Io .h5/.xdmf file in dolfinx (not in parallel)
I would like to write and read .xdmf or .h5 files in dolfinx, and I don’t need a parallel implementation. I am trying out the following code:
from dolfinx import fem, io, mesh, plot, geometry
import h5py as h5py
domain = mesh.create_rectangle(comm=MPI.COMM_WORLD,
                            points=((0.0, 0.0), (2.0, 1.0)), n=(32, 16),
                            cell_type=mesh.CellType.triangle,)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
uh = fem.Function(V, name = "Test")
with io.XDMFFile(domain.comm, "output/output.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_function(uh)
f0 = fem.Function(V)
with h5py.File('output/output.h5', 'r') as ifile:
    y = ifile['/Function/Test/0']
and I get the following error message:
File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
 File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
 File "/opt/anaconda3/envs/fenicsx-0.6.0/lib/python3.10/site-packages/h5py/_hl/group.py", line 357, in __getitem__
  oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
 File "h5py/h5o.pyx", line 241, in h5py.h5o.open
KeyError: 'Unable to synchronously open object (component not found)'
Any help is very welcome!
Many thanks.
Hi.
I cannot reproduce your error on the dolfinx v0.7.2 - v0.7.3 anaconda environments. Maybe you could try to update the dolfinx-conda environment or update the h5py package (and the corresponding dependencies). You could also use XDMFFile.write_checkpoint (see https://fenicsproject.discourse.group/t/read-mesh-from-xdmf-file-write-checkpoint/3458/3)
Cheers.
