Interpolating step functions in fenicsx
Hi all,
I’m trying to interpolate a step function as part of some fenicsx code. When I do, I get an error, so I’m clearly approaching this the wrong way.
I’m giving a MWE below: can you tell me what’s wrong?
Thanks in advance!
import dolfinx as d
msh = d.mesh.create_interval( comm=MPI.COMM_WORLD,
                                    nx=100, points=(0, 10) )
Pn = ufl.FiniteElement( 'CG', msh.ufl_cell(), 4 )
S = d.fem.FunctionSpace( msh, Pn )
f = d.fem.Function(S)
def profile( r, rho0, r_step ):
    if r < r_step:
        return rho0
        return 0.
# some calculations to determine rho0 and r_step...
# here I assign some random values, just to make a MWE
prof = lambda r : profile( r[0], 10, 1 )
f.interpolate(prof)
The error I get is:
TypeError                                 Traceback (most recent call last)
File ~/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/function.py:370, in Function.interpolate(self, u, cells)
    368 try:
    369     # u is a Function or Expression (or pointer to one)
--> 370     _interpolate(u, cells)
    371 except TypeError:
    372     # u is callable
File ~/anaconda3/envs/fenicsx/lib/python3.10/functools.py:889, in singledispatch.<locals>.wrapper(*args, **kw)
    886     raise TypeError(f'{funcname} requires at least '
    887                     '1 positional argument')
--> 889 return dispatch(args[0].__class__)(*args, **kw)
File ~/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/function.py:346, in Function.interpolate.<locals>._interpolate(u, cells)
    345 """Interpolate a cpp.fem.Function"""
--> 346 self._cpp_object.interpolate(u, cells)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. (self: dolfinx.cpp.fem.Function_float64, f: numpy.ndarray[numpy.float64], cells: numpy.ndarray[numpy.int32]) -> None
    2. (self: dolfinx.cpp.fem.Function_float64, u: dolfinx.cpp.fem.Function_float64, cells: numpy.ndarray[numpy.int32]) -> None
    3. (self: dolfinx.cpp.fem.Function_float64, expr: dolfinx::fem::Expression<double>, cells: numpy.ndarray[numpy.int32]) -> None
Invoked with: <dolfinx.cpp.fem.Function_float64 object at 0x1665b4bb0>, <function <lambda> at 0x15adb0790>, array([ 0,  1,  2,  3,  4,  5,  6,  7,  8,  9, 10, 11, 12, 13, 14, 15, 16,
       17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33,
       34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50,
       51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67,
       68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84,
       85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99],
      dtype=int32)
ValueError                                Traceback (most recent call last)
/path_to_file/test.ipynb Cell 13 line 2
     23 # some calculations to determine rho0 and r_step...
     24 # here I assign some random values, just to make a MWE
     26 prof = lambda r : profile( r[0], 10, 1 )
---> 28 f.interpolate(prof)
File ~/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/function.py:377, in Function.interpolate(self, u, cells)
    373 assert callable(u)
    374 x = _cpp.fem.interpolation_coords(
    375     self._V.element, self._V.mesh, cells)
    376 self._cpp_object.interpolate(
--> 377     np.asarray(u(x), dtype=self.dtype), cells)
     21         return 0.
---> 26 prof = lambda r : profile( r[0], 10, 1 )
/path_to_file/test.ipynb Cell 13 line 1
     17 def profile( r, rho0, r_step ):
---> 18     if r < r_step:
     19         return rho0
     20     else:
ValueError: The truth value of an array with more than one element is ambiguous. Use a.any() or a.all()
The interpolation function in DOLFINx is vectorized. It means that it takes in multiple points at once, i.e. the input r is a (num_points, 3) dimensional array. Thus, you would either have to vectorize your code, i.e.
    return rho0* (r < r_step)
which for an simple a:
 a = np.arange(10)
profile(a, 0.1, 3)
returns
Out[10]: array([0.1, 0.1, 0.1, 0. , 0. , 0. , 0. , 0. , 0. , 0. ])
Thanks! I had sensed the function was being vectorised, and I had tried, naïvely, with f.interpolate( np.vectorize(prof) ), but it hadn’t worked. That makes sense. Thank you!
