Dear @dokken,
I appreciate your quick help.
I tried applying a vector valued BC on the dofs (hope that is the correct way).
The error trace throws a type error now.
from dolfinx import fem, mesh, plot
import pyvista as pv
domain = mesh.create_unit_square(comm=MPI.COMM_WORLD,
nx=32, ny=32,
cell_type=mesh.CellType.triangle)
P1 = ufl.FiniteElement('BDM', domain.ufl_cell(), 1)
P2 = ufl.FiniteElement('DG', domain.ufl_cell(), 0)
element = ufl.MixedElement([P1, P2])
V = fem.FunctionSpace(domain, element)
# test and trial functions
tau, v = ufl.TestFunctions(V)
sigma, u = ufl.TrialFunctions(V)
# function determining if a node is on the tray top
def on_top_boundary(x):
return np.logical_or(np.isclose(x[0], 0),
np.isclose(x[0], 1))
V0, submap = V.sub(0).collapse()
# determine boundary DOFs
boundary_facets = mesh.locate_entities_boundary(domain, domain.topology.dim-1, on_top_boundary)
boundary_dofs = fem.locate_dofs_topological((V.sub(0), V0), domain.topology.dim-1, boundary_facets)
# apply Dirichlet (vector type) on identified dofs
u_zero = np.array((0,) * domain.geometry.dim, dtype=ScalarType) # vector type
bc = fem.dirichletbc(value=u_zero, dofs=boundary_dofs, V=V.sub(0)) # V.sub(0): Corresponds to BDM element
# apply Neumann BC
x = ufl.SpatialCoordinate(domain=domain)
f = 10.0 * ufl.exp(-((x[0] - 0.5)**2 + (x[1] - 0.5)**2) / 0.02)
g = ufl.sin(5 * x[0])
a = (ufl.dot(sigma, tau) + ufl.div(tau) * u + ufl.div(sigma) * v) * ufl.dx
L = -ufl.inner(f, v) * ufl.dx + ufl.inner(g, v) * ufl.ds
# Solve
problem = LinearProblem(a, L, [bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
Error occurs at line starting with “bc = fem.dirichletbc(…”
File "/Users/anil/Apps/anaconda3/envs/fenics-env/lib/python3.8/site-packages/dolfinx/fem/bcs.py", line 125, in __init__
super().__init__(_value, dofs, V) # type: ignore
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
1. dolfinx.cpp.fem.DirichletBC_float64(g: numpy.ndarray[numpy.float64], dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
2. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Constant<double>, dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace)
3. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: numpy.ndarray[numpy.int32])
4. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double>, dofs: List[numpy.ndarray[numpy.int32][2]], V: dolfinx::fem::FunctionSpace)
Invoked with: array([0., 0.]), [array([ 0, 1, 17, 18, 40, 41, 71, 72, 110, 111, 157,
158, 212, 213, 275, 276, 346, 347, 425, 426, 512, 513,
607, 608, 710, 711, 821, 822, 940, 941, 1067, 1068, 1202,
1203, 1345, 1346, 1496, 1497, 1655, 1656, 1822, 1823, 1997, 1998,
2180, 2181, 2371, 2372, 2570, 2571, 2777, 2778, 2992, 2993, 3215,
3216, 3446, 3447, 3685, 3686, 3932, 3933, 4187, 4188, 4194, 4195,
4447, 4448, 4692, 4693, 4929, 4930, 5158, 5159, 5379, 5380, 5592,
5593, 5797, 5798, 5994, 5995, 6183, 6184, 6364, 6365, 6537, 6538,
6702, 6703, 6859, 6860, 7008, 7009, 7149, 7150, 7282, 7283, 7407,
7408, 7524, 7525, 7633, 7634, 7734, 7735, 7827, 7828, 7912, 7913,
7989, 7990, 8058, 8059, 8119, 8120, 8172, 8173, 8217, 8218, 8254,
8255, 8283, 8284, 8304, 8305, 8317, 8318], dtype=int32), array([ 0, 1, 14, 15, 32, 33, 56, 57, 86, 87, 122,
123, 164, 165, 212, 213, 266, 267, 326, 327, 392, 393,
464, 465, 542, 543, 626, 627, 716, 717, 812, 813, 914,
915, 1022, 1023, 1136, 1137, 1256, 1257, 1382, 1383, 1514, 1515,
1652, 1653, 1796, 1797, 1946, 1947, 2102, 2103, 2264, 2265, 2432,
2433, 2606, 2607, 2786, 2787, 2972, 2973, 3164, 3165, 3170, 3171,
3360, 3361, 3544, 3545, 3722, 3723, 3894, 3895, 4060, 4061, 4220,
4221, 4374, 4375, 4522, 4523, 4664, 4665, 4800, 4801, 4930, 4931,
5054, 5055, 5172, 5173, 5284, 5285, 5390, 5391, 5490, 5491, 5584,
5585, 5672, 5673, 5754, 5755, 5830, 5831, 5900, 5901, 5964, 5965,
6022, 6023, 6074, 6075, 6120, 6121, 6160, 6161, 6194, 6195, 6222,
6223, 6244, 6245, 6260, 6261, 6270, 6271], dtype=int32)], FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Brezzi-Douglas-Marini', triangle, 1))
File "/Users/anil/.local/lib/python3.8/site-packages/IPython/core/interactiveshell.py", line 3378, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File "<ipython-input-2-ee23d4688714>", line 1, in <module>
runfile('/Users/anil/Py/FEM/mixed_poisson.py', wdir='/Users/anil/Py/FEM')
File "/Applications/PyCharm CE.app/Contents/plugins/python-ce/helpers/pydev/_pydev_bundle/pydev_umd.py", line 198, in runfile
pydev_imports.execfile(filename, global_vars, local_vars) # execute the script
File "/Applications/PyCharm CE.app/Contents/plugins/python-ce/helpers/pydev/_pydev_imps/_pydev_execfile.py", line 18, in execfile
exec(compile(contents+"\n", file, 'exec'), glob, loc)
File "/Users/anil/Py/FEM/mixed_poisson.py", line 99, in <module>
File "/Users/anil/Apps/anaconda3/envs/fenics-env/lib/python3.8/site-packages/dolfinx/fem/bcs.py", line 182, in dirichletbc
return formcls(value, dofs, V)
File "/Users/anil/Apps/anaconda3/envs/fenics-env/lib/python3.8/site-packages/dolfinx/fem/bcs.py", line 127, in __init__
super().__init__(_value, dofs, V._cpp_object) # type: ignore
6223, 6244, 6245, 6260, 6261, 6270, 6271], dtype=int32)], <dolfinx.cpp.fem.FunctionSpace object at 0x7ff3462c9870>
