Hello people,
I’m using a Nonlinear solver for what I think is a linear problem, the reason being that in the future I might want to add non linearities, and this would require many changes in the code if I had chosen a linear solver at first, whereas very little changes with the non linear solver.
I have a code that solves 2 coupled PDEs, with a mixed elements approach. The values seem to make sense, at a highly accurate testings, so I trusted the results, but a recent discussion Solving a system of coupled PDEs in fenicsx - #31 by dokken makes me think my problem is either ill-posed or my problem is non linear. Therefore, I would like to make sure the problem is linear/non linear, as a 1st step to debug.
The coupled PDE’s are:
\nabla \cdot \vec J_e =0 and \nabla \cdot (-\kappa \nabla T) + \rho \vec J_e\cdot \vec J_e-T \left( S_{xx} \frac{\partial J_{e_x}}{\partial x} + S_{yy} \frac{\partial J_{e_y}}{\partial y}\right)=0.
Where \vec J_e = -\sigma \nabla V -\sigma S \nabla T where \sigma =1/\rho is a scalar (float), S is a tensor (2D diagonal matrix in my case, where the 2 non zero elements are floats/scalars).
The boundary conditions are of Dirichlet type for T. I keep 2 “Physical curve” at constant temperature. For V, I employ Neumann type boundary condition, I specify that the voltage between 2 surfaces must be such that a total given electric current must flow.
Fenicsx solves for V and T, the voltage and the temperature. I am essentially solving a thermoelectric heat equation. From these 2 quantities, I can retrieve \vec J_e using the relation above, the heat flux, the electric field, and so on and so forth. I can also compute the total Joule heat in the material, and I confirmed that it matches the expected values to very high accuracy. I tested several cases, and always got meaningful results, to me.
I can show you my full code, but I really wish to stick with what is above. Is the above problem linear?
In any case, here is some code:
from dolfinx import log
from dolfinx.fem import (Constant, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_geometrical, VectorFunctionSpace,
locate_dofs_topological, Expression)
from dolfinx.io import XDMFFile, gmshio
from ufl import (FiniteElement, Measure, MixedElement, SpatialCoordinate,
TestFunction, TrialFunction, as_tensor, dot, dx, grad, inner,
inv, split, derivative, FacetNormal, div)
from dolfinx.io import gmshio, VTXWriter, XDMFFile
mesh, cell_markers, facet_markers = gmshio.read_from_msh("meshes/rectangles.msh", MPI.COMM_WORLD, gdim=2)
# Reminder of the mesh:
#Physical Surface("material", 11) = {2, 1, 3};
#Physical Curve("bottom_left", 12) = {10};
#Physical Curve("top_right", 13) = {6};
inj_current_curve = 12
out_current_curve = 13 # This corresponds to the curve the current leaves the material.
reading_voltage_surface_0 = 12
reading_voltage_surface_1 = 13
# Define ME function space
el = FiniteElement("CG", mesh.ufl_cell(), 4)
mel = MixedElement([el, el])
ME = FunctionSpace(mesh, mel)
u, v = TestFunction(ME)
TempVolt = Function(ME)
temp, volt = split(TempVolt)
dTV = TrialFunction(ME)
rho = 1
sigma = 1.0 / rho
κ = 1.8
# The Seebeck coefficient has to be an anisotropic tensor for the Bridgman heat to take place.
S_xx = 3600e-6
S_yy = S_xx * 10
Seebeck_tensor = as_tensor([[S_xx, 0], [0, S_yy]])
# Define the boundary conditions
left_facets = facet_markers.find(inj_current_curve)
right_facets = facet_markers.find(out_current_curve)
left_dofs = locate_dofs_topological(
ME.sub(1), mesh.topology.dim-1, left_facets)
left_dofs_temp = locate_dofs_topological(
ME.sub(0), mesh.topology.dim-1, left_facets)
right_dofs_temp = locate_dofs_topological(
ME.sub(0), mesh.topology.dim-1, right_facets)
T_cold = 300.0
ΔT = 200
bc_temp_left = dirichletbc(ScalarType(T_cold), left_dofs_temp, ME.sub(0))
bc_temp_right = dirichletbc(ScalarType(T_cold + ΔT), right_dofs_temp, ME.sub(0))
bcs = [bc_temp_left, bc_temp_right]
x = SpatialCoordinate(mesh)
dx = Measure("dx", domain=mesh, subdomain_data=cell_markers)
ds = Measure("ds", domain=mesh, subdomain_data=facet_markers)
resistance = -4.55847847099578
the_current = S_xx * ΔT / (2 * resistance) # Current, in amperes.
