How can I install Fenics on Windows 8? I’ve just found something for Windows 10.
As windows 8 is reaching its end of life in January 2023, I would strongly suggest upgrading your system to a newer version of Windows that either supports docker or the Windows subsystem for Linux.
I guess the one way of doing it is by using a VirtualBox and run linux through it.
One of the core dependencies of DOLFIN is PETSc, which strongly recommends you not to run on windows: Installing PETSc On Microsoft Windows — PETSc v3.17.0-186-g7d7a130581 documentation
