Integrating over an interior surface
It is because the input to C++ requires integration_entities to be flattened (i.e. a flat array where each row is stacked after eachother).
OK your example function works just fine, also on my mesh. However, as soon as I try to compute a tangential derivative, I get weird results, e.g. consider this code
from dolfinx.io import gmshio
from ufl import Measure, grad, inner, FacetNormal, dot, SpatialCoordinate, as_vector
from dolfinx.fem import form, assemble_scalar, functionspace, Function
from dolfinx.mesh import meshtags
from dolfinx import plot
import pyvista as pv
def grad_t(u, n):
    return grad(u) - dot(grad(u), n) * n
def get_mesh(size: float = 0.2, meshsize: float = 0.05, name: str = "dev"):
    comm = MPI.COMM_WORLD
    gmsh.model.add(name)
    model = gmsh.model
    geom = model.occ
    gdim = 2
    defeatured_domain_tag = geom.addDisk(0, 0, 0, 1, 1)
    geom.synchronize()
    disk_tag = geom.addDisk(0, 0, 0, size, size, defeatured_domain_tag + 1)
    geom.synchronize()
    out_dim_tags, *_ = geom.cut(
        [(gdim, defeatured_domain_tag)],
        [(gdim, disk_tag)],
        removeTool=False,
        removeObject=False,
    _, exact_domain_tag = out_dim_tags[0]
    geom.synchronize()
    exact_domain_marker = model.addPhysicalGroup(gdim, [exact_domain_tag])
    model.setPhysicalName(gdim, exact_domain_marker, "ExactDomain")
    outer_boundary = model.getBoundary([(gdim, defeatured_domain_tag)], oriented=False)
    outer_boundary_marker = model.addPhysicalGroup(
        gdim - 1, [b[1] for b in outer_boundary]
    model.setPhysicalName(gdim - 1, outer_boundary_marker, "OuterBoundary")
    disk_marker = model.addPhysicalGroup(gdim, [disk_tag])
    model.setPhysicalName(gdim, disk_marker, "Disk")
    disk_boundary = model.getBoundary([(gdim, disk_tag)], oriented=False)
    disk_boundary_marker = model.addPhysicalGroup(
        gdim - 1, [b[1] for b in disk_boundary]
    model.setPhysicalName(gdim - 1, disk_boundary_marker, "BoundaryDisk")
    gmsh.option.setNumber("Mesh.CharacteristicLengthMin", meshsize)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", meshsize)
    gmsh.model.mesh.generate(dim=gdim)
    gmsh.write(f"{name}.msh")
    mesh = meshio.read(f"{name}.msh")
    meshio.write(f"{name}.xdmf", mesh)
    domain, cell_markers, facet_markers = gmshio.model_to_mesh(
        gmsh.model, comm, rank=0, gdim=gdim
    gmsh.finalize()
    name2marker = {
        "ExactDomain": exact_domain_marker,
        "OuterBoundary": outer_boundary_marker,
        "Disk": disk_marker,
        "BoundaryDisk": disk_boundary_marker,
    return domain, cell_markers, facet_markers, name2marker
if __name__ == "__main__":
    size = 0.5
    mesh, cell_tags, facet_tags, name2marker = get_mesh(size=size, meshsize=0.01)
    tdim = mesh.topology.dim
    fdim = tdim - 1
    disk_boundary_marker = name2marker["BoundaryDisk"]
    disk_marker = name2marker["Disk"]
    outer_marker = name2marker["OuterBoundary"]
    outer_facets = facet_tags.find(outer_marker)
    outer_tags = meshtags(mesh, fdim, outer_facets, outer_marker)
    disk_boundary_facets = facet_tags.find(disk_boundary_marker)
    f2c = mesh.topology.connectivity(fdim, tdim)
    c2f = mesh.topology.connectivity(tdim, fdim)
    integration_entities = []
    for i, facet in enumerate(disk_boundary_facets):
        cells = f2c.links(facet)
        marked_cells = cell_tags.values[cells]
        correct_cell = np.flatnonzero(marked_cells == disk_marker)
        assert len(correct_cell) == 1
        local_facets = c2f.links(cells[correct_cell[0]])
        local_index = np.flatnonzero(local_facets == facet)
        assert len(local_index) == 1
        integration_entities.append((cells[correct_cell[0]], local_index[0]))
    ds = Measure("ds", domain=mesh, subdomain_data=[
                 (disk_boundary_marker, np.asarray(integration_entities, dtype=np.int32).flatten())
    V = functionspace(mesh, ("CG", 1))
    u.interpolate(lambda x: x[0]**2)
    integral = inner(grad_t(u, n), grad_t(u, n)) * ds
    norm = form(integral)
    print(
        f"Integral: {mesh.comm.allreduce(assemble_scalar(norm), op=MPI.SUM)}"
    print(
        f"Correct integral: {size**3 * np.pi}"
What would be the correct way to compute the tangential derivative of a function and then compute its L^2-norm?
