Issue with modification of solution vector in parallel implementation
I am trying to modify my solution vector based on a condition, the condition being if anywhere over the mesh the function has a value greater than 1 then I would like to bound that value to one before writing to the xdmf file.
u.vector().vec().array[u.vector()[:] > 1] = 1
Here is the minimum code
# MPI functions
comm = MPI.comm_world
xdmf = XDMFFile(comm,"output/disp.xdmf")
mesh = UnitSquareMesh(80, 80)
u_D = Expression('2*sin(M_PI *x[0])', degree=1)
u = project(u_D, V) # supposing this is the solution from a solver
u.vector().vec().array[u.vector()[:] > 1] = 1 # This is not working for parallel implementation
xdmf.write(u)
The above code works perfectly fine in serial, but breaks in parallel.
I have also attached the contour of solution for both serial and parallel implementation.
Any help will be highly appreciated. Thank you.
Don’t forget to update the ghost values:
u.vector().update_ghost_values()
Thank you so much Nate. It is working :blush:
