I solve diffusion equation in my program:
\frac{\rho f}{dt} \, + \, \nabla \cdot (\rho f v) \, = \, \nabla \cdot (\rho D \nabla f)
I create my geometry in gmsh:
I must definition subdomain and initialize F=0 and F=1. I imported my geometry, use this code:
msh = meshio.read("tube.msh")
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
meshio.write("facet_mesh.xdmf", line_mesh)
mesh = Mesh()
infile.read(mesh)
And imported facet domains in this code:
dim = mesh.topology().dim()
mvc = MeshValueCollection("size_t", mesh, dim-1)
with XDMFFile("facet_mesh.xdmf") as infile:
facet_domains = cpp.mesh.MeshFunctionSizet(mesh, mvc)
My .geo file:
Point(1) = {0, 0, 0, 1.0};
Point(2) = {0, 0.000150, 0, 1.0};
Point(3) = {0, -0.000150, 0, 1.0};
Point(4) = {-0.000750, -0.000150, 0, 1.0};
Point(5) = {-0.00075, -0.000300, 0, 1.0};
Point(6) = {-0.00075, 0.000150, 0, 1.0};
Point(7) = {-0.00075, 0.000300, 0, 1.0};
Point(8) = {0.002, 0, 0, 1.0};
Point(9) = {0.002, 0.000150, 0, 1.0};
Point(10) = {0.002, -0.000150, 0, 1.0};//+
Line(1) = {5, 3};
Line(2) = {4, 1};
Line(3) = {6, 1};
Line(4) = {7, 2};
Line(5) = {7, 6};
Line(6) = {4, 5};
Line(7) = {3, 10};
Line(8) = {1, 8};
Line(9) = {2, 9};
Line(10) = {9, 8};
Line(11) = {8, 10};
Curve Loop(1) = {5, 3, -2, 6, 1, 7, -11, -10, -9, -4};
Plane Surface(1) = {1};
Physical Surface("sur", 12) = {1};
Physical Curve("A", 13) = {5};
Physical Curve("B", 14) = {6};
Physical Curve("outlet", 15) = {10, 11};
Physical Curve("wall", 16) = {4, 9, 7, 1, 2, 3};
Curve Loop(2) = {5, 3, 8, -10, -9, -4};
Plane Surface(2) = {2};
Curve Loop(3) = {6, 1, 7, -11, -8, -2};
Plane Surface(3) = {3};
Physical Surface("sur_a", 17) = {2};
Physical Surface("sur_b", 18) = {3};
I create those two surface in gmsh (sur_a, sur_b). How i can import subdomain?
My subdomain must interact each other.
I see other topic for my theme, but didn’t found answer.
