Hi, can someone tell me how can I install dolfinx_materials GitHub - bleyerj/dolfinx_materials
on Google Colab and run the examples?
I have tried with !pip install but it doesn’t work.
Thank you
Please show us what you tried to do (and, if it doesn’t work, what error you get), rather than expecting that someone magically comes up with the right command. See Read before posting: How do I get my question answered?
Overall, it may not be trivial, considering that mgis will be required (which, I think, is a C++ library). cc @bleyerj
try:
except ImportError:
!wget "https://fem-on-colab.github.io/releases/fenicsx-install-real.sh" -O "/tmp/fenicsx-install.sh" && bash "/tmp/fenicsx-install.sh"
I installed dolfinx and gmsh.
!apt-get install gmsh
!pip install gmsh
I copied and pasted an example, but I need dolfinx_materials.
from dolfinx import fem, mesh, io, la, log
from dolfinx.common import list_timings, TimingType
from dolfinx.cpp.nls.petsc import NewtonSolver
from dolfinx_materials.quadrature_map import QuadratureMap
from dolfinx_materials.material.mfront import MFrontMaterial
from dolfinx_materials.solvers import NonlinearMaterialProblem
from dolfinx_materials.utils import (
symmetric_tensor_to_vector,
nonsymmetric_tensor_to_vector,
Nx, order = 20, 1
domain = mesh.create_unit_cube(
MPI.COMM_WORLD,
Nx,
Nx,
Nx,
cell_type=mesh.CellType.hexahedron,
ghost_mode=mesh.GhostMode.none,
gdim = domain.topology.dim
V = fem.functionspace(domain, ("P", order, (3,)))
deg_quad = 2 * order
# print(V.dofmap.list[[0, 1]])
E = 1e9
material = MFrontMaterial(
"dolfinx_materials/mfront_materials/src/libBehaviour.so",
"Ogden",
N = 10
# Exx = np.linspace(0, 2e-2, N + 1)
Exx = np.concatenate(
(np.linspace(1e-6, 8e-2, N + 1), np.linspace(8e-2, 20e-2, N + 1)[1:])
centers = np.array(
[0.0, 0.0, 0.0],
[1.0, 0.0, 0.0],
[0.0, 1.0, 0.0],
[0.0, 0.0, 1.0],
[1.0, 1.0, 0.0],
[1.0, 0.0, 1.0],
[0.0, 1.0, 1.0],
[1.0, 1.0, 1.0],
radius = 0.4
def inclusion(x):
markers = []
for center in centers:
print(center)
markers.append(
(x[0] - center[0]) ** 2 + (x[1] - center[1]) ** 2 + (x[2] - center[2]) ** 2
<= radius**2
marker = np.any(np.vstack(markers), axis=0)
return marker
def bottom(x):
return np.isclose(x[1], 0)
def left(x):
return np.isclose(x[0], 0)
def right(x):
return np.isclose(x[0], 1.0)
def border(x):
return np.logical_and(
np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)), inclusion(x)
tdim = domain.topology.dim
fdim = tdim - 1
# dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
dofs = fem.locate_dofs_geometrical(V, border)
exx = fem.Constant(domain, 0.0)
Fmacro = ufl.as_matrix([[exx, 0, 0], [0, 0, 0], [0, 0, 0]])
u_expr = fem.Expression(ufl.dot(Fmacro, x), V.element.interpolation_points())
uD = fem.Function(V)
bcs = [fem.dirichletbc(uD, dofs)]
du = ufl.TrialFunction(V)
u = fem.Function(V, name="Displacement")
def build_nullspace(V):
"""Build PETSc nullspace for 3D elasticity"""
# Create vectors that will span the nullspace
bs = V.dofmap.index_map_bs
length0 = V.dofmap.index_map.size_local
length1 = length0 + V.dofmap.index_map.num_ghosts
basis = [np.zeros(bs * length1, dtype=PETSc.ScalarType) for i in range(6)]
# Get dof indices for each subspace (x, y and z dofs)
dofs = [V.sub(i).dofmap.list.array.flatten() for i in range(3)]
# Set the three translational rigid body modes
for i in range(3):
basis[i][dofs[i]] = 1.0
# Set the three rotational rigid body modes
dofs_block = V.dofmap.list.array.flatten()
x0, x1, x2 = x[dofs_block, 0], x[dofs_block, 1], x[dofs_block, 2]
basis[3][dofs[0]] = -x1
basis[3][dofs[1]] = x0
basis[4][dofs[0]] = x2
basis[4][dofs[2]] = -x0
basis[5][dofs[2]] = x1
basis[5][dofs[1]] = -x2
# Create PETSc Vec objects (excluding ghosts) and normalise
basis_petsc = [
PETSc.Vec().createWithArray(x[: bs * length0], bsize=3, comm=V.mesh.comm)
for x in basis
la.orthonormalize(basis_petsc)
assert la.is_orthonormal(basis_petsc)
# Create and return a PETSc nullspace
return PETSc.NullSpace().create(vectors=basis_petsc)
def strain(u):
return symmetric_tensor_to_vector(ufl.sym(ufl.grad(u)))
def F(u):
return nonsymmetric_tensor_to_vector(ufl.Identity(gdim) + ufl.grad(u))
def dF(u):
return nonsymmetric_tensor_to_vector(ufl.grad(u))
def matrix(x):
return np.logical_not(inclusion(x))
