Hello everyone. I am trying to create simple square geometry using gmsh to test this approach. I used both the approaches and have issues.
- Using gmshio.model_to_mesh. On using this approach, I do not see any mesh when opened in Paraview although I have generated the mesh (picture below). What could be the issue here?
from pathlib import Path
from dolfinx.io import gmshio
import gmsh, meshio
#-------------- gmshio---------------------------------#
# Geometry
gmsh.initialize() # Before using any functions in the Python API, Gmsh must be initialized
gmsh.model.add("box_test_1") # name of the model
# Create points
lc = 1e-2 # target mesh size close to the point
gmsh.model.geo.addPoint(0, 0, 0, lc, 1)
gmsh.model.geo.addPoint(10.0, 0, 0, lc, 2)
gmsh.model.geo.addPoint(10.0, 10.0, 0, lc, 3)
gmsh.model.geo.addPoint(0, 10.0, 0, lc, 4)
# Create lines
gmsh.model.geo.addLine(1, 2, 1)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.addLine(3, 4, 3)
gmsh.model.geo.addLine(4, 1, 4)
# Create Surface
gmsh.model.geo.addCurveLoop([4, 1, 2, 3], 1)
pl = gmsh.model.geo.addPlaneSurface([1], 1)
gmsh.model.geo.synchronize() # Before they can be meshed the CAD entities must be synchronized with the Gmsh model
# Add Physical Group
gmsh.model.addPhysicalGroup(1, [1], 5)
gmsh.model.addPhysicalGroup(1, [2], 6)
gmsh.model.addPhysicalGroup(1, [3], 7)
gmsh.model.addPhysicalGroup(1, [4], 8)
# Meshing options
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.05)
gmsh.model.mesh.generate(2)
gmsh.write("test_gm.msh")
# Interfacing with dolfinx
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, gmsh_model_rank, gdim=2)
with dolfinx.io.XDMFFile(domain.comm, "test_gmsh.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
- Using meshio, I have the error given below. What could be the problem here?
import gmsh, meshio
proc = MPI.COMM_WORLD.rank
# msh = meshio.read(Path("geometry")/"quad.msh")
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read": [cell_data.astype(np.int32)]})
return out_mesh
if proc == 0:
# Read in mesh
msh = meshio.read(Path("geometry")/"tri1.msh")
# Create and save one file for the mesh, and one file for the facets
meshio.write("mt.xdmf", line_mesh)
MPI.COMM_WORLD.barrier()
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
ct = xdmf.read_meshtags(mesh, name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim - 1)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "r") as xdmf:
ft = xdmf.read_meshtags(mesh, name="Grid")
Error on the cell_data line in def create_mesh:
Exception has occurred: ValueError
need at least one array to concatenate
File "/home/igupta/studies/Basic_bi_copy/basic_bi.py", line 76, in create_mesh
File "/home/igupta/studies/Basic_bi_copy/basic_bi.py", line 86, in <module>
ValueError: need at least one array to concatenate
The tri1.msh file looks like this
$MeshFormat
4.1 0 8
$EndMeshFormat
$Entities
4 4 1 0
1 0 0 0 0
2 10 0 0 0
3 10 10 0 0
4 0 10 0 0
1 0 0 0 10 0 0 1 1 2 1 -2
2 10 0 0 10 10 0 1 2 2 2 -3
3 0 10 0 10 10 0 1 3 2 3 -4
4 0 0 0 0 10 0 1 4 2 4 -1
1 0 0 0 10 10 0 0 4 4 1 2 3
$EndEntities
$Nodes
8 40 1 40
0 1 0 1
1
0 0 0
0 2 0 1
2
10 0 0
0 3 0 1
3
10 10 0
0 4 0 1
4
0 10 0
1 1 0 9
5
6
7
8
9
10
11
12
13
0.9999999999991893 0 0
1.999999999996827 0 0
2.99999999999391 0 0
3.999999999991027 0 0
4.999999999992411 0 0
5.999999999993932 0 0
6.999999999995455 0 0
7.999999999996978 0 0
8.99999999999849 0 0
1 2 0 9
14
15
16
17
18
19
20
21
22
10 0.9999999999991893 0
10 1.999999999996827 0
10 2.99999999999391 0
10 3.999999999991027 0
10 4.999999999992411 0
10 5.999999999993932 0
10 6.999999999995455 0
10 7.999999999996978 0
10 8.99999999999849 0
1 3 0 9
23
24
25
26
27
28
29
30
31
8.999999999999998 10 0
7.999999999999996 10 0
6.999999999999994 10 0
5.999999999999991 10 0
4.999999999999989 10 0
3.999999999999988 10 0
2.999999999999985 10 0
1.999999999999982 10 0
0.9999999999999911 10 0
1 4 0 9
32
33
34
35
36
37
38
39
40
0 8.999999999999998 0
0 7.999999999999996 0
0 6.999999999999994 0
0 5.999999999999991 0
0 4.999999999999989 0
0 3.999999999999988 0
0 2.999999999999985 0
0 1.999999999999982 0
0 0.9999999999999911 0
$EndNodes
$Elements
4 40 1 40
1 1 1 10
1 1 5
2 5 6
3 6 7
4 7 8
5 8 9
6 9 10
7 10 11
8 11 12
9 12 13
10 13 2
1 2 1 10
11 2 14
12 14 15
13 15 16
14 16 17
15 17 18
16 18 19
17 19 20
18 20 21
19 21 22
20 22 3
1 3 1 10
21 3 23
22 23 24
23 24 25
24 25 26
25 26 27
26 27 28
27 28 29
28 29 30
29 30 31
30 31 4
1 4 1 10
31 4 32
32 32 33
33 33 34
34 34 35
35 35 36
36 36 37
37 37 38
38 38 39
39 39 40
40 40 1
$EndElements
