I am trying to install dolfinx from source inside the latest Docker dev-env image (fetched using docker pull dolfinx/dev-env:nightly).
Cloning and installing ufl, basix and ffcx works fine, but after subsequent cloning and trying to install dolfinx:
git clone https://github.com/FEniCS/dolfinx.git cd dolfinx/cpp && mkdir build && cd build cmake ..
I get
– SCOTCH could not be found. Be sure to set SCOTCH_ROOT. (missing: SCOTCH_LIBRARIES SCOTCH_INCLUDE_DIRS SCOTCH_TEST_RUNS) ** – ParMETIS could not be found/configured. (missing: PARMETIS_LIBRARIES PARMETIS_TEST_RUNS PARMETIS_INCLUDE_DIRS PARMETIS_VERSION PARMETIS_VERSION_OK) (Required is at least version “4.0.2”) CMake Error at CMakeLists.txt:359 (message):
** No graph partitioner found. SCOTCH, ParMETIS or KaHIP is required.
So, I understood that the dev-env Docker container already contains all PETSc and other related dependencies to install dolfinx. Do I see this wrong and would I need to install some of the other dependencies, too?
You need to set the PETSC_DIR and PETSC_ARCH as the dev-env does not set these (as it contains multiple installations of PETSc, real32, complex32 etc).
Thanks. This worked (setting PETSC_DIR=/usr/local/petsc and PETSC_ARCH=linux-gnu-real-64) and I could build according to the instructions.
Trying to run a demo/importing dolfinx in Python3 however yields
File "<stdin>", line 1, in <module>
File "/home/shared/work/codes/fenicsx/dolfinx/python/dolfinx/__init__.py", line 34, in <module>
from dolfinx.common import (TimingType, git_commit_hash, has_debug, has_kahip,
File "/home/shared/work/codes/fenicsx/dolfinx/python/dolfinx/common.py", line 11, in <module>
ImportError: cannot import name 'cpp' from partially initialized module 'dolfinx' (most likely due to a circular import) (/home/shared/work/codes/fenicsx/dolfinx/python/dolfinx/__init__.py)
I would need the output of the build-logs to be able to give any guidance on this, as this usually means that something failed during installation of the python bindings.
After calling cmake -DCMAKE_INSTALL_PREFIX=../build_install .. inside dolfinx/cpp/build, I get the following inside the CMakeError.log:
Determining if the PETSC_USE_COMPLEX exist failed with the following output:
Change Dir: /home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_6e70f/fast && /usr/bin/gmake -f CMakeFiles/cmTC_6e70f.dir/build.make CMakeFiles/cmTC_6e70f.dir/build
gmake[1]: Entering directory '/home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_6e70f.dir/CheckSymbolExists.c.o
/usr/bin/cc -I/usr/local/petsc/linux-gnu-real-64/include -I/usr/local/petsc/include -o CMakeFiles/cmTC_6e70f.dir/CheckSymbolExists.c.o -c /home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c
/home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c: In function 'main':
/home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:8:19: error: 'PETSC_USE_COMPLEX' undeclared (first use in this function); did you mean 'PETSC_HAVE_COMPLEX'?
8 | return ((int*)(&PETSC_USE_COMPLEX))[argc];
| PETSC_HAVE_COMPLEX
/home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:8:19: note: each undeclared identifier is reported only once for each function it appears in
gmake[1]: *** [CMakeFiles/cmTC_6e70f.dir/build.make:78: CMakeFiles/cmTC_6e70f.dir/CheckSymbolExists.c.o] Error 1
gmake[1]: Leaving directory '/home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp'
gmake: *** [Makefile:127: cmTC_6e70f/fast] Error 2
File /home/shared/work/codes/fenicsx/dolfinx/cpp/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <petscsystypes.h>
int main(int argc, char** argv)
(void)argv;
#ifndef PETSC_USE_COMPLEX
#else
(void)argc;
return 0;
#endif
Sure. So here is what I’m doing after having pulled the container, docker pull dolfinx/dev-env:nightly.
I’m launching the container with the following .env.list file:
Now, typing python3 and then in the command prompt import dolfinx yields the error
Thanks, it’s working like this for me. Not sure what the cause of the problem was. Maybe that something got mixed up with install locations, as I used others than /usr/local.
