from scipy.linalg import fractional_matrix_powerdef compute_tau_supg(dt, A1, A2, K11, K12, K21, K22, mesh):
Compute τ_SUPG according to:
τ_SUPG = (4/Δt² I + GᵢⱼAᵢAⱼ + CₗGᵢⱼGₖₗKᵢₖKₗⱼ)^(-1/2)Parameters: dt: time step size A1, A2: Advective flux Jacobian matrices K11, K12, K21, K22: Diffusion matrices mesh: FEniCS mesh """ # Get spatial coordinates and compute metric tensor Gᵢⱼ x = SpatialCoordinate(mesh) J = grad(x) # Jacobian matrix G = as_matrix([ [dot(J[:, 0], J[:, 0]), dot(J[:, 0], J[:, 1])], [dot(J[:, 0], J[:, 1]), dot(J[:, 1], J[:, 1])] ]) # Create identity matrix of same size as advection matrices I = Identity(A1.ufl_shape[0]) # Compute GᵢⱼAᵢAⱼ term AA_term = (G[0, 0] * A1 * A1 + G[0, 1] * (A1 * A2 + A2 * A1) + G[1, 1] * A2 * A2) # Compute CₗGᵢⱼGₖₗKᵢₖKₗⱼ term C_I = Constant(1.0) # Inverse estimate constant KK_term = C_I * ( G[0, 0] * G[0, 0] * (K11 * K11 + K12 * K12) + G[0, 1] * G[0, 1] * (K11 * K21 + K12 * K22) + G[1, 0] * G[1, 0] * (K21 * K11 + K22 * K12) + G[1, 1] * G[1, 1] * (K21 * K21 + K22 * K22) ) # Compute matrix under square root: 4/Δt² I + GᵢⱼAᵢAⱼ + CₗGᵢⱼGₖₗKᵢₖKₗⱼ M = 4.0 / (dt * dt) * I + AA_term + KK_term # Compute τ_SUPG using matrix power tau_SUPG = as_matrix(fractional_matrix_power(M, -0.5)) return tau_SUPG
this is code, I assemble the matrices used as parameters by using as_matrix, then I want to calculate the inverse square root of these matrices, is there any built-in function to do this?
