I want to create two functionspaces from one mesh, e.g. as in this image, with the interface \Gamma between the subdomains \Omega_A and \Omega_B at x=0.
I’ve used create_submesh to create two seperate meshes for each domain. Assembling vectors inside the domain works. Now I want to assemble Neumann BCs that are functions of the unknowns on both sides of the interface, e.g. f = 0.5(u_B - u_a). Think chemical reactions between species in \Omega_A and \Omega_B.
I created a Measure ds with the marker 1 at the interface, and tried to assemble \int_{\Gamma} v_a f \mathrm{d}s. This fails with the following error message:
IndexError Traceback (most recent call last)
File /home/ubuntu/interface_example.py:72
68 boundary_term = v_a * f * ds(1)
70 rhs = form(boundary_term)
---> 72 rhs_vector = assemble_vector(rhs)
File /usr/lib/python3.12/functools.py:909, in singledispatch.<locals>.wrapper(*args, **kw)
905 if not args:
906 raise TypeError(f'{funcname} requires at least '
907 '1 positional argument')
--> 909 return dispatch(args[0].__class__)(*args, **kw)
File /usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/assemble.py:180, in _assemble_vector_form(L, constants, coeffs)
178 b.array[:] = 0
179 constants = constants or _pack_constants(L._cpp_object)
--> 180 coeffs = coeffs or _pack_coefficients(L._cpp_object)
181 _assemble_vector_array(b.array, L, constants, coeffs)
182 return b
IndexError: map::at
A M(n)WE of all I have described so far:
#!/usr/bin/env python3
from ufl import Measure, TestFunction
from dolfinx.io.gmshio import model_to_mesh
from dolfinx.mesh import create_submesh, locate_entities, meshtags
from dolfinx.fem import functionspace, Function, form, assemble_vector
def create_model():
gmsh.model.add("t2")
lc = 0.25
gmsh.model.occ.addPoint(1, 0, 0, lc, 1)
gmsh.model.occ.addPoint(1, 1, 0, lc, 2)
gmsh.model.occ.addPoint(1, 1, 1, lc, 3)
gmsh.model.occ.addPoint(1, 0, 1, lc, 4)
gmsh.model.occ.addLine(1, 2, 1)
gmsh.model.occ.addLine(2, 3, 2)
gmsh.model.occ.addLine(3, 4, 3)
gmsh.model.occ.addLine(4, 1, 4)
gmsh.model.occ.addCurveLoop([1, 2, 3, 4], 1)
gmsh.model.occ.addPlaneSurface([1], 1)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(3, [1], name="left_volume")
gmsh.model.addPhysicalGroup(3, [2], name="right_volume")
gmsh.model.mesh.generate(3)
return gmsh.model
mesh, cell_tags, facet_tags = model_to_mesh(create_model(), MPI.COMM_WORLD, rank=0)
left_indices = np.where(cell_tags.values==1)[0]
right_indices = np.where(cell_tags.values==2)[0]
submesh_left, cell_map_left, _, _ = create_submesh(mesh, 3, left_indices)
submesh_right, cell_map_right, _, _ = create_submesh(mesh, 3, right_indices)
V_A = functionspace(submesh_left, ("Lagrange", 1))
V_B = functionspace(submesh_right, ("Lagrange", 1))
u_a = Function(V_A)
u_b = Function(V_B)
v_a = TestFunction(V_A)
v_b = TestFunction(V_B)
u_a.vector.array.fill(1.0)
u_b.vector.array.fill(2.0)
interface_facets = locate_entities(submesh_left, 2, lambda x: np.isclose(x[0], 0.0))
marker = np.full_like(interface_facets, 1)
facet_tags = meshtags(submesh_left, 2, interface_facets, marker)
ds = Measure("ds", domain=submesh_left, subdomain_data=facet_tags)
f = 0.5*(u_b - u_a)
This leads me to the following questions:
- Is this in general the correct approach?
- I found that I can supply
form()withentity_maps, which I think are the maps this index error occurs, but I’m not sure what to put in there. The submeshes don’t have any cells in common; would supplying facet and point maps suffice? How should they be constructed? - Can I put this in more general terms, so that I don’t have to do the interface tags & measure twice? For a form
v_b * f * ds(1)I would presumeably need a differentds, right?
I’m running MacOS 14 on ARM, and tried with both Dolfinx 0.8 from conda, and nightly using docker.
