I already posted before on this forum about interpolation issues with N1curl elements. I received advice that worked well for homogeneous fields, but I was not able to get the same precision with dipolar fields.
Using the same mesh, I have interpolated a homogeneous potential field and the associated magnetic field to a very satisfactory precision using both N1curl and Lagrange elements.
When interpolating homogeneous field potential in N1curl
L2 norm of A_nedelec_DG - A_DG = 3.21e-17
L2 norm of B_nedelec_DG - B_DG = 3.21e-17
When interpolating homogeneous field potential in Lagrange
L2 norm of A_lagrange_DG - A_DG = 8.13e-19
L2 norm of B_lagrange_DG - B_DG = 8.13e-19
However, the same method did not work for a dipolar field.
When interpolating dipole potential in N1curl
L2 norm of A_nedelec_DG - A_DG = 1.06e-02
L2 norm of B_nedelec_DG - B_DG = 1.06e-02
When interpolating dipole potential in Lagrange
L2 norm of A_lagrange_DG - A_DG = 1.22e-17
L2 norm of B_lagrange_DG - B_DG = 1.22e-17
Is there anything I am missing regarding N1curl interpolation ? Why is interpolation so bad for the dipole field/potential ?
I have put the errors I get with homogenous field potentials.
Here is a (fairly long) MWE exploring my interpolation process, for clarity :
A_DG : Potential interpolated from numpy, into DG
A_nedelec_DG : Potential interpolated from numpy, into N1curl, into DG
A_lagrange_DG : Potential interpolated from numpy, into Lagrange, into DG
B_DG : Field interpolated from numpy, into DG
B_nedelec_DG : Field interpolated from numpy, into N1curl, into DG
B_lagrange_DG : Field interpolated from numpy, into Lagrange, into DG
curl_A_nedelec_DG: curl of the potential, interpolated from numpy, into N1curl, into DG
"""MWE highlighting my issues with Nédélec interpolation."""
import pandas as pd
from dolfinx.fem import FunctionSpace, VectorFunctionSpace, Function
VACUUM_PERMEABILITY = 4 * np.pi * 1e-7
DIPOLE_MU = np.array([0, 0, 1])
DIPOLE_POSITION = np.array([0, 0, 0])
def generate_mesh():
"""Generate empty domain."""
bkg_tag = 0
sphere_tag = 1
# Mesh definition
gmsh.option.setNumber("General.Terminal", 0)
gmsh.model.add("MWE")
gmsh.model.occ.addSphere(0, 0, 0, 1, tag=bkg_tag)
gmsh.model.occ.addSphere(0, 0, 0, 1e-1, tag=sphere_tag)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(3, [1], tag=bkg_tag)
gmsh.model.addPhysicalGroup(3, [2], tag=sphere_tag)
gmsh.option.setNumber("Mesh.Algorithm", 2)
gmsh.model.mesh.generate(3)
gmsh.model.mesh.refine()
# gmsh.fltk.run()
mesh, _, _ = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=3)
gmsh.finalize()
return mesh
def numpy_potential():
"""Get numpy function for dipolar potential field."""
def background_potential(x):
"""Return dipolar potential."""
temp_mu_dipole = np.einsum("n,d->dn", np.ones(x.shape[1]), DIPOLE_MU)
temp_position = np.einsum("n,d->dn", np.ones(x.shape[1]), DIPOLE_POSITION)
r_dipole = x - temp_position
norm_r_dipole = np.linalg.norm(r_dipole, axis=0)
produit_vect = np.cross(temp_mu_dipole, r_dipole, axis=0)
# Potential expression obtained from https://en.wikipedia.org/wiki/Magnetic_dipole
bkg_potential = (
VACUUM_PERMEABILITY * produit_vect / (4 * np.pi * norm_r_dipole**3)
return bkg_potential
return background_potential
def numpy_to_nedelec(mesh, numpy_potential):
"""Nedelec expression from numpy."""
# V = FunctionSpace(mesh, ("N1curl", 1))
V = VectorFunctionSpace(mesh, ("Lagrange", 1))
A_nedelec = Function(V)
A_nedelec.interpolate(numpy_potential())
A_nedelec.x.scatter_forward()
return A_nedelec
def numpy_to_DG(mesh, numpy_potential):
"""DG expression from numpy."""
