Integrating an expression over an internal boundary
I am using dolfinx 0.4.1 installed through conda. My geometry is a square box containing two concentric circles inside. I want to integrate an algebraic expression (which will involve the solution as well) over the circumference of each circle i.e. internal boundaries. The example I am trying to follow is from the following thread:
Therefore, my code looks like this
dS = ufl.Measure(“dS”, model.mesh, subdomain_data=boundary_index)
S = dolfinx.fem.assemble(dS) # test by evaluating the circumference
However, I could not find the counterpart of MeshFunction() used in the referred thread in the new dolfinx I am using. Moreover, I also could not understand how to distinguish between the circumferences of the two circles separately. I would appreciate if someone could show me how it is done.
Thanks a lot
You should use MeshTags. See for instance:
https://jorgensd.github.io/dolfinx-tutorial/chapter3/subdomains.html?highlight=meshtags#convert-msh-files-to-xdmf-using-meshio
and
https://jorgensd.github.io/dolfinx-tutorial/chapter3/robin_neumann_dirichlet.html
Thanks for your quick reply!
In my version (0.4.1) dolfinx.MeshTags does not appear to be a valid attribute. Further, I am sadly still very dumb about the finer details. Say I have the ct and ft objects that contain mesh and edge information. How would I feed either of them into ufl.Measure or fem.assemble so as to perform the integration?
There was an interface change back in 0.3.0 or so:
In [3]: dolfinx.mesh.meshtags?
Signature:
dolfinx.mesh.meshtags(
    mesh: 'Mesh',
    dim: 'int',
    indices: 'np.ndarray',
    values: 'np.ndarray',
) -> 'MeshTagsMetaClass'
Docstring:
Create a MeshTags object that associates data with a subset of mesh entities.
Args:
    mesh: The mesh
    dim: Topological dimension of the mesh entity
    indices: Entity indices (local to process)
    values: The corresponding value for each entity
Returns:
    A MeshTags object
Note:
    The type of the returned MeshTags is inferred from the type of
    ``values``.
Thanks a lot Nate for the heads up!
So now this is how I am trying to do it:
# we already have ft instance computed as described in the tutorial shared above
bnd_tag = 6 # physical tag assigned to the boundary/edge we want to compute the integral on
arc_indices = ft.indices[ft.values == bnd_tag]
arc_tags = dolfinx.mesh.meshtags(model.mesh, 1, arc_indices, 6)
dS = ufl.Measure("dS", domain=model.mesh, subdomain_data=arc_tags)
print(dolfinx.fem.assemble.assemble_scalar(dS))
In the print statement, I used assemble_scalar as I could not find assemble() function itself. However, this too gives me the following error:
File “/install/miniconda3/envs/fenics/lib/python3.9/site-packages/IPython/core/interactiveshell.py”, line 3398, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File “”, line 1, in <cell line: 1>
dolfinx.cpp.fem.assemble_scalar(dS)
TypeError: assemble_scalar(): incompatible function arguments. The following argument types are supported:
1. (M: dolfinx::fem::Form, constants: numpy.ndarray[numpy.float64], coefficients: Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.float64]]) → float
2. (M: dolfinx::fem::Form, constants: numpy.ndarray[numpy.float32], coefficients: Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.float32]]) → float
3. (M: dolfinx::fem::Form<std::complex >, constants: numpy.ndarray[numpy.complex128], coefficients: Dict[Tuple[dolfinx::fem::IntegralType, int], numpy.ndarray[numpy.complex128]]) → complex
Invoked with: Measure(‘interior_facet’, subdomain_id=‘everywhere’, domain=Mesh(VectorElement(FiniteElement(‘Lagrange’, triangle, 1, variant=‘equispaced’), dim=2, variant=‘equispaced’), 0), subdomain_data=<dolfinx.mesh.MeshTagsMetaClass object at 0x7f132a6e71d0>)
Did you forget to #include <pybind11/stl.h>? Or <pybind11/complex.h>,
<pybind11/functional.h>, <pybind11/chrono.h>, etc. Some automatic
conversions are optional and require extra headers to be included
when compiling your pybind11 module.
Obviously assemble_scalar was a guess, trying assemble_vector also leads to some other error. I would appreciate if anyone could pull me out of this :slight_smile:
I would suggest you read through the tutorial: The FEniCSx tutorial — FEniCSx tutorial
as it explains how to use assemble_scalar, assemble_vector etc, as you need to call dolfinx.fem.form(1*dS) prior to inputting into any of the aforementioned functions.
That was a super comment! Thank you so much for your tutorials and being ever so ready to direct to them!
I am able to calculate integrals in individual subdomains as well as on facets now!
