I can’t seem to figure out how to correctly set the x0 argument of multiphenicsx.fem.set_bc and multiphenicsx.fem.apply_lifting.
In this MWE I solve incrementally a linear heat equation on the left side of the unit square with Dirichlet heating on the “outside” boundary and the middle boundary is insulated:
import multiphenicsx
import multiphenicsx.fem.petsc
import petsc4py
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
def main():
# Mesh and problems
points_per_side = 8
domain = mesh.create_unit_square(MPI.COMM_WORLD, points_per_side, points_per_side, mesh.CellType.quadrilateral)
tdim = domain.topology.dim
CG1 = fem.functionspace(domain, ("Lagrange", 1),)
DG0 = fem.functionspace(domain, ("Discontinuous Lagrange", 0),)
domain.topology.create_entities(tdim)
domain.topology.create_entities(tdim-1)
domain.topology.create_connectivity(tdim,tdim)
cell_map = domain.topology.index_map(tdim)
# Activation
active_els = fem.locate_dofs_geometrical(DG0, lambda x : x[0] <= 0.5 )
active_els_func = fem.Function(DG0,name="active_els")
active_els_func.x.array[active_els] = 1.0
active_dofs = fem.locate_dofs_topological(CG1, tdim, active_els,remote=True)
restriction = multiphenicsx.fem.DofMapRestriction(CG1.dofmap, active_dofs)
# Parameters
dt = fem.Constant(domain, 0.1)
k = fem.Constant(domain, 1.0)
c_p = fem.Constant(domain, 1.0)
rho = fem.Constant(domain, 1.0)
T_hot = 2.0
T_cold = 0.0
num_timesteps = 5
unp1 = fem.Function(CG1, name="unp1")
un = fem.Function(CG1, name="un")
udc = fem.Function(CG1, name="dirichlet")
du = fem.Function(CG1, name="delta_uh")
alg_rhs = fem.Function(CG1, name="rhs")
# Dirichlet BC
def left_marker_dirichlet(x):
return np.logical_or( np.isclose(x[1],1), np.logical_or(
np.isclose(x[0],0), np.isclose(x[1],0)) )
dirichlet_dofs = fem.locate_dofs_geometrical(CG1,left_marker_dirichlet)
dirichlet_bcs = [fem.dirichletbc(udc, dirichlet_dofs)]
# Forms
local_active_els = active_els_func.x.array.nonzero()[0][:np.searchsorted(active_els_func.x.array.nonzero()[0], cell_map.size_local)]
subdomain_idx = 1
dx = ufl.Measure("dx", subdomain_data=[(subdomain_idx,local_active_els)])
(u, v) = (ufl.TrialFunction(CG1), ufl.TestFunction(CG1))
a_ufl = k*ufl.dot(ufl.grad(u), ufl.grad(v))*dx(subdomain_idx)
a_ufl += (rho*c_p/dt)*u*v*dx(subdomain_idx)
l_ufl = (rho*c_p/dt)*un*v*dx(subdomain_idx)
a_compiled = fem.form(a_ufl)
l_compiled = fem.form(l_ufl)
# Normal solve
A = multiphenicsx.fem.petsc.create_matrix(a_compiled, (restriction, restriction),)
L = multiphenicsx.fem.petsc.create_vector(l_compiled, restriction)
x = multiphenicsx.fem.petsc.create_vector(l_compiled, restriction=restriction)
time = 0.0
unp1.x.array[:] = T_cold
udc.x.array[:] = T_hot
vtk_writer = io.VTKFile(domain.comm, f"post/normal.pvd", "wb")
for titer in range(num_timesteps):
time += dt.value
un.x.array[:] = unp1.x.array[:]
# ASSEMBLE
A.zeroEntries()
multiphenicsx.fem.petsc.assemble_matrix(A,
a_compiled,
bcs=dirichlet_bcs,
restriction=(restriction, restriction))
with L.localForm() as l_local:
l_local.set(0.0)
multiphenicsx.fem.petsc.assemble_vector(L,
l_compiled,
restriction=restriction,)
multiphenicsx.fem.petsc.apply_lifting(L, [a_compiled], [dirichlet_bcs], restriction=restriction,)
