Integrating FEniCS solution up to some point
As a part of a bigger problem there is a first order equation u'(x) = f(x) on [0,1] coupled with integration condition \int_{[0,1]}u(x)dx = 1 which has to be solved in every step. RHS f is a solution of some other equation. This equation can be solved by pure integration but question is how to do that in FEniCS.
As far as I know we can integrate on a whole domain or on subdomains but how can we say something like u(x)=\int_0^xf(s)ds?
Pick points from mesh, define step functions and then integrate product f\cdot\text{step} and later interpolate to starting function space?
Do you maybe know some tutorial about similar problem?
Did you find a solution for your problem? I’m facing a similar situation.
I would suggest implementing your own integration scheme with quadrature points. As you can evaluate a function at any point, i.e. u(x_p), where x_p is the point of interest, you have that \int_{0}^{x}u(x)\mathrm{ds}=\sum_q w_q u(p_q) where p_q are the quadrature points and w_q the weights on the interval [0, x]
Thank you for the reply. So, considering your comment, an attempt to include the term f(x)\cdot v \Bigg|^{x_1}_{x_0} in the variational form of the problem can be done by evaluating:
f(x)\cdot v \Bigg|^{x_1}_{x_0} = f(x_1)*v(x_1) - f(x_0)*v(x_0)
In that case, how could one access the values of the weights in x = x_1 and x = x_0?
You can find quadrature points and weights for the interval [0,1] at wikipedia: Gaussian quadrature - Wikipedia
You could also, as suggested in the original post, create a step function, (for instance using ufl.conditional), as shown in What is the syntax to import conditional operators from ufl package? - #4 by dokken
N = 10
mesh = UnitIntervalMesh(N)
x = SpatialCoordinate(mesh)
f = project(x[0], V)
def u(x0, degree):
    step = conditional(lt(x[0], x0), 1, 0)
    return  assemble(step*f*dx(domain=mesh, degree=degree))
for p in [0.05, 0.1, 0.23, 0.28]:
    for degree in [2**i for i in range(1,6)]:
        exact = 1/2*(p**2)
        approx = u(p, degree)
        print(p, degree, exact, approx, (exact-approx)/exact )
giving the following for N=10
0.05 2 0.0012500000000000002 0.0010566243270259353 0.15470053837925188
0.05 4 0.0012500000000000002 0.0003130601816090507 0.7495518547127595
0.05 8 0.0012500000000000002 0.0006078258433900407 0.5137393252879675
0.05 16 0.0012500000000000002 0.0008600886103124731 0.31192911175002164
0.05 32 0.0012500000000000002 0.0010324149186984053 0.17406806504127595
0.1 2 0.005000000000000001 0.0049999999999999975 6.938893903907227e-16
0.1 4 0.005000000000000001 0.004999999999999996 1.040834085586084e-15
0.1 8 0.005000000000000001 0.0049999999999999975 6.938893903907227e-16
0.1 16 0.005000000000000001 0.004999999999999997 8.6736173798840335e-16
0.1 32 0.005000000000000001 0.004999999999999999 3.4694469519536137e-16
0.23 2 0.02645 0.031056624327025925 -0.17416349062479863
0.23 4 0.02645 0.025868615737164594 0.021980501430450168
0.23 8 0.02645 0.027763381398945595 -0.04965525137790526
0.23 16 0.02645 0.025557752394857115 0.03373336881447584
0.23 32 0.02645 0.02605440254041938 0.014956425693029152
0.28 2 0.039200000000000006 0.044999999999999984 -0.14795918367346883
0.28 4 0.039200000000000006 0.036979726848275704 0.056639621217456665
0.28 8 0.039200000000000006 0.041501668016300265 -0.058716020823986206
0.28 16 0.039200000000000006 0.037494421258372934 0.043509661776200796
0.28 32 0.039200000000000006 0.03903467013137407 0.004217598689437088
For N=20
0.05 2 0.0012500000000000002 0.0012499999999999994 6.938893903907227e-16
0.05 4 0.0012500000000000002 0.001249999999999999 1.040834085586084e-15
0.05 8 0.0012500000000000002 0.0012499999999999994 6.938893903907227e-16
0.05 16 0.0012500000000000002 0.0012499999999999992 8.6736173798840335e-16
0.05 32 0.0012500000000000002 0.0012499999999999998 3.4694469519536137e-16
0.1 2 0.005000000000000001 0.004999999999999998 5.20417042793042e-16
0.1 4 0.005000000000000001 0.0049999999999999975 6.938893903907227e-16
0.1 8 0.005000000000000001 0.004999999999999999 3.4694469519536137e-16
0.1 16 0.005000000000000001 0.004999999999999998 5.20417042793042e-16
0.1 32 0.005000000000000001 0.005000000000000001 0.0
0.23 2 0.02645 0.025264156081756483 0.04483341845911222
0.23 4 0.02645 0.027856042823180036 -0.053158518834783904
0.23 8 0.02645 0.026929734238625287 -0.01813740032609774
0.23 16 0.02645 0.02624702013695705 0.007674096901434859
0.23 32 0.02645 0.026831735198445915 -0.01443233264445798
0.28 2 0.039200000000000006 0.03776415608175648 0.03662867138376349
0.28 4 0.039200000000000006 0.04091159837873558 -0.04366322394733602
0.28 8 0.039200000000000006 0.039785289794180834 -0.014930862096449692
0.28 16 0.039200000000000006 0.03895341973383283 0.0062903129124279285
0.28 32 0.039200000000000006 0.039664592624127276 -0.011851852656307919
Note that as long as the point x0 does not align with the interval, you do not obtain an exact value.
Thank you, dokken. The model I’m developing relies on a second-order stress equation on a boundary of a 2D (rectangle) domain.
I integrate the equation by parts to reduce the order, and the process yields the term t \cdot \phi \Big |^{S_f}_{S_i}, in which t is the tangent vector, \phi is a test function from a vector function space and S_f and S_i are the end and begin of the boundary S, respectively.
Considering the value of \phi(S_f)= \phi(S_i) = 1, the terms t \cdot \phi (S_f) and - t \cdot \phi (S_i) should be included in the residual of the element located at S_f and S_i. I’ve been struggling to find a solution to this problem, as I don’t know how to mark an edge using a MeshFunction and I still don’t know how could I work with the residual of an element alongside the weighted residual from the problem formulation. I defined a dummy function t_edges that takes the tangent value on the edges and is zero everywhere else, and the I add the term inner(t_edges, phi)*ds(marker) into the variational formulation. However this approach is not working. Do you have any thoughts on how I could do this?
