Internal vector arrangement and numpy automatic broadcasting
I wanted to interpolate an expression of the form:
f\left(\mathbf{x}\right) = \left\Vert \mathbf{x} - \mathbf{a} \right\Vert
which meant evaluating
\left\Vert\mathbf{x}_i-\mathbf{a}\right\Vert,\quad i=1,2,\dots,N_\mathrm{points}
Me being used to numpy automatic broadcasting, wrote:
f.interpolate( lambda x : np.linalg.norm(x - a))
where a is a 3 elements array.
However that does not work, as x is a 3 \times N_\mathrm{points} array, and numpy does automatic broadcasting from the right.
I can easily fix it by calling x.transpose() inside the expression, however the code is less clean. (my actual expression is a little bit more cumbersome)
Is there a reason for choosing the d \times N_\mathrm{points} arrangement instead of the transposed one?
You can give numpy.linalg.norm the axis to evaluate over: numpy.linalg.norm — NumPy v2.1 Manual
See the following example in the docs:
c = np.array([[ 1, 2, 3],
              [-1, 1, 4]])
LA.norm(c, axis=0)
array([ 1.41421356,  2.23606798,  5.        ])
LA.norm(c, axis=1)
array([ 3.74165739,  4.24264069])
LA.norm(c, ord=1, axis=1)
array([ 6.,  6.])
The reason for choosing this is that it allows for vectorized operations in Python, rather than looping over each point, which would be inefficient. (It also gives nice memory alignment).
Following up, the reason for shape=(3, npoints) is that it allows, for example, f = y \cos(x) to be interpolated using
f.interpolate(lambda x : x[1] * np.cos(x[0]))
nice! dokken answer was already convincing, but this one is also beautiful
