Thanks, Stein. That’s exactly what I want. I am new to fenics and by using two fields defined over two submeshes is cited from topic_example
Also I have found topic is similar to my problem ,and I have rerite the code
import dolfinx.fem.petsc
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx, grad, div, FacetNormal, inner, avg
from dolfinx import default_scalar_type
from dolfinx import fem, mesh, io, plot
def V_exact(mode):
"""Define exact solution function"""
return lambda x: -mode.cos(mode.pi * x[1])
V_numpy = V_exact(np) # Used for interpolation
V_ufl = V_exact(ufl) # Used for defining source term
def solve_poisson(N, degree=1):
Solve Poisson equation with interface conditions
# Create unit square mesh
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
[N, N], mesh.CellType.triangle)
# Why connectivity is needed:
# - Boundary conditions are defined on edges
# - Finite element degrees of freedom are associated with cells
# - To know which DOFs are affected by boundary conditions, the code needs to know which cells connect to boundary edges
domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
# Create discontinuous Galerkin space for representing discontinuous material properties
Q = fem.functionspace(domain, ("DG", 0))
# Define subdomains
def Omega_0(x):
return x[1] <= 0.50
def Omega_1(x):
return x[1] >= 0.50
# Set spatial coordinates
x = SpatialCoordinate(domain)
# Create conductivity function and assign values
sigma = fem.Function(Q)
cells_0 = mesh.locate_entities(domain, domain.topology.dim, Omega_0)
cells_1 = mesh.locate_entities(domain, domain.topology.dim, Omega_1)
def anode_conductivity(T):
return 1. / (5.929e-5 - T * 1.235e-8)
# Set different conductivity values for different regions
sigma.x.array[cells_0] = np.full_like(cells_0, 210, dtype=default_scalar_type)
sigma.x.array[cells_1] = np.full_like(cells_1, anode_conductivity(800), dtype=default_scalar_type)
# Calculate source term based on exact solution
f = div(-sigma * grad(V_ufl(x)))
# Create first-order Lagrange function space for solution
W = fem.functionspace(domain, ("Lagrange", 1))
V = TrialFunction(W)
phi = TestFunction(W)
# Variational form left side: bilinear form
a = dot(sigma * grad(V), grad(phi)) * dx
# Mark boundaries and interface
boundaries = [(1, lambda x: np.isclose(x[0], 0)), # Left boundary
(2, lambda x: np.isclose(x[0], 1)), # Right boundary
(3, lambda x: np.isclose(x[1], 0)), # Bottom boundary
(4, lambda x: np.isclose(x[1], 1)), # Top boundary
(5, lambda x: np.isclose(x[1], 0.5))] # Interface
# Create boundary markers
facet_indices, facet_markers = [], []
fdim = domain.topology.dim - 1
for (marker, locator) in boundaries:
facets = mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_markers.append(np.full_like(facets, marker))
facet_indices = np.hstack(facet_indices).astype(np.int32)
facet_markers = np.hstack(facet_markers).astype(np.int32)
sorted_facets = np.argsort(facet_indices)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
# Define interior interface integration measure
dS = ufl.Measure("dS", domain=domain, subdomain_data=facet_tag)
