Installation of dolfinx_mpc
I installed dolfinx in conda, and the version of it is 0.7.0, but I noticed that the latest dolfinx_mpc is 0.6.1, so when I tried to build it, there is a lot of errors. I also try to install dolfinx_mpc in conda as well:
conda install -c conda-forge libdolfinx_mpc
but it takes forever to creat environment.
Any suggestion regarding my situation? Or should I install dolfinx 0.6.0 if I want to use dolfinx_mpc?
Thanks!
I’ve not had time to update DOLFINx_mpc to be compatible with v0.7.0.
I’ve started with: Fixes for vector elements by jorgensd · Pull Request #77 · jorgensd/dolfinx_mpc · GitHub
but it is not quite done
Ok. Understand, I will go back to v0.6.0 since it worked fine for me. I guess the only way to install the not latest version is building from source? And it is impossible to install v0.6.0 using conda or sudo ?
Thanks for your replying!
Oh, just fixed it. Never mind.
I’ve now released a v0.7.0 of DOLFINX_mpc, compatible with DOLFINx v0.7.0 and v0.7.1
On conda-forge, the version of DOLFINX_mpc is still 0.6.1. Can you say when 0.7.0 will be available there? Thanx!
See: Missing 0.7.x on conda · jorgensd/dolfinx_mpc · Discussion #93 · GitHub
0.7.0 is now being rolled out on conda-forge: Dolfinx Mpc :: Anaconda.org
