UFLValueError: Invalid type conversion - can not be converted to any UFL type
I am working on a contact issue using a penalty term in the variational formulation.
Maybe someone can help me find a solution for the following UFL Type Error:
 File "/home/fenics/shared/mwe_rec_cropped.py", line 97, in <module>
    form = inner(sigma(u), eps(u_))*dx +pen*dot(u_, gap)*ds
  File "/usr/local/lib/python3.10/dist-packages/ufl/operators.py", line 174, in dot
    b = as_ufl(b)
  File "/usr/local/lib/python3.10/dist-packages/ufl/constantvalue.py", line 438, in as_ufl
    raise UFLValueError("Invalid type conversion: %s can not be converted"
ufl.log.UFLValueError: Invalid type conversion: <function gap at 0x7fb625a57d90> can not be converted to any UFL type.
I am probably mixing different types of algebra but as I am new to fenicsx I can not find a working expression for gap().
I would be very grateful for help.
Sketch of the problem:
MWE for the problem:
from dolfinx import fem, mesh
from dolfinx.io import XDMFFile, gmshio
from ufl import dx, inner, derivative, tr, Identity, sym, grad, TrialFunction, TestFunction, Measure, SpatialCoordinate, dot, sqrt
gmsh.model.add("rectangle")
lc=0.5e-1
# generate points for inner contour
gmsh.model.geo.addPoint(1, 1, 0, lc, 1)
gmsh.model.geo.addPoint(-1, 1, 0, lc, 2)
gmsh.model.geo.addPoint(-1, -1, 0, lc, 3)
gmsh.model.geo.addPoint(1, -1, 0, lc, 4)
# generate inner contour
gmsh.model.geo.addLine(1, 2, 1)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.addLine(3, 4, 3)
gmsh.model.geo.addLine(4, 1, 4)
# generate points for outer contour
gmsh.model.geo.addPoint(2, 2, 0, lc, 5)
gmsh.model.geo.addPoint(-2, 2, 0, lc, 6)
gmsh.model.geo.addPoint(-2, -2, 0, lc, 7)
gmsh.model.geo.addPoint(2, -2, 0, lc, 8)
# generate outer contour
gmsh.model.geo.addLine(5, 6, 5)
gmsh.model.geo.addLine(6, 7, 6)
gmsh.model.geo.addLine(7, 8, 7)
gmsh.model.geo.addLine(8, 5, 8)
# generate curveloops
gmsh.model.geo.addCurveLoop([1, 2, 3, 4], 1)
gmsh.model.geo.addCurveLoop([5, 6, 7, 8], 2)
# generate surface
gmsh.model.geo.addPlaneSurface([2, 1], 1)
gmsh.model.geo.synchronize()
# generate physical groups for boundary conditions
inside, outside, surface = 1, 2, 3
gmsh.model.addPhysicalGroup(1, [1, 2, 3, 4], inside, name="Inner Contour")
gmsh.model.addPhysicalGroup(1, [5, 6, 7, 8], outside, name="Outer Contour")
gmsh.model.addPhysicalGroup(2, [1], surface, name="Surface")
# finish gmsh
gmsh.model.mesh.generate(2)
# create a DOLFINx mesh
dim = 2
gmsh_model_rank = 0
domain_com = MPI.COMM_SELF
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, domain_com, gmsh_model_rank, dim)
gmsh.finalize()
tdim = domain.topology.dim
fdim = tdim - 1
# define function space
V = fem.VectorFunctionSpace(domain, ("CG",1))
# contact zones
x = SpatialCoordinate(domain)
center_x = .0
center_y = .0
D = 2.4
def gap():
    return (D/2) - sqrt( pow(x[0]-center_x, 2) + pow(x[1]-center_y, 2) )
def in_circle(x):
    return np.less_equal(((x[0]-center_x)**2 + (x[1]-center_y)**2), ((D/2)**2))
contact_facets = mesh.locate_entities_boundary(domain,fdim ,in_circle)
ds = Measure('ds', domain=domain, subdomain_data=contact_facets, metadata=metadata)
# test and trial functions
u = fem.Function(V, name="Displacement")
du = TrialFunction(V)
u_ = TestFunction(V)
# define outer contour as homogenous boundary condition
u_zero = np.array((0,)*domain.geometry.dim, dtype=ScalarType)
bc = fem.dirichletbc(u_zero, fem.locate_dofs_topological(V, fdim, facet_markers.find(outside)), V)
# constituive relations - linear elasticity
E = fem.Constant(domain, ScalarType(10.))
nu = fem.Constant(domain, ScalarType(0.3))
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
    return sym(grad(v))
def sigma(v):
    return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
pen = fem.Constant(domain, ScalarType(1e4))
form = inner(sigma(u), eps(u_))*dx + pen*dot(u_, gap)*ds
J = derivative(form, u, du)
problem = fem.petsc.NonlinearProblem(form, u, bcs=[bc], J=J)
from dolfinx import nls
solver = nls.petsc.NewtonSolver(domain.comm, problem)
First of all gap is python-function, which is not supported as input to the form.
You should be able to use gap() as long as you define it correctly.
Note that gap is not a vector-valued function, which you can inspect by printing gap().ufl_shape. As you can see by printing u_.ufl_shape, the shape should be (2,) not () which would indicate a scalar valued expression.
Thanks for your help!
I have now changed the function name and tried to do the dot product by using the first dim of u_ only (just for syntax test purpose)
It seems, that ufl can not handle the expression itself.
Shape of pen_depth() - former gap():
Shape of u_[0]:
  File "/home/fenics/shared/mwe_rec_cropped.py", line 102, in <module>
    form = inner(sigma(u), eps(u_))*dx + pen*dot(u_[0], pen_depth)*ds
    b = as_ufl(b)
ufl.log.UFLValueError: Invalid type conversion: <function pen_depth at 0x7f85f0fcfd90> can not be converted to any UFL type.
As i said earlier, this has to be
form = inner(sigma(u), eps(u_))*dx + pen*dot(u_[0], pen_depth())*ds
If pen_depth is def pen_depth():….