# Calculate flux jump at the interface
n = FacetNormal(domain)
# Calculate flux jump at the interface based on exact solution
g = ufl.pi * (sigma('+') - sigma('-')) # Because cos(pi*y) has zero derivative at y=0.5
# Variational form right side: linear form
L = f * phi * dx + g * avg(phi) * dS(5) # Using average of test function
# Set Dirichlet boundary conditions
facets_bottom = facet_tag.find(3)
dofs_bottom = fem.locate_dofs_topological(W, fdim, facets_bottom)
facets_top = facet_tag.find(4)
dofs_top = fem.locate_dofs_topological(W, fdim, facets_top)
BCs = [
fem.dirichletbc(PETSc.ScalarType(-1), dofs_bottom, W), # Bottom boundary condition
fem.dirichletbc(PETSc.ScalarType(1), dofs_top, W) # Top boundary condition
# Solve linear problem
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=BCs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
return problem.solve(), V_ufl(x)
def error_L2_func(Vh, V_ex, degree_raise=3):
"""Calculate L2 error norm"""
# Create higher-order function space
degree = 1
family = Vh.function_space.ufl_element().family_name
mesh = Vh.function_space.mesh
Q = fem.functionspace(mesh, (family, degree + degree_raise))
# Interpolate numerical solution
V_W = fem.Function(Q)
V_W.interpolate(Vh)
# Interpolate exact solution
V_ex_W = fem.Function(Q)
if isinstance(V_ex, ufl.core.expr.Expr):
u_expr = fem.Expression(V_ex, Q.element.interpolation_points)
V_ex_W.interpolate(u_expr)
V_ex_W.interpolate(V_ex)
# Calculate error
e_W = fem.Function(Q)
e_W.x.array[:] = V_W.x.array - V_ex_W.x.array
# Integrate error
error = fem.form(ufl.inner(e_W, e_W) * ufl.dx)
error_local = fem.assemble_scalar(error)
error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
return np.sqrt(error_global)
# Convergence test
N = [40, 80, 160, 320, 640]
error_L2 = []
error_H1 = []
h = []
mpi_rank = 5
for i in range(len(N)):
Vh, Vex = solve_poisson(N[i])
comm = Vh.function_space.mesh.comm
# Calculate L2 error
error_L2 += [error_L2_func(Vh, V_numpy)]
# Calculate H1 seminorm error
eh = Vh - Vex
error_H10 = fem.form(dot(grad(eh), grad(eh)) * dx)
E_H10 = np.sqrt(comm.allreduce(fem.assemble_scalar(error_H10), op=MPI.SUM))
error_H1 += [E_H10]
h += [1. / N[i]]
if comm.rank == 0:
mpi_rank = comm.rank
print(f"h: {h[i]:.2e} Error L2: {error_L2[i]:.2e}")
print(f"h: {h[i]:.2e} Error H1: {error_H1[i]:.2e}")
# Plot convergence curves
if mpi_rank == 0:
plt.figure(figsize=(10, 6))
plt.loglog(N, error_L2, 'o-', label='$L^2$ error')
plt.loglog(N, error_H1, 's-', label='$H^1$ error')
# Reference lines
plt.loglog(N, h, '--', label='$O(h)$')
h_square = [x ** 2 for x in h]
plt.loglog(N, h_square, '-.', label='$O(h^2)$')
plt.xlabel('Mesh resolution N')
plt.ylabel('Error')
plt.title('Error Convergence Analysis')
plt.legend()
plt.grid(True)
plt.show()
But please forgive my ignorance as a beginner. I still want to know the implementation process of using weak forms such as the Lagrange multiplier method or the Nitsche method. I’ve found two similar examples, but I don’t know how to modify them into the format of interface flux jump to meet the requirements of my problem.
Nitsche method example:
