Invalid value encountered in interpolate
Hi, I have a dirichlet boundary function in which a divide exists. The division is valid on the boundary but not in the whole domain. This is the warning:
RuntimeWarning: invalid value encountered in divide
  theta = np.arctan(x[1] / x[0])
Use the cells input to interpolate to limit the cells you are using interpolation on
Dear dokken,
My code is
x0 = 23.43211
y0 = 5.19
alpha = np.arctan(y0 / x0)
beta = np.arctan(x0 / y0)
def out_boundary(x):
    return 0.13395 - (theta - alpha) / (beta - alpha) * 0.2679
mesh_comm = MPI.COMM_WORLD
gdim = 3
gmsh_model_rank = 0
domain, cell_markers, facet_markers = gmshio.read_from_msh('pole-FEMMeshGmsh.msh', mesh_comm, rank=gmsh_model_rank, gdim=gdim)
#with XDMFFile(MPI.COMM_WORLD, "rfq_out.xdmf", "w") as xdmf:
# xdmf.write_mesh(domain)
# xdmf.write_meshtags(facet_markers)
V = FunctionSpace(domain, ("CG", 2))
a = dot(grad(u), grad(v)) * dx
L = Constant(domain, ScalarType(0)) * v * dx
neg_pole_facets = facet_markers.indices[facet_markers.values == 27]
neg_pole_bdofs = locate_dofs_topological(V, 2, neg_pole_facets)
pos_pole_facets = facet_markers.indices[facet_markers.values == 26]
pos_pole_bdofs = locate_dofs_topological(V, 2, pos_pole_facets)
print(neg_pole_bdofs, pos_pole_bdofs)
out_facets = facet_markers.indices[facet_markers.values == 25]
out_bdofs = locate_dofs_topological(V, 2, out_facets)
u_O = Function(V)
u_O.interpolate(out_boundary)
u_O is the function I want to interpolate on the out_facets. Then how to modify the last line in my code? Thank you.
Please make a minimal reproducible example next time (using a built in mesh).
Consider the following:
V = dolfinx.fem.FunctionSpace(mesh, ("Lagrange", 2))
u = dolfinx.fem.Function(V)
def f(x):
    return x[1]/x[0]
def left_facet_locator(x):
    return np.isclose(x[0], 1)
left_facets = dolfinx.mesh.locate_entities(mesh, mesh.topology.dim-1, left_facet_locator)
cells = dolfinx.mesh.compute_incident_entities(mesh, left_facets, mesh.topology.dim-1, mesh.topology.dim)
u.interpolate(f, cells)
with dolfinx.io.VTXWriter(mesh.comm, "u.bp", [u]) as vtx:
    vtx.write(0.0)
returning
Thank you very much. :smiley:
