I’m solving an equation with an axisymmetric formulation. I obtain the solution u which depens on variables r and z. Now I use u as the rhs of another problem, which is in an axisymmetric setting too. The rhs f, of the second problem, is defined by f:= \dfrac{1}{r}\int_0^r u(t,z)\, t\,dt. How can I to implement this rhs in Fenics? i.e. the term \int f\,v\,dr\,dz…
Many thanks Leo!! but I don’t think that this helps me… if u is a displacement vector, to use your example, then u_r = u[0], as you pointed out. Note that still we have u_r = u_r(r,z)!. My problem it to calculate
\frac{1}{r}\int_0^r u_r(t,z) dt
i.e., integrating only over one variable. Of course this defines a function which depends on r and z. Remember that I know u_r because is the solution to a previos FEM problem…
Anyways, thanks to take time to consider my problem!!
