Issue Loading XDMF Mesh File into FEniCS
Hello FEniCS Community,
I am currently working on designing a mesh system and have been following Jorgen S. Dokken’s tutorial, which includes using Meshio to convert a .msh file to .xdmf. I successfully performed the conversion, and I am able to visually inspect the .xdmf file in ParaView without any issues. However, I’m encountering difficulties when attempting to load the .xdmf file into FEniCS.
Here is the code snippet I am using to load the mesh:
# Load mesh from XDMF file
mesh = Mesh()
with XDMFFile("tetra_mesh.xdmf") as infile:
    infile.read(mesh)
The error I am facing is as follows:
Input In [2], in <cell line: 5>()
      4 mesh = Mesh()
      5 with XDMFFile("tetra_mesh.xdmf") as infile:
----> 6     infile.read(mesh)
      8 # Load mesh function from XDMF file
      9 volumes = MeshValueCollection("size_t", mesh, mesh.topology().dim())
I am unsure whether the problem lies within the mesh file itself or if I might be missing some important details or steps required to read the mesh file correctly in FEniCS. Here are my system details:
  • FEniCS Version: Legacy Edition 2019.1.0
  • Installation: Docker
  • Platform: Linux
I would greatly appreciate any guidance or suggestions you could provide to help resolve this issue. To assist in diagnosing the problem, below in the github link you can see both the .xdmf and .msh files.
physical_groups_4
physical_groups_3
physical_groups_2
physical_groups_1
paraview xdmf
Thank you in advance for your assistance!
Best regards,
Without the corresponding tetra_mesh.h5 we cannot help you.
Also add the full error message of the RunTimeError, as it seems like you haven’t included it all
I have updated the github. Please see the link below.
Hence, the error message in full can be seen below:
4 mesh = Mesh()
5 with XDMFFile(“tetra_mesh.xdmf”) as infile:
9 volumes = MeshValueCollection(“size_t”, mesh, mesh.topology().dim())
RuntimeError:
*** Error: Unable to open HDF5 file.
*** Reason: File “tetra_mesh.h5” does not exist.
*** Where: This error was encountered inside HDF5Interface.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: ba376b6aebd7a9bc089be46b50bdd9f5c548fb91
The error is quite explicit.
You do not have the h5 file and xdmf file in the same repo (it seems).
For using the code
mesh = Mesh()
    infile.read(mesh)
from your updated git repo works fine.