# In this demo, we implement a domain decomposition scheme for
# the Poisson equation based on Nitche's method. The scheme can
# be found in "Mortaring by a method of J. A. Nitsche" by Rolf
# Stenberg. See also "A finite element method for domain
# decomposition with non-matching grids" by Becker et al.
from dolfinx import mesh, fem, io
from ufl import inner, grad, avg, div
from utils import norm_L2, convert_facet_tags, interface_int_entities
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from meshing import create_square_with_circle
def u_e(x, module=np):
"A function to represent the exact solution"
return module.exp(-((x[0] - 0.5) ** 2 + (x[1] - 0.5) ** 2) / (2 * 0.05**2)) + x[0]
# Set some parameters
comm = MPI.COMM_WORLD
h = 0.05 # Maximum cell diameter
k_0 = 1 # Polynomial degree in omega_0
k_1 = 3 # Polynomial degree in omega_1
# Create mesh and sub-meshes
msh, ct, ft, vol_ids, surf_ids = create_square_with_circle(comm, h)
tdim = msh.topology.dim
submesh_0, sm_0_to_msh = mesh.create_submesh(msh, tdim, ct.find(vol_ids["omega_0"]))[:2]
submesh_1, sm_1_to_msh = mesh.create_submesh(msh, tdim, ct.find(vol_ids["omega_1"]))[:2]
# Define function spaces on each submesh
V_0 = fem.functionspace(submesh_0, ("Lagrange", k_0))
V_1 = fem.functionspace(submesh_1, ("Lagrange", k_1))
W = ufl.MixedFunctionSpace(V_0, V_1)
# Test and trial functions
u = ufl.TrialFunctions(W)
v = ufl.TestFunctions(W)
# We use msh as the integration domain, so we require maps from cells
# in msh to cells in submesh_0 and submesh_1. These can be created
# as follows:
cell_imap = msh.topology.index_map(tdim)
num_cells = cell_imap.size_local + cell_imap.num_ghosts
msh_to_sm_0 = np.full(num_cells, -1)
msh_to_sm_0[sm_0_to_msh] = np.arange(len(sm_0_to_msh))
msh_to_sm_1 = np.full(num_cells, -1)
msh_to_sm_1[sm_1_to_msh] = np.arange(len(sm_1_to_msh))
# Compute integration entities for the interface integral
fdim = tdim - 1
interface_facets = ft.find(surf_ids["interface"])
domain_0_cells = ct.find(vol_ids["omega_0"])
domain_1_cells = ct.find(vol_ids["omega_1"])
# Create interface integration entities and modify msh_to_sm maps
interface_entities, msh_to_sm_0, msh_to_sm_1 = interface_int_entities(
msh, interface_facets, msh_to_sm_0, msh_to_sm_1
# Create entity maps using the modified msh_to_sm maps
entity_maps = {submesh_0: msh_to_sm_0, submesh_1: msh_to_sm_1}
# Create integration measures
dx = ufl.Measure("dx", domain=msh, subdomain_data=ct)
dS = ufl.Measure("dS", domain=msh, subdomain_data=[(surf_ids["interface"], interface_entities)])
x = ufl.SpatialCoordinate(msh)
kappa = [1.0 + 0.1 * ufl.sin(ufl.pi * x[0]) * ufl.sin(ufl.pi * x[1]) for _ in range(2)]
# Penalty parameter (including harmonic mean on kappa on interface)
# TODO Add k dependency
gamma = 10 * 2 * kappa[0] * kappa[1] / (kappa[0] + kappa[1])
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
def jump_i(v, n):
return v[0]("+") * n("+") + v[1]("-") * n("-")
def grad_avg_i(v, kappa):
return kappa[1] / (kappa[0] + kappa[1]) * kappa[0] * grad(v[0]("+")) + kappa[0] / (
kappa[0] + kappa[1]
) * kappa[1] * grad(v[1]("-"))
a = (
inner(kappa[0] * grad(u[0]), grad(v[0])) * dx(vol_ids["omega_0"])
+ inner(kappa[1] * grad(u[1]), grad(v[1])) * dx(vol_ids["omega_1"])
- inner(grad_avg_i(u, kappa), jump_i(v, n)) * dS(surf_ids["interface"])
- inner(jump_i(u, n), grad_avg_i(v, kappa)) * dS(surf_ids["interface"])
+ gamma / avg(h) * inner(jump_i(u, n), jump_i(v, n)) * dS(surf_ids["interface"])
# Compile LHS forms
a = fem.form(ufl.extract_blocks(a), entity_maps=entity_maps)
# Define right-hand side forms
f = [-div(kap * grad(u_e(ufl.SpatialCoordinate(msh), module=ufl))) for kap in kappa]
# L = inner(f[0], v[0]) * dx(vol_ids["omega_0"]) + inner(f[1], v[1]) * dx(vol_ids["omega_1"])
G = 1.0 #
L = (inner(f[0], v[0]) * dx(vol_ids["omega_0"]) +
inner(f[1], v[1]) * dx(vol_ids["omega_1"]) +
0.5 * G * (v[0]("+") + v[1]("-")) * dS(surf_ids["interface"]))
# Compile RHS forms and set block structure
L = fem.form(ufl.extract_blocks(L), entity_maps=entity_maps)