the_current = 1e-15#1.0
J = the_current / assemble_scalar(form(1 * ds(inj_current_curve, domain=mesh)))
# Weak form.
J_vector = -sigma * grad(volt) - sigma * Seebeck_tensor * grad(temp)
Fourier_term = dot(-κ * grad(temp), grad(u)) * dx
Joule_term = dot(rho * J_vector, J_vector) * u * dx
Bridgman_term = - temp * (S_xx * J_vector[0].dx(0) + S_yy * J_vector[1].dx(1)) * u * dx
F_T = Fourier_term + Joule_term #+ Bridgman_term
F_V = -dot(grad(v), sigma * grad(volt))*dx -dot(grad(v), sigma * Seebeck_tensor * grad(temp))*dx - v * J * ds(out_current_curve) + v * J * ds(inj_current_curve)
weak_form = F_T + F_V
# Solve the PDE.
Jac = derivative(weak_form,TempVolt,dTV)
print(f''' ------- Pre-processing --------
Current density: {J}
Length of the side where current is injected: {assemble_scalar(form(1 * ds(inj_current_curve, domain=mesh)))}
Length of the side where current leaves the wire: {assemble_scalar(form(1 * ds(out_current_curve, domain=mesh)))}
This should correspond to the current injected: {assemble_scalar(form(J*ds(out_current_curve)))}
# Solve the PDE.
problem = NonlinearProblem(weak_form, TempVolt, bcs=bcs, J = Jac)
solver.rtol = 1e-10
solver.report = True
solver.max_it = 10000
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}pc_type"] = "ksp"
ksp.setFromOptions()
log.set_log_level(log.LogLevel.WARNING)
n, converged = solver.solve(TempVolt)
assert(converged)
print(f'''------- Processing --------
Number of interations: {n:d}''')
avg_voltage_curve_integral_0 = assemble_scalar(form(volt * ds(reading_voltage_surface_0, domain=mesh))) / assemble_scalar(form(1 * ds(reading_voltage_surface_0, domain=mesh)))
avg_voltage_curve_integral_1 = assemble_scalar(form(volt * ds(reading_voltage_surface_1, domain=mesh))) / assemble_scalar(form(1 * ds(reading_voltage_surface_1, domain=mesh)))
voltage_diff = avg_voltage_curve_integral_1 - avg_voltage_curve_integral_0
avg_temperature_surface_integral_2 = assemble_scalar(form(temp * ds(inj_current_curve, domain=mesh))) / assemble_scalar(form(1 * ds(inj_current_curve, domain=mesh)))
avg_temperature_surface_integral_3 = assemble_scalar(form(temp * ds(out_current_curve, domain=mesh))) / assemble_scalar(form(1 * ds(out_current_curve, domain=mesh)))
# Compute fluxes on boundaries
down_heat_flux = form(dot(-κ * grad(temp) + Seebeck_tensor * temp * J_vector, n)*ds(out_current_curve))
Q_out = assemble_scalar(down_heat_flux)
top_heat_flux = form(dot(-κ * grad(temp) + Seebeck_tensor * temp * J_vector, n)*ds(inj_current_curve))
Q_in = assemble_scalar(top_heat_flux)
print(f'''--------- Post processing -------
voltage measured: {voltage_diff} V.
voltage left: {avg_voltage_curve_integral_0} V.
voltage right: {avg_voltage_curve_integral_1} V.
the_current: {the_current} A.
This should correspond to the current injected: {assemble_scalar(form(dot(J_vector, n)*ds(out_current_curve)))}
Temperature of current injection contact: {avg_temperature_surface_integral_2} K.
Temperature of current outjection contact: {avg_temperature_surface_integral_3} K.
Computed generated Joule heat through the whole volume: {assemble_scalar(form(dot(rho * J_vector, J_vector) * dx))} W.
Computed Joule heat with I^2R: {the_current**2 * resistance} W.
Make sure div(J_e) = 0 throughought the whole volume: {assemble_scalar(form((J_vector[0].dx(0) + J_vector[1].dx(1)) * dx))}
Make sure div(J_e) = 0 throughought the whole volume: {assemble_scalar(form(div(J_vector) * dx))}
Average temperature of whole volume: {assemble_scalar(form(temp * dx(domain=mesh))) / assemble_scalar(form(1 * dx(domain=mesh)))}
Electrical resistance should be slightly lower than {0.5 /0.1 * rho}. It is worth {voltage_diff / the_current}.
More accurately, it is worth {voltage_diff / the_current + S_xx * ΔT / the_current}
Q_out: {Q_out} W/m^2.
Q_in: {Q_in} W/m^2.
Power produced by the TE element: {Q_in + Q_out} W.
# Heat flux.
Q = VectorFunctionSpace(mesh, ("DG", 3))
q = Function(Q)
flux_calculator = Expression(-κ * grad(temp), Q.element.interpolation_points())
q.interpolate(flux_calculator)
# Current density.
J = VectorFunctionSpace(mesh, ("DG", 3))
Je = Function(J)
Je_flux_calculator = Expression(-sigma * grad(volt) - sigma * Seebeck_tensor * grad(temp), J.element.interpolation_points())
Je.interpolate(Je_flux_calculator)
Output_0 = TempVolt.sub(0).collapse()
Output_1 = TempVolt.sub(1).collapse()
output_3 = q
output_4 = Je
with VTXWriter(MPI.COMM_WORLD, "results/temperature.bp", [Output_0], engine="BP4") as vtx:
vtx.write(0.0)
with VTXWriter(MPI.COMM_WORLD, "results/voltage.bp", [Output_1], engine="BP4") as vtx:
vtx.write(0.0)
with VTXWriter(MPI.COMM_WORLD, "results/heat_flux.bp", [output_3], engine="BP4") as vtx:
vtx.write(0.0)
with VTXWriter(MPI.COMM_WORLD, "results/current_density.bp", [output_4], engine="BP4") as vtx:
vtx.write(0.0)
