Issue with dolfinx.fem.Function.interpolate
You are interpolating a discontinuous function, i.e.
into a continuous space.
This will cause some interpolation error which can be manifested in non-symmetry.
Talking about smoothness, as the bending moment only depends on theta, which is a piecewise linear, the best you will get is a piecewise constant function.
Here using paraview to illustrate this:
Upon mesh refinement, the stresses gets better, in the sense that the jumps between each element becomes smaller: (40x40)
80x80
Script to reproduce the bp file can be found below:
import basix
from dolfinx import fem
from dolfinx.mesh import (
    CellType,
    DiagonalType,
    create_unit_square,
    locate_entities_boundary,
# from matplotlib import pyplot, tri as tri_plot
Based on:
https://bleyerj.github.io/comet-fenicsx/intro/plates/plates.html
https://jsdokken.com/dolfinx-tutorial/chapter2/linearelasticity_code.html
# number of elements per edge
N = 80
domain = create_unit_square(
    MPI.COMM_WORLD, N, N, cell_type=CellType.triangle, diagonal=DiagonalType.crossed
# material parameters
E = 31.45e9
nu = 0.2
kappa = 5.0 / 6.0
thick = 0.05
# bending stiffness
D = fem.Constant(domain, E * thick**3 / (1 - nu**2) / 12.0)
# shear stiffness
F = fem.Constant(domain, E / 2 / (1 + nu) * thick * 5.0 / 6.0)
# uniform transversal load
f = fem.Constant(domain, -1e5)
# Useful function for defining strains and stresses
def curvature(u):
    (w, theta) = ufl.split(u)
    return ufl.as_vector(
        [theta[0].dx(0), theta[1].dx(1), theta[0].dx(1) + theta[1].dx(0)]
def shear_strain(u):
    return ufl.grad(w) - theta
def bending_moment(u):
    DD = ufl.as_matrix([[D, nu * D, 0], [nu * D, D, 0], [0, 0, D * (1 - nu) / 2.0]])
    return ufl.dot(DD, curvature(u))
def shear_force(u):
    return F * shear_strain(u)
# Definition of function space for U:displacement, T:rotation
Ue = basix.ufl.element("P", domain.basix_cell(), 2)  # quadratic shape functions
Te = basix.ufl.element(
    "P", domain.basix_cell(), 1, shape=(2,)
)  # linear shape functions
V = fem.functionspace(domain, basix.ufl.mixed_element([Ue, Te]))
# Functions
u = fem.Function(V, name="Unknown")
u_ = ufl.TestFunction(V)
(w_, theta_) = ufl.split(u_)
du = ufl.TrialFunction(V)
# Linear and bilinear forms
dx = ufl.Measure("dx", domain=domain)
L = f * w_ * dx
a = (
    ufl.dot(bending_moment(u_), curvature(du))
    + ufl.dot(shear_force(u_), shear_strain(du))
) * dx
# Boundary of the plate
# Find all edges of unit square plate
def border(x):
    return np.logical_or(
        np.logical_or(np.isclose(x[0], 0), np.isclose(x[0], 1)),
        np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1)),
# fix displacement on the border
facet_dim = 1
sliding_facets = locate_entities_boundary(domain, facet_dim, border)
sliding_dofs = fem.locate_dofs_topological(V.sub(0), facet_dim, sliding_facets)
u0 = fem.Function(V)
bcs = [fem.dirichletbc(u0, sliding_dofs)]
# Solve the problem
problem = fem.petsc.LinearProblem(
    a, L, u=u, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
problem.solve()
# Get deflections
w_fun_space, w_idx = V.sub(0).collapse()
w_values = u.x.array[w_idx]
# Get stresses
bending_stress = bending_moment(u) * 6 / thick**2
# Create a function space for stress using a vector element with linear shape functions
V_sigma = fem.functionspace(
    domain,
    basix.ufl.element(
        "Lagrange", basix.CellType.triangle, 1, shape=(3,), discontinuous=True
# Define the stress expression
stress_expr = fem.Expression(bending_stress, V_sigma.element.interpolation_points())
# Create the function to store interpolated stresses
stresses = fem.Function(V_sigma)
stresses.interpolate(stress_expr)
# # get functionspace and indices of stress corresponding to sigma_x
# fs_x, idx_x = V_sigma.sub(0).collapse()
fs_x = stresses.sub(0).collapse()
import dolfinx.io
with dolfinx.io.VTXWriter(domain.comm, "stress.bp", [stresses]) as vtx:
    vtx.write(0.0)