# Apply boundary conditions. We require the DOFs of V_0 on the domain
# boundary. These can be identified via that facets of submesh_0 that
# lie on the domain boundary.
ft_sm_0 = convert_facet_tags(msh, submesh_0, sm_0_to_msh, ft)
bound_facets_sm_0 = ft_sm_0.find(surf_ids["boundary"])
submesh_0.topology.create_connectivity(fdim, tdim)
bound_dofs = fem.locate_dofs_topological(V_0, fdim, bound_facets_sm_0)
u_bc_0 = fem.Function(V_0)
u_bc_0.interpolate(u_e)
bc_0 = fem.dirichletbc(u_bc_0, bound_dofs)
bcs = [bc_0]
# Assemble linear system of equations
A = assemble_matrix_block(a, bcs=bcs)
A.assemble()
b = assemble_vector_block(L, a, bcs=bcs)
# Set-up solver
ksp = PETSc.KSP().create(msh.comm)
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("superlu_dist")
# Compute solution
x = A.createVecRight()
ksp.solve(b, x)
# Recover solution
u_0, u_1 = fem.Function(V_0), fem.Function(V_1)
offset = V_0.dofmap.index_map.size_local * V_0.dofmap.index_map_bs
u_0.x.array[:offset] = x.array_r[:offset]
u_1.x.array[: (len(x.array_r) - offset)] = x.array_r[offset:]
u_0.x.scatter_forward()
u_1.x.scatter_forward()
# Write solution to file
with io.VTXWriter(msh.comm, "u_0.bp", u_0, "BP4") as f:
f.write(0.0)
with io.VTXWriter(msh.comm, "u_1.bp", u_1, "BP4") as f:
f.write(0.0)
# Compute error in solution
e_L2_0 = norm_L2(msh.comm, u_0 - u_e(ufl.SpatialCoordinate(submesh_0), module=ufl))
e_L2_1 = norm_L2(msh.comm, u_1 - u_e(ufl.SpatialCoordinate(submesh_1), module=ufl))
e_L2 = np.sqrt(e_L2_0**2 + e_L2_1**2)
if msh.comm.rank == 0:
print(e_L2)
Lagrange multiplier example from github_link (I want to implement it solely using FEniCS)
# Primal, multiscale
from xii import *
from emi.utils import H1_norm, L2_norm, subdomain_interpolate
import emi.fem.common as common
from xii.assembler.trace_matrix import trace_mat_no_restrict
def setup_problem(n, mms, params):
'''Multi-dimensional primal formulation'''
base_mesh = UnitSquareMesh(mpi_comm_self(), *(n,) * 2)
# Marking
inside = ['(0.25-tol<x[0])', '(x[0] < 0.75+tol)', '(0.25-tol<x[1])', '(x[1] < 0.75+tol)']
inside = CompiledSubDomain(' && '.join(inside), tol=1E-10)
mesh_f = MeshFunction('size_t', base_mesh, base_mesh.topology().dim(), 0)
inside.mark(mesh_f, 1)
inner_mesh = SubMesh(base_mesh, mesh_f, 1) # Inside
outer_mesh = SubMesh(base_mesh, mesh_f, 0) # Ouside
interface_mesh = BoundaryMesh(inner_mesh, 'exterior')
# Spaces
V1 = FunctionSpace(outer_mesh, 'CG', 1)
V = FunctionSpace(inner_mesh, 'CG', 1)
Q = FunctionSpace(interface_mesh, 'CG', 1)
W = [V1, V, Q]
u1, u, p = map(TrialFunction, W)
v1, v, q = map(TestFunction, W)
Tu1, Tv1 = (Trace(f, interface_mesh) for f in (u1, v1))
Tu, Tv = (Trace(f, interface_mesh) for f in (u, v))
# Mark subdomains of the interface mesh (to get source terms therein)
subdomains = mms.subdomains[1] #
marking_f = MeshFunction('size_t', interface_mesh, interface_mesh.topology().dim(), 0)
[subd.mark(marking_f, i) for i, subd in enumerate(map(CompiledSubDomain, subdomains), 1)]
# The line integral
dx_ = Measure('dx', domain=interface_mesh, subdomain_data=marking_f)
kappa, epsilon = map(Constant, (params.kappa, params.eps))
a = block_form(W, 2)
a[0][0] = kappa * inner(grad(u1), grad(v1)) * dx
