeramg_strong_threshold"] = "0.5" # Coarsening limit
ksp.setFromOptions()
# print("Options PETSc définies :")
# for key, value in opts.getAll().items():
# print(f"{key} = {value}")
start = time.time()
solver.solve(wnP1)
end = time.time()
print(f"Elapsed time: {end - start:.4f} seconds for {npts} points")
and gives the expected output:
Option prefix: nls_solve_
Elapsed time: 1.8762 seconds for 10201 points
When I run this new MWE with fenics-dolfinx 0.9.0 and petsc 3.22.3 / petsc4py 3.22.4 (the conda env has been created using conda create -n fenicsx090 fenics-dolfinx -c conda-forge ):
import os
import time
# FEniCS import
from dolfinx import default_real_type, fem, mesh
def g_expr(x):
return np.vstack((1 - np.exp((Re.value / 2 - np.sqrt(Re.value**2 / 4 + 4 * np.pi**2)) * x[0]) * np.cos(2 * np.pi * x[1]),
(Re / 2 - np.sqrt(Re.value**2 / 4 + 4 * np.pi**2)) / (2 * np.pi) * np.exp((Re.value / 2 - np.sqrt(Re.value**2 / 4 + 4 * np.pi**2)) * x[0]) * np.sin(2 * np.pi * x[1])))
def dir_marker(x):
return (
# VARIABLES
npts = len(pts)
# CONSTANTES
Re = fem.Constant(msh, default_real_type(50))
dt = fem.Constant(msh, default_real_type(1e-2))
# FEM
V_el = element("Lagrange", msh.basix_cell(), 2, shape=(gdim,))
Q_el = element("Lagrange", msh.basix_cell(), 1)
W_el = mixed_element([V_el, Q_el])
W = fem.functionspace(msh, W_el)
# Boundaries
bc = [bc_u]
u_dofs = V_map
p_dofs = Q_map
opts.clear()
opts[f"{option_prefix}pc_fieldsplit_schur_precondition"] = "user" # Default preconditioner for one of the schur blocks.
start = time.time()
solver.solve(wnP1)
end = time.time()
The output specifies that the same options are unused:
Elapsed time: 5.0500 seconds for 10201 points
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 12 unused database options. They are:
Option left: name:-nls_solve_fieldsplit_p_ksp_type value: preonly source: code
Option left: name:-nls_solve_fieldsplit_p_pc_hypre_boomeramg_coarsen_type value: pmis source: code
Option left: name:-nls_solve_fieldsplit_p_pc_hypre_boomeramg_interp_type value: FF1 source: code
Option left: name:-nls_solve_fieldsplit_p_pc_hypre_boomeramg_strong_threshold value: 0.5 source: code
Option left: name:-nls_solve_fieldsplit_p_pc_hypre_type value: boomeramg source: code
Option left: name:-nls_solve_fieldsplit_p_pc_type value: hypre source: code
Option left: name:-nls_solve_fieldsplit_u_ksp_type value: preonly source: code
Option left: name:-nls_solve_fieldsplit_u_pc_type value: jacobi source: code
Option left: name:-nls_solve_ksp_pc_side value: right source: code
Option left: name:-nls_solve_pc_fieldsplit_schur_fact_type value: upper source: code
Option left: name:-nls_solve_pc_fieldsplit_schur_preconditioning value: user source: code
Option left: name:-nls_solve_pc_fieldsplit_type value: schur source: code
I believe this is related to the PETSc versions, but from what I’ve seen on their website, the prefix format hasn’t changed, so I’m giving it a try here.
The solution given in this topic:
works only on the first four options.
Thanks!
