Hi, I would like to check the convergence rate of the Nedelec edge element approximating a singular field on an L-shape domain \Omega=(-1,1)\times(-1,1)-[0,1)\times(-1,0]. The exact function {\bf{b}}_e=\nabla \left( r^{4/3} \sin(\frac{4\theta}{3})\right)=[\frac{4}{3} r^{1/3}\sin(\frac{\theta}{3}),\frac{4}{3} r^{1/3}\cos({\frac{\theta}{3}})]^T is defined in polar coordinate, which is curl-free.
However, when I check the Hcurl0 error between this {\bf{b}}_e and its interpolation in FEniCS, the spatial convergence rate is around 0.333. I do not why Hcurl0 error is so large. Below is an example. Thanks.
from mshr import *nx_list = [10,20,40]
domain = Rectangle(Point(-1.0,-1.0), Point(1.0,1.0)) - Rectangle(Point(0.0,-1.0), Point(1,0))
mesh = generate_mesh(domain,nx_list[0])rr = Expression("sqrt(x[0]x[0]+x[1]x[1])",degree=2)
theta = Expression('x[1] >= 0 ? atan2(x[1], x[0]):atan2(x[1], x[0]) + 2pi’, degree=2)
b_e = Expression(('4.0/3.0pow(r,1.0/3.0)sin(t/3.0)','4.0/3.0pow(r,1.0/3.0)*cos(t/3.0)'),
r=rr, t=theta, degree = 5)
Magnetic1 = FiniteElement(“N1curl”, mesh.ufl_cell(), 1)for nx in nx_list:
Nedelec_l_space = FunctionSpace(mesh, Magnetic1) b_h = interpolate(b_e,Nedelec_l_space) print(errornorm(b_e, b_h, 'L2', degree_rise=2),errornorm(b_e, b_h, 'Hcurl0', degree_rise=2)) mesh = refine(mesh)
