Interpolating numerical values (2D numpy array) over a mesh
I am trying to interpolate a 2D-vector valued numpy array over a mesh. I have the numerical values of 2D-vectors at every node of the mesh as a numpy array. Now I would like to interpolate this numerical vector valued function over the mesh. Could you please let know how I can do that? Below I post my code.
### Linear elasticity example FEniCSx tutorial ###
###         importing packages and defining parameters starts      ###
from __future__ import annotations
from pathlib import Path
from typing import Union
import dolfinx.fem as fem
import scipy.sparse.linalg
from dolfinx.common import Timer, TimingType, list_timings
from dolfinx.mesh import create_unit_square, locate_entities_boundary
from ufl import (SpatialCoordinate, TestFunction, TrialFunction, as_vector, dx,
                 exp, grad, inner, pi, sin, cos)
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem, MultiPointConstraint
import pandas as pd
import pyvista
from dolfinx import mesh, fem, plot, io
default_scalar_type = PETSc.ScalarType
### importing the subroutine to give analytical solution ###
import stokesTheoryForL2
from stokesTheoryForL2 import anasolmain
from stokesTheoryForL2 import correctedsol
#L = 1
#W = 0.2
mu = 0.001 ### 0.001, 1
#rho = 1
#delta = W / L
#gamma = 0.4 * delta**2
#beta = 1.25
#lambda_ = beta
lambda_ = 1
print("Value of mu: {}, and lambda: {}".format(mu,lambda_))
#g = gamma
###      importing packages and defining parameters ends           ###
###                          defining mesh starts                  ###
# domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
#                          [20, 6, 6], cell_type=mesh.CellType.hexahedron)
# nx, ny = 50, 50
# domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
#                                [nx, ny], mesh.CellType.triangle)
# Get PETSc int and scalar types
complex_mode = True if np.dtype(default_scalar_type).kind == 'c' else False
# Create mesh and finite element
NX = 50
NY = 50
mesh = create_unit_square(MPI.COMM_WORLD, NX, NY)
#V = fem.functionspace(mesh, ("Lagrange", 1, (mesh.geometry.dim, )))
V = fem.functionspace(mesh, ("Lagrange", 2, (mesh.geometry.dim, )))
tol = 250 * np.finfo(default_scalar_type).resolution
# Listing space points ###
dof_coordinates = V.tabulate_dof_coordinates()
#print(dof_coordinates[:2,:2])
df = pd.DataFrame(dof_coordinates)
df.to_csv('outdata/planenodesPeriodic.csv', index = None, header=False)
###                     defining mesh ends                         ###
###                boundary conditions starts                      ###
bcs = []
def periodic_boundary(x):
    #print('From periodic_boundary0 function, length of x: ', len(x))
    print('From periodic_boundary0 function, shape of x: ', x.shape)
    #print(np.isclose(x[0], 1, atol=tol))
    boollist = []
    for i in range(x.shape[1]):
        if np.isclose(x[0,i], 0, atol=tol) or np.isclose(x[1,i], 0, atol=tol):
            boollist = boollist + [1]
            boollist = boollist + [0]
    boollist = np.array(boollist, dtype='bool')
    return boollist
def mapping(x):
    left_constraint = x[1] > 1e-14
    #mapped_values = np.zeros((2, x.shape[1]))
    mapped_values = np.zeros_like(x)
    mapped_values[0] = left_constraint + x[0]
    mapped_values[1] = np.invert(left_constraint) + x[1]
    return mapped_values
with Timer("~PERIODIC: Initialize MPC"):
    mpc = MultiPointConstraint(V)
    mpc.create_periodic_constraint_geometrical(V, periodic_boundary, mapping, bcs)
    #mpc.create_periodic_constraint_geometrical(V, periodic_boundary0, periodic_relation0, bcs)
    #mpc.create_periodic_constraint_geometrical(V, periodic_boundary1, periodic_relation1, bcs)
    mpc.finalize()
### traction free BC starts on other faces ###
T = fem.Constant(mesh, default_scalar_type((0, 0)))