V_DG = VectorFunctionSpace(mesh, ("DG", 1))
A_DG = Function(V_DG)
A_DG.interpolate(numpy_potential())
A_DG.x.scatter_forward()
return A_DG, V_DG
mesh = generate_mesh()
background_potential = numpy_potential()
A_nedelec = numpy_to_nedelec(mesh, numpy_potential)
A_DG, V_DG = numpy_to_DG(mesh, numpy_potential)
comm = V_DG.mesh.comm
A_error = Function(V_DG)
A_nedelec_DG = Function(V_DG)
A_nedelec_DG.interpolate(A_nedelec)
A_error.x.array[:] = A_nedelec_DG.x.array - A_DG.x.array
error_L2 = dolfinx.fem.form(ufl.inner(A_error, A_error) * ufl.dx)
print(
f"L2 norm of A_nedelec_DG - A_DG = {np.real(np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error_L2), MPI.SUM))):.2e}"
curl_A_DG = Function(V_DG)
curl_A_DG.interpolate(
dolfinx.fem.Expression(
ufl.as_vector(
A_DG.sub(2).dx(1) - A_DG.sub(1).dx(2), # Dz/Dy - Dy/Dz
A_DG.sub(0).dx(2) - A_DG.sub(2).dx(0), # Dx/Dz - Dz/Dx
A_DG.sub(1).dx(0) - A_DG.sub(0).dx(1), # Dy/Dx - Dx/Dy
V_DG.element.interpolation_points(),
curl_A_nedelec_DG = Function(V_DG)
curl_A_nedelec_DG.interpolate(
ufl.as_vector(
A_nedelec_DG.sub(2).dx(1) - A_nedelec_DG.sub(1).dx(2), # Dz/Dy - Dy/Dz
A_nedelec_DG.sub(0).dx(2) - A_nedelec_DG.sub(2).dx(0), # Dx/Dz - Dz/Dx
A_nedelec_DG.sub(1).dx(0) - A_nedelec_DG.sub(0).dx(1), # Dy/Dx - Dx/Dy
curl_error = Function(V_DG)
curl_error.x.array[:] = curl_A_nedelec_DG.x.array - curl_A_DG.x.array
curl_error_L2 = dolfinx.fem.form(ufl.inner(curl_error, curl_error) * ufl.dx)
print(
f"L2 norm of curl_A_nedelec_DG - curl_A_DG = {np.real(np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(curl_error_L2), MPI.SUM))):.2e}"
def numpy_field():
"""Get numpy function for dipolar magnetic field."""
def background_field(x):
"""Return dipolar field."""
######################################### DIPOLE #########################################
dot_product = np.einsum("dn,dn->n", temp_mu_dipole, r_dipole)
bkg_field = (VACUUM_PERMEABILITY / (4 * np.pi * norm_r_dipole**3)) * (
(3 * r_dipole * dot_product / norm_r_dipole**2) - temp_mu_dipole
return bkg_field
return background_field
background_field = numpy_field()
B_nedelec = numpy_to_nedelec(mesh, numpy_potential)
B_DG, _ = numpy_to_DG(mesh, numpy_potential)
B_error = Function(V_DG)
B_nedelec_DG = Function(V_DG)
B_nedelec_DG.interpolate(B_nedelec)
B_error.x.array[:] = B_nedelec_DG.x.array - B_DG.x.array
error_L2 = dolfinx.fem.form(ufl.inner(B_error, B_error) * ufl.dx)
print(
f"L2 norm of B_nedelec_DG - B_DG = {np.real(np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error_L2), MPI.SUM))):.2e}"
B_error.x.array[:] = B_nedelec_DG.x.array - curl_A_nedelec_DG.x.array
print(
f"L2 norm of B_nedelec_DG - curl_A_nedelec_DG = {np.real(np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error_L2), MPI.SUM))):.2e}"
B_error.x.array[:] = B_DG.x.array - curl_A_DG.x.array
print(
f"L2 norm of B_DG - curl_A_DG = {np.real(np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error_L2), MPI.SUM))):.2e}"
## When interpolating dipole potential in N1curl
# L2 norm of A_nedelec_DG - A_DG = 1.06e-02 <- why is this error so high
# L2 norm of B_nedelec_DG - B_DG = 1.06e-02 <- why is this error so high
# L2 norm of curl_A_nedelec_DG - curl_A_DG = 5.50e-01
# L2 norm of B_nedelec_DG - curl_A_nedelec_DG = 7.20e-03
# L2 norm of B_DG - curl_A_DG = 5.54e-01
## When interpolating dipole potential in Lagrange
# L2 norm of A_lagrange_DG - A_DG = 1.22e-17
# L2 norm of B_lagrange_DG - B_DG = 1.22e-17
# L2 norm of curl_A_lagrange_DG - curl_A_DG = 6.12e-16
# L2 norm of B_lagrange_DG - curl_A_lagrange_DG = 5.54e-01
## When interpolating homogeneous field potential in N1curl
# L2 norm of A_nedelec_DG - A_DG = 3.21e-17
# L2 norm of B_nedelec_DG - B_DG = 3.21e-17
# L2 norm of curl_A_nedelec_DG - curl_A_DG = 1.22e-16
# L2 norm of B_nedelec_DG - curl_A_nedelec_DG = 2.01e-01 <- is curl introducing big errors ?
# L2 norm of B_DG - curl_A_DG = 2.01e-01 <- is curl introducing big errors ?
## When interpolating homogeneous field potential in Lagrange
# L2 norm of A_lagrange_DG - A_DG = 8.13e-19
# L2 norm of B_lagrange_DG - B_DG = 8.13e-19
# L2 norm of curl_A_lagrange_DG - curl_A_DG = 3.61e-17
# L2 norm of B_lagrange_DG - curl_A_lagrange_DG = 2.01e-01 <- is curl introducing big errors ?
Any help is appreciated ! Thank you ![]()
