Difficulties in using docker image dolfinx_mpc:v0.8.0.post0
Hello all,
I am trying to use the new version 0.8.0 for dolfinx_mpc via docker. I have problems for using the dolfinx_mpc part:
xxx@test:~$ docker pull ghcr.io/jorgensd/dolfinx_mpc:v0.8.0.post0
v0.8.0.post0: Pulling from jorgensd/dolfinx_mpc
3c645031de29: Already exists
4f4fb700ef54: Already exists
47015cdd6499: Already exists
c4b983ba6c68: Already exists
4b0f2b32fe9d: Already exists
0735a16b4797: Already exists
4010ff3b128a: Already exists
1b3a12d2cedb: Already exists
a5e9d2b65ef7: Already exists
049e604d7349: Already exists
d7e4c1c30f79: Already exists
0206e4f74a15: Already exists
bb6de4299671: Already exists
35500ecc44de: Already exists
0658e41621f3: Already exists
eb6772ca3ce2: Already exists
3554461bc0fd: Already exists
243dac84957a: Already exists
1be379a9fafc: Already exists
6a8452fbd728: Already exists
Digest: sha256:28df86f3cfcbe657ef1f6eb0ad17bf2de71814c0321f9fd66c252e01c63eb045
Status: Downloaded newer image for ghcr.io/jorgensd/dolfinx_mpc:v0.8.0.post0
xxx@test:~$ docker run -ti ghcr.io/jorgensd/dolfinx_mpc:v0.8.0.post0
root@22d776c99b93:~# python3
Python 3.10.12 (main, Nov 20 2023, 15:14:05) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import dolfinx_mpc
>>> from dolfinx_mpc import MultiPointConstraint
  File "<stdin>", line 1, in <module>
ImportError: cannot import name 'MultiPointConstraint' from 'dolfinx_mpc' (unknown location)
This error message did not occur in previous versions.
What could be the reason for that?
cc @dokken : I can replicate this on my amd64 system.
I’ve made a 0.8.0.post1 release to fix the dockerfile, it will be done building when Fix typo in version · jorgensd/dolfinx_mpc@b780366 · GitHub passes
New try at: Check docker image build on CI (#116) · jorgensd/dolfinx_mpc@36de714 · GitHub
It works. Thank you!
One more question about the installation via Spack on the HPC:
Is it already possible to install version 0.8.0 of dolfinx via Spack? And how can I specify the version to be installed in the commands?
No, it is currently not released on spack, see versions at: Spack Packages
