Dear community,
I have until now used dolfinx only via the docker images on my personal computer.
Now I have to use faculty cluster and hence tried installing dolfinx using spack from the instructions given here.
Following is the error I run into on my personal computer (the installation on cluster is for some reason unknown to me, very slow and I have not yet encountered this error).
Will you kindly let me know on how to fix this?
Thanks a lot.
1 error found in build log:
34 -- Found boost_chrono 1.79.0 at /home/ampdes/spack/opt/spack/linux-ubuntu20.04-icelake/gcc-10.3.0/boost-1.79.0-2mcjachudtjagkpnq2bvbg4qqxfdk56w/lib/cmake/boost_chrono-1.79.0
35 -- [x] libboost_chrono.so.1.79.0
36 -- [ ] libboost_chrono.a
37 -- Adding boost_chrono dependencies: headers
38 -- Found Boost: /home/ampdes/spack/opt/spack/linux-ubuntu20.04-icelake/gcc-10.3.0/boost-1.79.0-2mcjachudtjagkpnq2bvbg4qqxfdk56w/lib/cmake/Boost-1.79.0/BoostConfig.cmake (found suitable versio
n "1.79.0", minimum required is "1.70") found components: timer
39 -- Found Python3: /usr/bin/python3.8 (found version "3.8.10") found components: Interpreter
>> 40 CMake Error at CMakeLists.txt:159 (find_package):
41 Could not find a package configuration file provided by "Basix" with any of
42 the following names:
43
44 BasixConfig.cmake
45 basix-config.cmake
46
See build log for details:
/tmp/ampdes/spack-stage/spack-stage-fenics-dolfinx-0.5.0-cyqtndpxufej652wtaax7dxfcs5lu27z/spack-build-out.txt
==> Warning: Skipping build of py-fenics-dolfinx-0.5.0-tdcv4xehlidlrmeb7cknrgayhg57tcmg since fenics-dolfinx-0.5.0-cyqtndpxufej652wtaax7dxfcs5lu27z failed
==> Error: py-fenics-dolfinx-0.5.0-tdcv4xehlidlrmeb7cknrgayhg57tcmg: Package was not installed
==> Updating view at /home/ampdes/spack/var/spack/environments/fenicsx-env/.spack-env/view
==> Error: Installation request failed. Refer to reported errors for failing package(s).
