Hi!
This all started because I wanted to be able to talk to Claude about a problem set and it evolved from there. So introducing a MCP for Dolfinx! I also made a Claude CoWork plugin so you can install that have access to specialized skills and agents to design (or have help troubleshoot) what ever you would like. I personally have liked using Claude CoWork as it will do the full workflow and create a report in word or PDF, but since it is set up as a MCP you can use whatever AI assistant you want! So many choices. If you have an issue or spot an error submit it on GitHub and I will do my best to answer.
dolfinx-mcp
ekstanley/ccFenics-plugin (on GitHub)
Talk to your PDE solver. An MCP server that gives AI assistants direct access to the FEniCSx/DOLFINx finite element framework. Describe a PDE in natural language and the tools handle the rest - mesh generation, function spaces, assembly, solving, and post-processing - all inside a sandboxed Docker container.
| 38 MCP Tools |
37 FEM Skills |
514 Tests |
9 Invariants |
20 Lean 4 Theorems |
MCP Client Docker Container
(Claude, Cursor, ...) (dolfinx/dolfinx:stable)
| | JSON-RPC | FastMCP Server |
| "Solve the 3D | ββ stdio/http βββ> | 38 Tool Handlers |
| Poisson equation" | | SessionState |
| | <βββββββββββββββββ | /workspace output |
Quick Start
1. Build
git clone https://github.com/ekstanley/ccFenics-plugin.git
cd ccFenics-plugin
docker build -t dolfinx-mcp .
2. Configure Your MCP Client
Add to your client configuration (Claude Desktop, Cursor, VS Code, etc.).
Set /path/to/workspace to the directory for simulation output (VTK, XDMF):
"mcpServers": {
"dolfinx": {
"command": "docker",
"args": [
"run", "--rm", "-i", "--network", "none",
"-v", "/path/to/workspace:/workspace",
"dolfinx-mcp"
Claude Code β zero-config setup
This repo includes .mcp.json for automatic MCP server discovery:
docker build -t dolfinx-mcp .claude(from the repo root)- Start asking FEM questions β the server auto-connects
For the full FEM-aware experience (37 skills, 6 agents, 6 commands):
claude --plugin-dir ./ccfenics
Claude Cowork (Desktop App)
- Build the Docker image:
docker build -t dolfinx-mcp . - Zip the
dolfinx-assistant/folder - In Claude Desktop, go to Customize > Add Plugin > upload the zip
The 38 MCP tools become available in your Cowork session.
3. Use
Ask your AI assistant to solve a PDE:
βCreate a 16x16 unit square mesh and solve the Poisson equation
with f = 2pi^2 sin(pi x) sin(pi y), then compute the L2 error.β
Example: 3D Poisson on Unit Cube
A Jupyter notebook demonstrating a full 3D workflow is at
examples/3d_poisson_demo.ipynb.
Problem: -\nabla^2 u = 3\pi^2 \sin(\pi x)\sin(\pi y)\sin(\pi z) on [0,1]^3, u=0 on boundary.
| Metric | Result |
| Mesh | 16x16x16 tetrahedra (24,576 cells, 4,913 vertices) |
| Space | P2 Lagrange (35,937 DOFs) |
| Solver | CG + Hypre AMG |
| max(u_h) | 1.000056 (expected 1.0) |
| L2 error | 1.21e-05 |
| H1 error | 1.15e-03 |
Supported Problems
| Category | PDE Types |
| Elliptic | Poisson, Helmholtz, mixed Poisson (RT elements), singular Poisson (nullspace), complex-valued |
| Parabolic | Heat equation, Cahn-Hilliard, Allen-Cahn |
| Flow | Stokes (Taylor-Hood), Navier-Stokes (IPCS) |
| Solid Mechanics | Linear elasticity, hyperelasticity (neo-Hookean), membrane deflection |
| Electromagnetics | H(curl) formulations with Nedelec edge elements |
| Special | Biharmonic (C/IP-DG), discontinuous Galerkin, eigenvalue (SLEPc), axisymmetric |
Boundary conditions: Dirichlet, Neumann, Robin, Nitsche (weak), component-wise, multi-region.
Elements: Lagrange (P1-P5), DG, Nedelec, Raviart-Thomas, BDM, Crouzeix-Raviart, mixed.
Solvers: Direct (LU, MUMPS), iterative (CG, GMRES, BiCGSTAB) with preconditioners (ILU, Hypre AMG, Jacobi), Newton (SNES), time-stepping (Euler, Crank-Nicolson).