### traction free BC ends on other faces ###
### defining surface integral over the boundary starts ###
ds = ufl.Measure("ds", domain=mesh)
### defining surface integral over the boundary ends ###
###                  boundary conditions end                       ###
###              variational formulation starts                    ###
    return ufl.sym(ufl.grad(u))  # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
x = SpatialCoordinate(mesh)
#print('Printing x', x)
#f = as_vector((sin(2 * pi * x[0]), 0))
f = as_vector((1000 * cos(2 * pi * x[0] + 2 * pi * x[1]), 1000 * cos(2 * pi * x[0] + 2 * pi * x[1])))
#f = fem.Constant(mesh, default_scalar_type((0, 0)))
#f = as_vector((x[0] * sin(5.0 * pi * x[1]) + 1.0 * exp(-(dx_ * dx_ + dy_ * dy_) / 0.02), 0.3 * x[1]))
###              variational formulation ends                      ###
###           solving variational problem starts                   ###
# Setup MPC system
with Timer("~PERIODIC: Initialize varitional problem"):
    problem = LinearProblem(a, L, mpc, bcs=bcs)
solver = problem.solver
# Give PETSc solver options a unique prefix
solver_prefix = "dolfinx_mpc_solve_{}".format(id(solver))
solver.setOptionsPrefix(solver_prefix)
petsc_options: dict[str, Union[str, int, float]]
if complex_mode or default_scalar_type == np.float32:
    petsc_options = {"ksp_type": "preonly", "pc_type": "lu"}
    petsc_options = {"ksp_type": "cg", "ksp_rtol": 1e-6, "pc_type": "hypre", "pc_hypre_type": "boomeramg",
                     "pc_hypre_boomeramg_max_iter": 1, "pc_hypre_boomeramg_cycle_type": "v"  # ,
                     # "pc_hypre_boomeramg_print_statistics": 1
# Set PETSc options
opts = PETSc.Options()  # type: ignore
opts.prefixPush(solver_prefix)
if petsc_options is not None:
    for k, v in petsc_options.items():
        opts[k] = v
opts.prefixPop()
solver.setFromOptions()
with Timer("~PERIODIC: Assemble and solve MPC problem"):
    uh = problem.solve()
    # solver.view()
    it = solver.getIterationNumber()
    print("Constrained solver iterations {0:d}".format(it))
###             solving variational problem ends                   ###
###                  L^2 error computation starts                  ###
usol = uh.x.array
numpoints = int(len(usol)/2)
usol = np.reshape(usol, (numpoints,2))
df = pd.DataFrame(usol)
df.to_csv('outdata/planedisplacementsPeriodicNumerical.csv', index = None, header=False)
### interpolating the analytical solution over mesh using basis functions ###
V2 = fem.functionspace(mesh, ("Lagrange", 2, (mesh.geometry.dim, )))
uex = fem.Function(V2)
#uex.interpolate(lambda x: anasolmain(x[0],x[1]))
uex.interpolate(anasolmain)
### reshaping the 2D-planer analytical solution ###
#print(uex.x.array)
usolAna = uex.x.array
numpointsAna = int(len(usolAna)/2)
usolAna = np.reshape(usolAna, (numpointsAna,2))
#print(usol.tolist())
### saving the analytical solution into a file ###
df = pd.DataFrame(usolAna)
df.to_csv('outdata/planedisplacementsPeriodicAnaFenicsx.csv', index = None, header=False)
L2_error = fem.form(ufl.inner(uh - uex, uh - uex) * ufl.dx)
error_local = fem.assemble_scalar(L2_error)
error_L2 = np.sqrt(mesh.comm.allreduce(error_local, op=MPI.SUM))
#print("L^2-norm of the error for {}x{} grid is: {}".format(NX, NY, error_L2))
L2_error = fem.form(uh[0] * ufl.dx)
error_local_uh0 = fem.assemble_scalar(L2_error)
#print("Integral of the first component of numerical solution: ", error_local_uh0)
L2_error = fem.form(uh[1] * ufl.dx)
error_local_uh1 = fem.assemble_scalar(L2_error)
#print("Integral of the second component of numerical solution: ", error_local_uh1)
L2_error = fem.form(uex[0] * ufl.dx)
error_local_uex0 = fem.assemble_scalar(L2_error)
#print("Integral of the first component of analytical solution: ", error_local_uex0)
L2_error = fem.form(uex[1] * ufl.dx)
error_local_uex1 = fem.assemble_scalar(L2_error)
