Integrating over a boundary surface in DolfinX 0.11
In using the “allreduce” statement to generate an integral over a boundary surface that computes the surface area of a boundary, something seems to have changed in the way this is done. (It works in DolfinX 0.9.0.) The boundaries in question are sub-boundaries labeled as such in the GMSH code (labels 2 and 3).
The problematic lines are at the end of this almost-running example
import sys
from mpi4py import MPI as M
from petsc4py import PETSc as P
import ufl as U
import basix.ufl
from dolfinx.io import gmsh as gmshio
from dolfinx.fem import petsc
from dolfinx import mesh as msh
from dolfinx import fem
from dolfinx import io
from dolfinx import plot
import scifem
import time
try:
    import pyvista
    have_pyvista = True
except ModuleNotFoundError:
    print("Pyvista required to visualize solution.")
    have_pyvista = False
t_start = time.perf_counter()
eps = 1.0e-4
a = 22.86 #WG width
b = 10.16 #WG height
l = 50.8 # WG length
posx = a/3
posz = l/2
rad = 1.0
f = 16.5 #frequency of operation GHz
c = 300.0 #speed of light
#lm = 0.565
lm = 1.2
mode = 1
model = None
comm = M.COMM_WORLD
mpiRank = comm.rank
mpiSize = comm.size
print("MPI rank = {0}, MPI size = {1}.".format(mpiRank, mpiSize))
modelRank = 0 # where GMSH runs
k0 = 2.0 * np.pi * f / c #wavenumber wrt frequency
if mpiRank == modelRank:
    WithObstruction = 1
    gmsh.option.setNumber('General.Terminal', 1)
    gmsh.model.add('Waveguide')
    if(WithObstruction != 0):
        gmsh.model.occ.addBox(0, 0, 0, a, b, l, 1)
        gmsh.model.occ.addCylinder(posx, 0, posz, 0, b, 0, rad, 2, np.pi * 2.0)
        gmsh.model.occ.addCylinder(posx/2, 0, posz, 0, b, 0, rad, 20, np.pi * 2.0)
        gmsh.model.occ.cut([(3,1)], [(3,2),(3,20)], 3, removeObject=True, removeTool=True)
        gmsh.model.occ.addBox(0, 0, 0, a, b, l, 3)
    gmsh.model.occ.synchronize()
    pt = gmsh.model.getEntities(dim=0)
    gmsh.model.mesh.setSize(pt, lm)
    gmsh.option.setNumber('Mesh.MeshSizeMin', 0.01)
    gmsh.option.setNumber('Mesh.MeshSizeMax', 5.2)
    gmsh.option.setNumber('Mesh.Algorithm', 6) #1=Mesh Adapt, 2=Auto, 3=Initial mesh only, 5=Delaunay, 6=Frontal-Delaunay
    gmsh.option.setNumber('Mesh.MinimumCirclePoints', 30)
    gmsh.option.setNumber('Mesh.CharacteristicLengthFromCurvature', 1)
    gmsh.option.setNumber('Mesh.Tetrahedra', 0)
    OUT = []
    IN = []
    PEC = []
    bb = gmsh.model.getEntities(dim=3)
    pt = gmsh.model.getBoundary(bb, combined=True, oriented=False, recursive=False)
    for bnd in pt:
        CoM = gmsh.model.occ.getCenterOfMass(bnd[0], bnd[1])
        if np.abs(CoM[2]) < eps:
            IN.append(bnd[1])
        elif np.abs(CoM[2] - l) < eps:
            OUT.append(bnd[1])
            PEC.append(bnd[1])
    gmsh.model.addPhysicalGroup(3, [3], 1) #WG
    gmsh.model.setPhysicalName(3, 1, "Waveguide")
    gmsh.model.addPhysicalGroup(2, PEC, 1)
    gmsh.model.setPhysicalName(2, 1, "PEC")
    gmsh.model.addPhysicalGroup(2, IN, 2)
    gmsh.model.setPhysicalName(2, 2, "INPORT")
    gmsh.model.addPhysicalGroup(2, OUT, 3)
    gmsh.model.setPhysicalName(2, 3, "OUTPORT")
    gmsh.model.mesh.generate(3)
    model = gmsh.model
model = comm.bcast(model, root=modelRank)
mesh_data = gmshio.model_to_mesh(model, comm, modelRank, gdim=3)
    gmsh.finalize()
comm.barrier()
mesh_data.mesh.topology.create_connectivity(mesh_data.mesh.topology.dim-1, mesh_data.mesh.topology.dim)
exterior_facets=msh.exterior_facet_indices(mesh_data.mesh.topology)
fm = mesh_data.facet_tags
ct = mesh_data.cell_tags
#Real function space to be used on surface tags 2 and 3 for mode 1
Z1 = scifem.create_real_functionspace(mesh_data.mesh, value_shape=(4,))
zu = U.TrialFunction(Z1)
zv  = U.TestFunction(Z1)
#Internal E field solution space
elem = basix.ufl.element('N1curl', mesh_data.mesh.basix_cell(), degree=2)
V = fem.functionspace(mesh_data.mesh, elem)
u = U.TrialFunction(V)
v = U.TestFunction(V)
n = U.FacetNormal(mesh_data.mesh)
# The integration domain over the input and output ports (boundary tags 2 and 3)
ds2 = U.Measure("ds", domain=mesh_data.mesh, subdomain_data=fm, subdomain_id=2)
ds3 = U.Measure("ds", domain=mesh_data.mesh, subdomain_data=fm, subdomain_id=3)
