Issue in generating Tetrahedron mesh
Hi Fenics Community,
I am trying to use Tetrahedron from mshr as follow:
Tet1 = Tetrahedron(dolfin.Point(0.0, 44.0, 12.0), dolfin.Point(0.0, 64.0, 12.0), dolfin.Point(48.0, 64.0, 12.0), dolfin.point(0.0, 44.0, -2.0) )
mesh = generate_mesh(Tet1, 4)
plot(mesh)
The error:
AttributeError: ‘module’ object has no attribute ‘point’
I was looking for the source of this error from some of the available online resources but unfortunately, I couldn’t find any clue, so It would be great if someone could give me a hint in this case.
Thank you in advance,
Ali
import dolfin
Tet1 = Tetrahedron(
    dolfin.Point(0.0, 44.0, -2.0),
from vtkplotter.dolfin import plot
plot(mesh)
capital p in point!
Thanks for your response.
I am trying to get a 3D Cook membrane, so I should define more than four Tetrahedron as follows:
import math
Cube = Box(dolfin.Point(0.0, 0.0, 0.0), dolfin.Point(48.0, 64.0, 10.0))
Tet1 = Tetrahedron(
Tet2 = Tetrahedron(
dolfin.Point(0.0, 64.0, -2.0),
dolfin.Point(24.0, 54.0, 12.0),
Tet3 = Tetrahedron(
dolfin.Point(48.0, 64.0, -2.0),
Tet4 = Tetrahedron(
geometry = Cube - Tet1 - Tet2 - Tet3 - Tet4
mesh = generate_mesh(geometry, 10)
plot(mesh)
vtkfile = dolfin.File(‘Figures/3Dcook.pvd’)
vtkfile << mesh
But It seems generate_mesh cannot get more than four input.
Error:
Error !!!
Error !!!
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
system msg for write_line failure : Bad file descriptor
this is one possible issue…
