I am working with FEniCS and dolfin-adjoint, and I encountered an error while trying to compute the gradient of a functional. The error message I am receiving is:
Invalid type conversion: f_53 can not be converted to any UFL type.
The forward problem is implemented as follows:
u_bc = DirichletBC(V, u_bc_expr, boundary)
F = k * dot(grad(u), grad(v)) * dx - f_expr * v * dx
a, L = lhs(F), rhs(F)
u_sol = Function(V)
A, b = assemble_system(a, L, u_bc)
solve(A, u_sol.vector(), b)
After solving the forward problem, I am trying to compute the sensitivity of the loss with respect to k by calculating the gradient:
neum_output_func = k_func * dot(grad(u_output), n)
neum_exact_func = k_exact_func * dot(grad(target_u), n)
diff_neum_func = neum_output_func - neum_exact_func
L = assemble(0.5 * inner(diff_neum_func, diff_neum_func) * ds)
control_k = Control(k_func)
dLdk = compute_gradient(L, control_k)
The error occurs when trying to compute the gradient using compute_gradient(L, control_k).
I am using the following versions:
* dolfin-adjoint: 2019.1.0
* fenics-dijitso: 2019.2.0.dev0
* fenics-dolfin: 2019.2.0.64.dev0
* fenics-ffc: 2019.2.0.dev0
* fenics-fiat: 2019.2.0.dev0
* fenics-ufl: 2024.2.0
* fenics-ufl-legacy: 2022.3.0
Question:
Could you help me understand why this error occurs? It seems like there might be a mismatch or compatibility issue with the UFL types, but I’m not sure how to resolve it.
Also, could this problem be caused by the version differences between dolfin-adjoint, fenics-dolfin, and fenics-ufl? Would using compatible versions of these packages help resolve the issue? Any advice or guidance would be greatly appreciated.
Thank you!
Best regards, Dabin Park