V0 = fem.functionspace(domain, ("DG", 0))
kappa = fem.Function(V0)
cells_incl = mesh.locate_entities(domain, gdim, inclusion)
cells_matrix = mesh.locate_entities(domain, gdim, matrix)
kappa.vector.array[:] = 0.0
kappa.x.array[cells_incl] = np.full_like(cells_incl, 1, dtype=ScalarType)
num_cells_local = domain.topology.index_map(gdim).size_local
marker = 2 * np.ones(num_cells_local, dtype=np.int32)
cells_0 = cells_incl[cells_incl < num_cells_local]
marker[cells_0] = 1
cell_tag = mesh.meshtags(domain, gdim, np.arange(num_cells_local), marker)
print(cell_tag.values)
cells_matrix = cell_tag.find(2)
qmap = QuadratureMap(domain, deg_quad, material, cells=cells_matrix)
qmap.register_gradient("DeformationGradient", F(u))
dx = qmap.dx(subdomain_data=cell_tag)
print(qmap.internal_state_variables)
sig = qmap.fluxes["FirstPiolaKirchhoffStress"]
Res = 1e-6 * (ufl.dot(sig, dF(v)) * dx(2) + E * ufl.dot(strain(u), strain(v)) * dx(1))
Jac = qmap.derivative(Res, u, du)
problem = NonlinearMaterialProblem(qmap, Res, Jac, u, bcs)
newton = NewtonSolver(MPI.COMM_WORLD)
newton.rtol = 1e-4
newton.convergence_criterion = "incremental"
newton.report = True
log.set_log_level(log.LogLevel.ERROR)
# Set solver options
ksp = newton.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}ksp_rtol"] = 1e-8
# Use Chebyshev smoothing for multigrid
opts["mg_levels_ksp_type"] = "chebyshev"
opts["mg_levels_pc_type"] = "jacobi"
# # Improve estimate of eigenvalues for Chebyshev smoothing
opts["mg_levels_esteig_ksp_type"] = "gmres"
opts["mg_levels_ksp_chebyshev_esteig_steps"] = 20
ksp.setFromOptions()
file_results = io.XDMFFile(
domain.comm,
f"{material.name}_results.xdmf",
"w",
file_results.write_mesh(domain)
file_results.write_function(kappa)
Sxx = np.zeros_like(Exx)
for i, exx_v in enumerate(Exx):
exx.value = exx_v
uD.interpolate(u_expr)
print(f"Increment {i}")
converged, it = problem.solve(newton)
# converged, it = snes.solve(snes_solver)
# assert snes_solver.getConvergedReason() > 0
Sxx[i] = sig.vector.array[0]
# p = qmap.project_on("EquivalentPlasticStrain", ("DG", 0))
# e = qmap.project_on("Strain", ("DG", 0))
file_results.write_function(u, i)
list_timings(domain.comm, [TimingType.wall, TimingType.user])
I tried with
!pip install dolfinx_materials
but it gives me an error:
ERROR: Could not find a version that satisfies the requirement dolfinx_materials (from versions: none)
ERROR: No matching distribution found for dolfinx_materials
I don’t think that dolfinx_materials is available on pypi, hence you’ll need to install it from its source on github, for instance
!pip install git+https://github.com/bleyerj/dolfinx_materials.git
For the reasons stated above, it may very well happen that the installed library won’t be usable.
Thank you.
You are right, now I have this error:
ModuleNotFoundError: No module named ‘mgis’
Do you know how to install ‘mgis’ on Colab?
I’ve done all I can, now you’ll need to wait for the author of the package to answer. My understanding is that mgis is at GitHub - thelfer/MFrontGenericInterfaceSupport: This project aims at providing support for MFront generic behaviours. This project can be embedded in open-source and propriary sofware, but having never used it I wouldn’t know how to install it, except for noticing that it uses cmake.
Ok, thank you very much for your precious help
Hello, yes you need to install mgis and tfel from source if you want to compile MFront behaviors. You can also find a docker image with everything installed here: Package mealor · GitHub
Thank you, Could you explain to me how to install them?
@bleyerj I found here another example of yours about Von Mises plasticity: Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation
I have tried to modified it considering a holed plate, but I’m not sure about the results.
Can I show them here or it is better to open a new discussion?
First, if you are using dolfinx, I suggest to look at the new tutorial:
https://bleyerj.github.io/comet-fenicsx/tours/nonlinear_problems/plasticity/plasticity.html
Then I think it is best to start a new discussion specific to your question and code
Ok, thanks so much for your help.
I’ll open a new discussion.
I considered dolfin’s example because I’m more familiar with it