#print("Integral of the second component of analytical solution: ", error_local_uex1)
# ###                  L^2 error computation ends                    ###
usolCorrected = np.zeros((numpoints,2))
### Subtracting the constant error from the numerical result
usolCorrected[:,0] = usol[:,0] - (error_local_uh0 - error_local_uex0)
usolCorrected[:,1] = usol[:,1] - (error_local_uh1 - error_local_uex1)
print("Printing corrected solution from outside any function len(usolCorrected[:,0])", len(usolCorrected[:,0]))
print("Printing corrected solution from outside any function", np.array([usolCorrected[:,0],usolCorrected[:,1]]))
df = pd.DataFrame(usolCorrected)
df.to_csv('outdata/planedisplacementsPeriodicCorrected.csv', index = None, header=False)
###       Interpolating corrdected numerical solution over mesh using basis functions        ###
def usolcorrectSupply(x):
    x1 = x[0]
    x2 = x[1]
    v1anaCorrected = usolCorrected[:,0] #np.ones(len(x1)) #x1 #usolCorrected[:,0] #utest[:,0]
    v2anaCorrected = usolCorrected[:,1] #np.cos(2 * np.pi * x2) #x2 #usolCorrected[:,1] #utest[:,1]
    print("Length of v1anaCorrected (number of x[0] coordinates): ", len(x1))
    print("Printing corrected sol from inside of usolcorrectSupply function", np.array([v1anaCorrected, v2anaCorrected]))
    return np.array([v1anaCorrected, v2anaCorrected])
usolCorrectedMesh = fem.Function(V2)
usolCorrectedMesh.interpolate(usolcorrectSupply)
#usolCorrectedMesh.interpolate(anasolmain)
#usolCorrectedMesh.interpolate(correctedsol)
usolCorrectedPrint = usolCorrectedMesh.x.array
#print("Testing usolcurrectSupply function", usolCorrectedPrint)
numpoints = int(len(usolCorrectedPrint)/2)
usolCorrectedPrint = np.reshape(usolCorrectedPrint, (numpoints,2))
print("Printing interpolated corrected sol", np.array([usolCorrectedPrint[:,0],usolCorrectedPrint[:,1]]))
df = pd.DataFrame(usolCorrectedPrint)
#df = pd.DataFrame(usolCorrected)
df.to_csv('outdata/planedisplacementsPeriodicCorrectedMesh.csv', index = None, header=False)
L2_error = fem.form(usolCorrectedMesh[0] * ufl.dx)
error_local_ucorrect0 = fem.assemble_scalar(L2_error)
# error_L2 = np.sqrt(mesh.comm.allreduce(error_local, op=MPI.SUM))
print("Integral of the first component of corrected solution: ", error_local_ucorrect0)
L2_error = fem.form(usolCorrectedMesh[1] * ufl.dx)
error_local_ucorrect1 = fem.assemble_scalar(L2_error)
print("Integral of the second component of corrected solution: ", error_local_ucorrect1)
print("Number of nodes {}".format(len(dof_coordinates)))
print("Number of sol points {}".format(len(usol)))
In the above code I am trying to interpolate the array “usolCorrected” (which is a numpy array of 2D-vectors evaluated at every node of the mesh) over the mesh.
Thanks.
You typically want to search the forum before asking a question. Interpolating a function defined from an array is quite a common question, even though probably the case of a vector field is less common.
The very first search result I found is How to interpolate numpy array into VectorFunctionSpace? : it boils down to creating a LinearNDInterpolator from scipy. I won’t be searching further results for you.
Furthermore, taking the risk of sounding rude, I won’t be reading your code either. That is far from a minimal example: we don’t need to see your linear elasticity problem, which even uses dolfinx_mpc, for your to formulate the question “how can I interpolate a 2D field defined in numpy to a dolfinx Function”? Just take a built in mesh, prepare mock numpy data, and then ask how to interpolate those in a dolfinx Function.
This is far from a general example representative of your question:
as the code involves dolfinx_mpc and solving a problem.
It is unclear why you need this for the problem at hand.
You should also consider the following:
and explain how your relation with the mesh nodes is assumed.
