I’m attempting to incorporate the external library CoolProp to calculate fluid properties to be used in a finite element Navier Stokes algorithm. I’m doing this in a pretty simplified manner, see code below. It seems that when I try to interpolate the value to create a function object, the values are no longer the same. Not sure what’s going wrong exactly, if someone could point out my error that would be greatly appreciated.
from CoolProp.CoolProp import PropsSI
mesh = UnitSquareMesh(100, 100)
Q = FunctionSpace(mesh, "CG", 1)
class ThermalProperty(UserExpression):
ThermalProperty(property, a, A, b, B)
property = string for property sought for
a = string for input state variable
A = FEniCS function, input state variable function
b = string for second input state variable
B = FEniCS function for second input state variable
def __init__(self, property, a, A, b, B, **kwargs):
super().__init__(**kwargs)
self.property = property
self.a = a
self.b = b
self.A = A
self.B = B
self.list = []
def eval(self, value, x):
value = PropsSI(self.property, self.a, self.A(x),
self.b, self.B(x), "CarbonDioxide")
self.list.append(value)
return
def value_shape(self):
return ()
temp_0 = Expression("320", degree = 0)
T_n = interpolate(temp_0, Q)
p_n = interpolate(Constant(52e6), Q)
rho_n = interpolate(Constant(978.15), Q)
C_V = ThermalProperty("CPMASS", "DMASS", rho_n, "T", T_n)
print(interpolate(C_V, Q).vector().get_local())
print(np.array(C_V.list))
[2.0895309e-316 2.0895309e-316 2.0895309e-316 … 2.0895309e-316
2.0895309e-316 2.0895309e-316]
[1741.70968994 1741.70968994 1741.70968994 … 1741.70968994 1741.70968994
1741.70968994]
