Interior Neumann B.C. in BDM/DG mixed Poisson
I’m trying to solve the mixed Poisson in the subdomain. Firstly, I set up a reference case with submesh created with MeshView():
# Create mesh
mesh_all = UnitSquareMesh(MPI.comm_world, 20, 20, 'crossed')
class TopBottom(SubDomain):
        return near(x[1]*(1-x[1]), 0.0)
class Wall(SubDomain):
        return near((x[0]-0.2)*(0.8-x[0]), 0.0)
class Block(SubDomain):
        return between(x[0], (0.2, 0.8))
subdomains = MeshFunction("size_t",mesh_all, mesh_all.topology().dim())
subdomains.set_all(0)
Block().mark(subdomains, 1)
mesh = Mesh(MeshView.create(subdomains, 1))
boundaries = MeshFunction("size_t",mesh, mesh.topology().dim()-1)
boundaries.set_all(0)
TopBottom().mark(boundaries, 1)
Wall().mark(boundaries, 2)
ds = Measure('ds', domain = mesh, subdomain_data = boundaries)
# Define function spaces and mixed (product) space
BDM = FiniteElement("BDM", mesh.ufl_cell(),1)
DG = FiniteElement("DG", mesh.ufl_cell(), 0)
W = FunctionSpace(mesh, BDM * DG)
D = FunctionSpace(mesh, DG)
(sigma, u) = TrialFunctions(W)
(tau, v) = TestFunctions(W)
# Define source function
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", element=D.ufl_element())
# Define variational form
a = (dot(sigma, tau)+ div(tau)*u + div(sigma)*v)*dx
L = - f*v*dx + Constant(1.0)*dot(tau, n)*ds(2)
# Define function G such that G \cdot n = g
class BoundarySource(UserExpression):
    def __init__(self, mesh, **kwargs):
        self.mesh = mesh
        super().__init__(**kwargs)
    def eval_cell(self, values, x, ufc_cell):
        cell = Cell(self.mesh, ufc_cell.index)
        n = cell.normal(ufc_cell.local_facet)
        g = sin(5*x[0])
        values[0] = g*n[0]
        values[1] = g*n[1]
    def value_shape(self):
        return (2,)
G = BoundarySource(mesh, degree=2)
# Define essential boundary
def boundary(x):
    return x[1] < DOLFIN_EPS or x[1] > 1.0 - DOLFIN_EPS
bc = DirichletBC(W.sub(0), G, boundaries, 1)
# Compute solution
w = Function(W)
solve(a == L, w, bc)
(sigma, u) = w.split(True)
print("u_max =", u.vector().max(), 'u_min =', u.vector().min())
plot(u)
Here the Dirichlet B.C. u=1.0 is impelemented weakly by adding the term Constant(1.0)*dot(tau, n)*ds(2) on the RHS.
The results give
u_max = 1.1637949250619102 u_min = 0.991970223504017.
Then I switch to solve the problem on the subdomain and appyling A.ident_zeros() to the domain out of interest, and my question is how to apply the Neumann B.C. above now. Since the functional u is defined on element-wise constent space DG0, the facet integral after the integrate by parts reads \sum _{e \in \mathcal{F}_i} \int_{e} [[u \tau]]ds, where \mathcal{F}_i is the set of interior facets. I need your help to convert the interior B.C. u=1.0 into the interior facet integral, below is the WME that i tried but failed to match the refernce case above with submesh
# Create mesh
mesh = UnitSquareMesh(MPI.comm_world, 20, 20, 'crossed')
subdomains = MeshFunction("size_t",mesh, mesh.topology().dim())
dx = Measure('dx', domain = mesh, subdomain_data = subdomains)
dS = Measure('dS', domain = mesh, subdomain_data = boundaries)
a = (dot(sigma, tau)+ div(tau)*u + div(sigma)*v)*dx(1)
L = - f*v*dx(1) + Constant(1.0)*jump(tau, n)*dS(2)
        self.mesh = mesh
        g = sin(5*x[0])
        values[0] = g*n[0]
        values[1] = g*n[1]
        return (2,)
def boundary(x):
A, b = assemble_system(a, L, keep_diagonal=True)
bc.apply(A, b)
A.ident_zeros()
# Compute solution
w = Function(W)
solve(A, w.vector(), b)
plot(u)
with results
u_max = 0.15264490930389638 u_min = -0.005560735505760749.
Any help will be really appreciated!
Hello everyone,
unfortunately after a month, I`m still struggling with this problem, anyone has some idea? Many thanks!
Looks like you already know about the principle of Mixed function spaces. Make sure you’ve checked against examples at https://bitbucket.org/fenics-project/dolfin/src/master/python/demo/documented/
e.g. https://bitbucket.org/fenics-project/dolfin/src/master/python/demo/documented/mixed-poisson/demo_mixed-poisson.py.rst
I guess you might handle your inner boundary condition with a lagrange multiplier.
Dokken gives more references (published papers) to Cécile Daversin-Catty’s work on mixed spaces at Prescribe discontinuity on internal boundary and also mentions Nitsche’s method as another approach (for discontinuous systems).
