Good afternoon,
I tried this solution but the compliance doesn’t change at all with every iteration. There must be an issue somewhere:
#IMPORTS
from dolfinx import fem, cpp, io, mesh
#PARAMETERS
NITER_TOTAL=300
TOL=1e4
THETAMIN=0.001
NOMFICHIER="opti_test.xdmf"
M=0.2
ETA=0.5
PENAL=2
LMIN_INIT, LMAX_INIT = 0, 1e5
DENS_CIBLE=0.3
WEIGHT=1
LAMBDA=0.6
MU=0.4
L, W, H=0.303, 0.19, 0.064
EMP=0.06
AXE=0.025
BOTTOM_MARKER=1
AXES_MARKER=2
NX, NY, NZ = 30, 19, 6
#MESH CREATION
points=[np.array([0, 0, 0]), np.array([L, W, H])]
domain=mesh.create_box(
MPI.COMM_WORLD,
points,
[NX,NY,NZ],
cell_type=cpp.mesh.CellType.hexahedron,
ghost_mode=mesh.GhostMode.shared_facet
dim=domain.topology.dim
#BOUNDARY MARKERS
def axes(x):
return np.logical_and(
np.logical_or(np.sqrt( (x[0]-EMP)**2 + (x[2]-H/2)**2 ) <=AXE,
np.sqrt( (x[0]-L+EMP)**2 + (x[2]-H/2)**2 ) <=AXE),
np.logical_or(np.isclose(x[1], 0, atol=1e-6),
np.isclose(x[1], W, atol=1e-6))
def bottom(x):
return np.isclose(x[2], 0, atol=1e-6)
bottom_facets=mesh.locate_entities(domain, dim-1, bottom)
axes_facets=mesh.locate_entities(domain, dim-1, axes)
facet_indices=[bottom_facets,axes_facets]
facet_indices=np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers=[np.full(len(bottom_facets), BOTTOM_MARKER), np.full(len(axes_facets), AXES_MARKER)]
facet_markers=np.array(np.hstack(facet_markers), dtype=np.int32)
sorted_facets=np.argsort(facet_indices)
facet_tag=mesh.meshtags(
domain,
dim-1,
facet_indices[sorted_facets],
facet_markers[sorted_facets]
#LOADS AND BC
U=fem.VectorFunctionSpace(domain, ("CG", 1))
u=fem.Function(U, name="Déplacement")
bcdofs=fem.locate_dofs_geometrical(U, axes)
u_0=np.array((0,)*dim, dtype=PETSc.ScalarType)
bc=fem.dirichletbc(u_0, bcdofs, U)
ds= ufl.Measure("ds", domain=domain, subdomain_data=facet_tag)
bottom_surf=fem.assemble_scalar(fem.form(fem.Constant(domain, 1.)*ds(1)))
def eps(v):
return ufl.sym(ufl.grad(v))
def sigma(v):
return (LAMBDA*ufl.nabla_div(v)*ufl.Identity(dim)+2*MU*eps(v))
def dE(u, v):
return ufl.inner(sigma(u), eps(v))/2
#DENSITY SET UP
T=fem.FunctionSpace(domain, ("DG", 0))
density_old=fem.Function(T)
density=fem.Function(T, name="Density")
def homogenous(x):
return np.full(len(x[0]), DENS_CIBLE)
density.interpolate(homogenous)
VOL=fem.assemble_scalar(fem.form(fem.Constant(domain, 1.)*ufl.dx))
frac_init=fem.assemble_scalar(fem.form(density_old*ufl.dx))/VOL
#VARIATONAL PROBLEM
u_=ufl.TestFunction(U)
du=ufl.TrialFunction(U)
a=ufl.inner(density**PENAL*sigma(u_), eps(du))*ufl.dx
b=ufl.dot((WEIGHT/bottom_surf)*ufl.FacetNormal(domain), u_)*ds(1)
solver=PETSc.KSP().create(domain.comm)
OPTIONS=PETSc.Options()
OPTIONS["ksp_type"]="cg"
OPTIONS["ksp_atol"]=1.0e-10
OPTIONS["pc_type"]="ilu"
solver.setFromOptions()
compliance_history=[]
compliance_old=1e30
file = io.XDMFFile(domain.comm, NOMFICHIER, 'w')
file.write_mesh(domain)
#OPTIMISATION LOOP
for i in range(NITER_TOTAL):
density_old.interpolate(density)
#SOLVE
A=fem.petsc.assemble_matrix(fem.form(a), bcs=[bc])
B=fem.petsc.assemble_vector(fem.form(b))
fem.petsc.apply_lifting(B, [fem.form(a)], bcs=[[bc]])
B.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(B, [bc])
solver.setOperators(A)
iter_solve=solver.solve(B, u.vector)
u.x.scatter_forward()
file.write_function(density_old, i)
file.write_function(u, i)
#OPTIMISATION CRITERIA
sensitivity=-PENAL*density**(PENAL-1)*dE(u,u)
#LAGRANGE MULTIPLIER FINDER (DICHOTOMY)
lmin, lmax=LMIN_INIT, LMAX_INIT
while lmax-lmin>TOL:
lmoy=(lmin+lmax)/2
densitynew=fem.Function(T)
densitynew.interpolate(fem.Expression((-sensitivity/lmoy)**ETA, T.element.interpolation_points))
criterion=np.maximum(THETAMIN,
np.maximum(density_old.vector-M,
np.minimum(1,
np.minimum(density_old.vector+M,
density.vector
densitynew.vector.setArray(criterion)
frac=fem.assemble_scalar(fem.form(densitynew*ufl.dx))/VOL
if frac-frac_init>0:
lmin=lmoy
lmax=lmoy
density.vector.setArray(densitynew.vector.getArray())
compliance=fem.assemble_scalar(fem.form(ufl.action(b,u)))
compliance_history.append(compliance)
print("Iteration {}: compliance=".format(i), compliance)
file.close()
Please excuse le if the code isn’t the most minimal, just don’t want to break the code already working.
Thanks again!
