Installation of fenics on macOS Sonoma 14.4
Hello everyone,
Please I need your help!
I try to install Fenics with the command instruction on website but I have some issues ‘’ the following packages are not available from the current channel’'.
I have macOS Sonoma 14.4 and I installed anaconda downloading setup and make the installation normally.
Your help will be very helpful for me
Thank you
Hello.
I just tried to install FEniCS on macOS 14.4 yesterday.
(I use miniforge.)
I have been able to install it for now using the following installation method described on the web page.
conda create -n fenicsx-env
conda activate fenicsx-env
conda install -c conda-forge fenics-dolfinx mpich pyvista
Do you select conda-forege with the -c option?
Hello!
Thank you very much. I updated my Conda, and your command worked perfectly