What do you mean by weird results?
Could you also consider this on a simple, circular geometry with a standard measure?
Secondly, you are approximating x^2 with a piecewise linear function, which means that \nabla u is a piecewise constant, which would give you way lower accuracy than you would hope for. Try the same example with u being in a second order Lagrange space.
By weird results I mean that the integral of the tangential gradient on an interior boundary is not correctly computed, even if I explicitly construct an oriented measure as you have explained above. Here, by interior boundary, I mean the inner circle of my two circles.
When I do the same but only on the inner circle with the default measure on outer boundaries provided by FenicsX, the result is correct.
Here’s an MWE:
def grad_t(u, n):
def get_inner_mesh(size: float = 0.2, meshsize: float = 0.05, name: str = "dev_inner"):
    model = gmsh.model
    geom = model.occ
    gdim = 2
    domain_tag = geom.addDisk(0, 0, 0, size, size)
    geom.synchronize()
    exact_domain_marker = model.addPhysicalGroup(gdim, [domain_tag])
    boundary = model.getBoundary([(gdim, domain_tag)], oriented=False)
    boundary_marker = model.addPhysicalGroup(gdim - 1, [b[1] for b in boundary])
    model.setPhysicalName(gdim - 1, boundary_marker, "OuterBoundary")
    gmsh.finalize()
    name2marker = {"ExactDomain": exact_domain_marker, "OuterBoundary": boundary_marker}
def get_full_mesh(size: float = 0.2, meshsize: float = 0.05, name: str = "dev"):
    model = gmsh.model
    geom = model.occ
    gdim = 2
    geom.synchronize()
    geom.synchronize()
        [(gdim, disk_tag)],
        removeTool=False,
        removeObject=False,
    geom.synchronize()
    gmsh.finalize()
    name2marker = {
def get_oriented_measure(
    mesh, cell_tags, tdim, fdim, int_boundary_marker, int_marker, int_boundary_facets
    for i, facet in enumerate(int_boundary_facets):
        correct_cell = np.flatnonzero(marked_cells == int_marker)
    ds = Measure(
        "ds",
        domain=mesh,
        subdomain_data=[
                np.asarray(integration_entities, dtype=np.int32).flatten(),
    return ds
def run_full_mwe(size: float = 0.5, meshsize: float = 0.01, deg: int = 1):
    print("Running MWE on the full disk with oriented measure...")
    mesh, cell_tags, facet_tags, name2marker = get_full_mesh(
        size=size, meshsize=meshsize
    fdim = tdim - 1
    ds = get_oriented_measure(
        mesh,
        cell_tags,
        tdim,
        fdim,
        disk_marker,
        disk_boundary_facets,
    u.interpolate(lambda x: x[0] ** 2)
    result_title = "----- Result on full disk and interior boundary -----"
    print(result_title)
    print(f"Integral: {mesh.comm.allreduce(assemble_scalar(norm), op=MPI.SUM)}")
    print(f"Correct integral: {size**3 * np.pi}")
    print("-" * len(result_title))
def run_inner_mwe(size: float = 0.5, meshsize: float = 0.01, deg: int = 1):
    print("Running MWE on the inner disk with default measure...")
    mesh, *_ = get_inner_mesh(
    ds = Measure("ds", domain=mesh)
    result_title = "----- Result on inner disk -----"
    print(result_title)
    run_full_mwe(size=0.5, meshsize=0.005, deg=1)
    run_inner_mwe(size=0.5, meshsize=0.005, deg=1)
