By the way, if you have a better install tutorial please let me know, I think I am not very good, but not that bad, I am so confused with the install tutorial from the Springer book.
Yes, dokken, I appreciate you, but this is the seciton 5, my question is that I cannot run the command in section 1, which is
curl -s https://get.fenicsproject.org | bash
Do all the other commands than the curl one. Aka open your browser to the page, and find the access token as described. You have already started the docker container.
Just follow the instructions after:
5.1. Docker for Mac, Docker for Windows and Linux users
First of all we run a new Docker container with the jupyter-notebook command specified and the default port 8888 exposed on localhost:
Please read the error message, a notebook named notebook has already been created, last time you ran the command. Please use docker container start -t notebook