L.ghostUpdate(addv=petsc4py.PETSc.InsertMode.ADD, mode=petsc4py.PETSc.ScatterMode.REVERSE)
multiphenicsx.fem.petsc.set_bc(L,dirichlet_bcs,restriction=restriction)
# LINEAR SOLVE
opts = {"pc_type" : "lu", "pc_factor_mat_solver_type" : "mumps",}
with x.localForm() as x_local:
x_local.set(0.0)
ksp = petsc4py.PETSc.KSP()
ksp.create(domain.comm)
ksp.setOperators(A)
ksp_opts = PETSc.Options()
for key,value in opts.items():
ksp_opts[key] = value
ksp.setFromOptions()
ksp.solve(L, x)
x.ghostUpdate(addv=petsc4py.PETSc.InsertMode.INSERT, mode=petsc4py.PETSc.ScatterMode.FORWARD)
ksp.destroy()
# Unrestrict solution
with unp1.x.petsc_vec.localForm() as usub_vector_local, \
multiphenicsx.fem.petsc.VecSubVectorWrapper(x, CG1.dofmap, restriction) as x_wrapper:
usub_vector_local[:] = x_wrapper
unp1.x.scatter_forward()
vtk_writer.write_function([unp1,un,udc,active_els_func],t=time)
vtk_writer.close()
for la_ds in [A, L, x]:
la_ds.destroy()
# Incremental solve
(u, v) = (unp1, ufl.TestFunction(CG1))
r_ufl = a_ufl - l_ufl
j_ufl = ufl.derivative(a_ufl,unp1)
j_compiled = fem.form(j_ufl)
r_compiled = fem.form(r_ufl)
A = multiphenicsx.fem.petsc.create_matrix(j_compiled, (restriction, restriction),)
L = multiphenicsx.fem.petsc.create_vector(r_compiled, restriction)
x = multiphenicsx.fem.petsc.create_vector(r_compiled, restriction=restriction)
time = 0.0
vtk_writer = io.VTKFile(domain.comm, f"post/incremenetal.pvd", "wb")
time += dt.value
# ASSEMBLE
A.zeroEntries()
j_compiled,
bcs=dirichlet_bcs,
l_local.set(0.0)
r_compiled,
L.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
L.scale(-1)
# Dirichlet
multiphenicsx.fem.petsc.apply_lifting(L, [j_compiled], [dirichlet_bcs], x0=[unp1.x.petsc_vec], restriction=restriction)
multiphenicsx.fem.petsc.set_bc(L,dirichlet_bcs, x0=unp1.x.petsc_vec, restriction=restriction)
L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
# RHS to function
with alg_rhs.x.petsc_vec.localForm() as lfunsub_vector_local, \
multiphenicsx.fem.petsc.VecSubVectorWrapper(L, CG1.dofmap, restriction) as l_wrapper:
lfunsub_vector_local[:] = l_wrapper
alg_rhs.x.scatter_forward()
# LINEAR SOLVE
x_local.set(0.0)
ksp.setOperators(A)
for k,v in opts.items():
ksp_opts[k] = v
ksp.solve(L, x)
ksp.destroy()
with du.x.petsc_vec.localForm() as dusub_vector_local, \
dusub_vector_local[:] = x_wrapper
du.x.scatter_forward()
unp1.x.array[:] += du.x.array[:]
vtk_writer.write_function([unp1,un,udc,active_els_func,alg_rhs],t=time)
vtk_writer.close()
la_ds.destroy()
if __name__=="__main__":
main()
There is a a “normal” solve commented out and an incremental solve (residual, jacobian) both using multiphenicsx. First two time-steps of both:
At the first time-step, both solves obtain the same thing. At the second time-step, my incremental solve doesn’t apply correctly the Dirichlet BC. The RHS at the second time-step should be zero at the Dirichlet nodes after calling multiphenicsx.fem.petsc.set_bc but it is not in my case. It is mostly zero except at some nodes:
I’m working with the latest commits of dolfinx, multiphenicsx, etc. on the test-env docker container. Any help is appreciated.
@francesco-ballarin please could you have a look?
