Interpretation of continuity at interface in a homoganization problem
I solved a periodic homogenization problem with fenics. As you see in the picture displayed in Paraview of sigma11 in the uniaxial x BC.
i tried to read the answers of this topic Continuity at interface between two subdomains but i don’t seem to quite understand :
  • The white fluctuations happening between the cells
  • The significance of 2 cells (super dark red and super dark blue ones)
It would be great to know the following:
  • What spaces have you used for sigma?
  • How have you saved the data to a Paraview readable format (XDMFFile.write, XDMFFile.write_checkpoint or File.write)
@dokken through File.write
File.write gives you a CG 1 interpolation of the field you have in dolfin. For visualization of CG spaces >1 or DG spaces, you Need to use XDMFFile.write_checkpoint, see for instance: Loading xdmf data back in - #4 by dokken