# Weak form. Need areas over the input and output ports in order to normalize mode coefficients
# This is where the program crashes.
Area1 = mesh_data.mesh.comm.allreduce(fem.assemble_scalar(fem.form(U.inner(n, n) * ds2)), op=M.SUM)
Area2 = mesh_data.mesh.comm.allreduce(fem.assemble_scalar(fem.form(U.inner(n, n) * ds3)), op=M.SUM)
print("Area 1 = {0}, Area 2 = {1}".format(Area1, Area2))
sys.exit(0)
I get an “incompatible function arguments” error:
  File "/home/bill/WaveguideBC/Test.py", line 120, in <module>
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
    1. __init__(self, spaces: collections.abc.Sequence[dolfinx.cpp.fem.FunctionSpace_float64], integrals: collections.abc.Mapping[dolfinx.cpp.fem._IntegralType, collections.abc.Sequence[tuple[int, int, ndarray[dtype=int32, shape=(*), order='C', writable=False], ndarray[dtype=int8, shape=(*), order='C', writable=False]]]], coefficients: collections.abc.Sequence[dolfinx.cpp.fem.Function_complex128], constants: collections.abc.Sequence[dolfinx.cpp.fem.Constant_complex128], need_permutation_data: bool, entity_maps: collections.abc.Sequence[dolfinx.cpp.mesh.EntityMap], mesh: dolfinx.cpp.mesh.Mesh_float64) -> None
    2. __init__(self, form: collections.abc.Sequence[int], spaces: collections.abc.Sequence[dolfinx.cpp.fem.FunctionSpace_float64], coefficients: collections.abc.Sequence[dolfinx.cpp.fem.Function_complex128], constants: collections.abc.Sequence[dolfinx.cpp.fem.Constant_complex128], subdomains: collections.abc.Mapping[dolfinx.cpp.fem._IntegralType, collections.abc.Sequence[tuple[int, ndarray[dtype=int32, shape=(*), order='C', writable=False]]]], entity_maps: collections.abc.Sequence[dolfinx.cpp.mesh.EntityMap], mesh: dolfinx.cpp.mesh.Mesh_float64 | None) -> None
I looked at some tutorial examples that use this form integration method and I cannot see what I am doing incorrectly. What am I missing?
I can’t reproduce your error with docker run -ti -v $(pwd):/root/shared -w /root/shared --rm ghcr.io/fenics/dolfinx/dolfinx:stable. How did you install dolfinx?
Dear Dokken,
I installed with Spack using the following sequence of commands
spack add py-fenics-dolfinx@0.11.0.post0 +slepc
spack add py-mpi4py@4.0.1
spack add py-numpy
spack add py-matplotlib
spack add py-pandas
spack add py-gmsh
spack add openmpi
spack add petsc@3.24.1 +fortran +mumps +superlu-dist +complex
spack add py-scifem
spack add py-pyvista
spack concretize --force
spack install
It is possible that there is a dependency conflict somewhere.. :thinking:
Cheers!
Could you try with an env config like:
# This is a Spack Environment file.
# It describes a set of packages to be installed, along with
# configuration settings.
spack:
  # add package specs to the `specs` list
  specs:
  - py-scifem ^py-fenics-dolfinx@0.11.0.post0+slepc4py ^petsc@3.24.1+complex+fortran+mumps+superlu-dist ^py-mpi4py@4.0.1 ^py-numpy ^openmpi ^py-nanobind@2.8.0
  - py-matplotlib
  - py-pandas
  - py-gmsh
  - py-pyvista
  packages:
    py-nanobind:
      require: "@2.8.0"
    py-fenics-dolfinx:
      require: "%py-nanobind@2.8.0"
    py-fenics-basix:
  view: true
  concretizer:
    unify: true
Dear Dokken,
That works! It was indeed a dependency problem.