Tools (38)
Mesh Operations (9)
| Tool | Description |
create_unit_square |
Unit square mesh with triangular or quadrilateral elements |
create_mesh |
Rectangle or box meshes with custom dimensions |
create_custom_mesh |
Import mesh from Gmsh (.msh) file |
get_mesh_info |
Inspect mesh properties (cells, vertices, bounding box) |
compute_mesh_quality |
Mesh quality metrics (aspect ratio, volume) |
mark_boundaries |
Tag boundary facets using coordinate expressions |
manage_mesh_tags |
Create and manage cell/facet region markers |
refine_mesh |
Uniformly refine an existing mesh |
create_submesh |
Extract submesh from tagged regions |
Function Spaces (2)
create_function_space |
Lagrange, DG, Nedelec, RT, BDM, or CR elements (degree 1-5) |
create_mixed_space |
Mixed function space from component subspaces |
Problem Definition (3)
set_material_properties |
Define material coefficients and source terms |
define_variational_form |
Bilinear and linear forms via UFL expressions |
apply_boundary_condition |
Dirichlet boundary conditions (value + locator) |
Solvers (5)
solve |
Direct (LU, MUMPS) or iterative (CG, GMRES) with preconditioners |
solve_time_dependent |
Time stepping: backward/forward Euler, Crank-Nicolson |
solve_nonlinear |
Newton solver (SNES) for nonlinear PDEs |
solve_eigenvalue |
Generalized eigenvalue problems via SLEPc |
get_solver_diagnostics |
Convergence info, iterations, residual norms |
Post-processing (6)
compute_error |
L2 or H1 error against an exact solution |
evaluate_solution |
Evaluate solution at specified coordinates |
query_point_values |
Point queries with geometric cell info |
compute_functionals |
Integrate UFL expressions over the domain |
export_solution |
Export to XDMF or VTK format |
plot_solution |
Contour or warp plots (PNG via PyVista) |
Interpolation (4)
create_function |
Create a function in a space, optionally initialized with an expression |
interpolate |
Interpolate UFL expression into a function space |
project |
L2-project an expression onto a function space |
create_discrete_operator |
Build a discrete operator matrix |
Session Management (9)
get_session_state |
List all registered meshes, spaces, functions, solutions |
reset_session |
Clear all session state |
run_custom_code |
Execute Python code with persistent namespace across calls |
assemble |
Assemble UFL forms into scalars, vectors, or matrices |
remove_object |
Remove an object with cascade deletion of dependents |
read_workspace_file |
Read files from /workspace/ as base64 (images) or text (VTK, CSV) |
list_workspace_files |
List files in /workspace/ matching glob patterns |
bundle_workspace_files |
Package workspace files into a ZIP archive |
generate_report |
Generate an HTML simulation report with plots and diagnostics |
Claude Code Plugin
The ccfenics/ directory adds FEM domain intelligence on top of the 38 MCP tools.
Load it with claude --plugin-dir ./ccfenics.
Agents (6)
| Agent | What it does |
fem-solver |
End-to-end PDE solve pipeline (mesh to post-processing) |
convergence-study |
Automated mesh refinement with convergence rate fitting |
nonlinear-solver |
Newton method with load stepping and convergence diagnostics |
time-dependent-solver |
Transient PDE workflows (initial conditions, time stepping, output) |
boundary-condition-setup |
Complex BC configuration (Dirichlet, Neumann, Robin, Nitsche) |
mesh-quality |
Mesh quality analysis and refinement recommendations |
Skills (37)
Guided workflows for every supported PDE type, plus solver selection, element selection,
and debugging. Triggered automatically when you describe a problem:
βSolve a Stokes flow problemβ β
fem-workflow-stokes
βMy solver divergedβ βfem-debugging
Commands (6)
| Command | Description |
/solve-poisson |
End-to-end Poisson solve with manufactured solution |
/tutorial-chapter |
Walk through a DOLFINx tutorial chapter step-by-step |
/run-tests |
Run the test suite with coverage |
/check-contracts |
Audit Design-by-Contract compliance |
/add-tool |
Scaffold a new MCP tool |
/verify-installation |
Check Docker, container, and server status |
MCP Protocol
Prompt Templates (6)
| Prompt | Description |
setup_poisson |
Guided Poisson equation setup |
setup_elasticity |
Linear elasticity problem workflow |
setup_stokes |
Stokes flow with mixed elements |
setup_navier_stokes |
Navier-Stokes with time stepping |
debug_convergence |
Diagnose solver convergence failures |
convergence_study |
h-refinement convergence rate study |
Resources (6)
| URI | Content |
dolfinx://capabilities |
Element families, solvers, export formats |
dolfinx://mesh/schema |
JSON schema for mesh objects |
dolfinx://space/schema |