a[0][2] = inner(Tv1, p) * dx_
a[1][1] = inner(grad(u), grad(v)) * dx
a[1][2] = -inner(Tv, p) * dx_
a[2][0] = inner(Tu1, q) * dx_
a[2][1] = -inner(Tu, q) * dx_
a[2][2] = -epsilon * inner(p, q) * dx_
# Data
# Source for domains, outer boundary data, source for interface
f1, f, gBdry, gGamma, hGamma = mms.rhs
L = block_form(W, 1)
L[0] = inner(f1, v1) * dx
L[0] += sum(inner(hi, Tv1) * dx_(i) for i, hi in enumerate(hGamma, 1))
# Iface contribution
L[1] = inner(f, v) * dx
L[2] = sum(inner(gi, q) * dx_(i) for i, gi in enumerate(gGamma, 1))
A, b = map(ii_assemble, (a, L))
subdomains = mms.subdomains[0] #
facet_f = MeshFunction('size_t', outer_mesh, outer_mesh.topology().dim() - 1, 0)
[subd.mark(facet_f, i) for i, subd in enumerate(map(CompiledSubDomain, subdomains), 1)]
V1_bcs = [DirichletBC(V1, gi, facet_f, i) for i, gi in enumerate(gBdry, 1)]
bcs = [V1_bcs, [], []]
A, b = apply_bc(A, b, bcs)
return A, b, W
setup_mms = common.setup_mms
def setup_error_monitor(mms_data, params):
'''Compute function mapping numerical solution to errors'''
# Error of the solution ...
exact = mms_data.solution
subdomains = mms_data.subdomains[1]
def get_error(wh, subdomains=subdomains, exact=exact, mms=mms_data, params=params):
u1h, uh, ph = wh
sigma_exact, u_exact, p_exact, I_exact = exact
# Mutliplier error
mesh = ph.function_space().mesh()
Q = FunctionSpace(mesh, 'CG', 3)
cell_f = MeshFunction('size_t', mesh, mesh.topology().dim(), 0)
# Spaces on pieces
for tag, subd in enumerate(subdomains, 1):
CompiledSubDomain(subd, tol=1E-10).mark(cell_f, tag)
dx = Measure('dx', domain=mesh, subdomain_data=cell_f)
p, q = TrialFunction(Q), TestFunction(Q)
a = inner(p, q) * dx
L = sum(inner(I_exact_i, q) * dx(i) for i, I_exact_i in enumerate(I_exact, 1))
I_exact = Function(Q)
A, b = map(assemble, (a, L))
solve(A, I_exact.vector(), b)
V = uh.function_space()
mesh = V.mesh()
# Recover the transmembrane potential by postprocessing
mesh = V.mesh()
interface_mesh = BoundaryMesh(mesh, 'exterior')
V = FunctionSpace(interface_mesh, 'CG', 1)
Tu1 = PETScMatrix(trace_mat_no_restrict(u1h.function_space(), V)) * u1h.vector()
Tu = PETScMatrix(trace_mat_no_restrict(uh.function_space(), V)) * uh.vector()
vh = Function(V, Tu1 - Tu)
# Now using flux we have
Q = ph.function_space()
mesh = Q.mesh()
# Spaces on pieces
gGamma = mms.rhs[3]
L = inner(params.eps * ph, q) * dx + sum(inner(gi, q) * dx(i) for i, gi in enumerate(gGamma, 1))
vh_P = Function(Q) # Since we project
solve(A, vh_P.vector(), b)
vh_I = subdomain_interpolate(zip(gGamma, subdomains), Q)
vh_I.vector().axpy(params.eps, ph.vector())
# Simply by interpolation
return (sqrt(H1_norm(u_exact[0], u1h) ** 2 + H1_norm(u_exact[1], uh) ** 2),
L2_norm(p_exact, vh),
L2_norm(p_exact, vh_P),
L2_norm(p_exact, vh_I))
error_types = ('|u|_1', '|v|_0', '|v|_{0P}', '|v|_{0I}')
return get_error, error_types
# How is the problem parametrized
PARAMETERS = ('kappa', 'eps')
I’d be extremely grateful for any hints and assistance. Currently, I’m working on a semiconductor device simulation project based on FEniCS. Those who are interested are also welcome to communicate and cooperate with me.
Thank you again.