JSON schema for function space objects |
dolfinx://solution/schema |
JSON schema for solution objects |
dolfinx://session/overview |
Current session state summary |
dolfinx://solver/options |
Available solver and preconditioner options |
Transport Modes
| Mode | Command | Use Case |
| stdio (default) | docker run --rm -i dolfinx-mcp |
CLI clients, Claude Desktop |
| streamable-http | docker run -p 8000:8000 dolfinx-mcp --transport streamable-http --host 0.0.0.0 |
Web clients, JupyterLab |
| sse | docker run -p 8000:8000 dolfinx-mcp --transport sse --host 0.0.0.0 |
Legacy SSE clients |
JupyterLab Integration
Start with Docker Compose:
docker-compose -f docker-compose.lab.yml up --build
# Open http://localhost:8888
Or install directly:
pip install dolfinx-mcp[jupyter]
Use IPython magics inside JupyterLab:
%load_ext dolfinx_mcp_jupyter
%mcp_config url=http://localhost:8000/mcp
%mcp create_unit_square name=mesh nx=16 ny=16
%mcp create_function_space name=V family=Lagrange degree=1
%mcp solve solver_type=direct
%mcp compute_error exact="sin(pi*x[0])*sin(pi*x[1])" norm_type=L2
Design-by-Contract
All 38 tools enforce runtime contracts:
- Preconditions: Input validation (parameter types, ranges, existence checks)
- Postconditions: Output validation (return structure, value constraints)
- Invariants: 9 referential integrity invariants on SessionState
Contract violations return structured error responses:
"error": "PRECONDITION_VIOLATED",
"message": "Mesh 'box' not found in session",
"suggestion": "Create a mesh first with create_unit_square or create_mesh"
Error codes: NO_ACTIVE_MESH, MESH_NOT_FOUND, FUNCTION_SPACE_NOT_FOUND,
FUNCTION_NOT_FOUND, INVALID_UFL_EXPRESSION, SOLVER_ERROR, DUPLICATE_NAME,
DOLFINX_API_ERROR, FILE_IO_ERROR, PRECONDITION_VIOLATED,
POSTCONDITION_VIOLATED, INVARIANT_VIOLATED.
Formal Verification (Lean 4)
8 of the 9 referential integrity invariants are formally verified in Lean 4
with machine-checked proofs. INV-9 (FormInfo.trial_space_name) is specified
in Quint and enforced at runtime.
20 theorems, 4 helper lemmas, zero sorry placeholders.
| Theorem | What it proves |
freshState_valid |
Empty session satisfies all 8 invariants |
registerMesh_valid |
Adding a mesh preserves invariants |
registerFunctionSpace_valid |
Adding a function space preserves invariants |
removeMesh_valid |
Cascade deletion of mesh + dependents preserves invariants |
removeSpaceDeps_valid |
Removing space dependents preserves invariants |
cleanup_valid |
Session reset produces a valid state |
validateOutputPath_safe |
Output path validation is a containment check |
errorCodeString_injective |
All 13 error codes are pairwise distinct |
Verify locally (requires [Lean 4]):
cd .outline/proofs/DolfinxProofs
lake build # exits 0, zero warnings
Security
Three-layer defense for UFL expression evaluation:
- Token blocklist β
_check_forbidden()rejectsimport,__,exec,eval,open,os.,subprocess, and 12 more tokens at parse time - Empty
__builtins__β expression namespaces have no access to Python internals - Docker isolation β container runs with
--network none, non-root user,--rm
run_custom_code intentionally bypasses the blocklist (full __builtins__).
Docker isolation is the sole boundary for custom code execution.
See SECURITY.md for vulnerability reporting.
Development
pip install -e ".[dev]"
# Unit tests (no Docker, ~417 tests)
pytest tests/ \
--ignore=tests/test_runtime_contracts.py \
--ignore=tests/test_tutorial_workflows.py \
--ignore=tests/test_edge_case_contracts.py \
--ignore=tests/test_poisson_workflow.py
# Docker integration tests (514 tests across 6 suites)
./scripts/run-docker-tests.sh
# Lint & type check
ruff check src/
pyright src/dolfinx_mcp/
Project Structure
src/dolfinx_mcp/
server.py Entry point
_app.py FastMCP instance + lifespan
session.py SessionState (8 registries, 9 invariants)
errors.py 13 error classes + decorator
ufl_context.py Restricted UFL expression evaluation
tools/
mesh.py 9 mesh tools
spaces.py 2 function space tools
problem.py 3 problem definition tools
solver.py 5 solver tools
postprocess.py 6 post-processing tools
interpolation.py 4 interpolation tools
session_mgmt.py 9 session management tools
prompts/templates.py 6 workflow prompts
resources/providers.py 6 URI resources
src/dolfinx_mcp_jupyter/ JupyterLab extension (5 IPython magics)
tests/ 18 test files, ~514 tests (417 unit + 97 Docker-only)
examples/ 3D Poisson notebook + production readiness suite
.outline/proofs/ Lean 4 formal verification (20 theorems)
ccfenics/ Claude Code plugin (37 skills, 6 agents, 6 commands)
Contributing
See CONTRIBUTING.md for development setup, code style, and the new tool checklist.
License
MIT
