Hi all,
I created my quadrilateral mesh using SALOME and then imported it into my code. After generating the .xdmf and .h5 files, I encountered an issue when trying to use them: there seems to be a mismatch between the orientation in the .xdmf file and what FEniCS 2019 expects.
Here is the error message I get:
RuntimeError:
DOLFIN encountered an error. If you are not able to resolve this issue
using the information listed below, you can ask for help at
fenics-support@googlegroups.com
Remember to include the error message listed below and, if possible,
Error: Unable to order quadrilateral cell.
Reason: Cell is not orderable.
Where: This error was encountered inside QuadrilateralCell.cpp.
Process: 0
DOLFIN version: 2019.1.0
Git changeset: ec7503cef5f328d4927ba1050abe55c3519ac4e9
Could you please help me solve this problem?
I’m also attaching my conversion script used to transform the .med file into .xdmf/.h5 format:
msh = meshio.read(".../Mesh_Tun_EURO_FLiBe_NEW_quadr.med")
print("CELLS:", msh.cells)
print("CELL DATA:", msh.cell_data_dict.keys())
print("CELL SETS:", msh.cell_sets)
print("FIELD DATA:", msh.field_data)
def check_unorderable_quads(points, quads):
bad_cells = [ ]
for i, q in enumerate(quads):
pts = points[q, :2]
area = 0.5 * (
(pts[0,0]*pts[1,1] + pts[1,0]*pts[2,1] +
pts[2,0]*pts[3,1] + pts[3,0]*pts[0,1]) -
(pts[1,0]*pts[0,1] + pts[2,0]*pts[1,1] +
pts[3,0]*pts[2,1] + pts[0,0]*pts[3,1])
if abs(area) < 1e-12 or np.isnan(area):
bad_cells.append(i)
return bad_cells
quads = msh.cells_dict["quad"]
bad = check_unorderable_quads(msh.points, quads)
def fix_quad_order(points, quads):
fixed_quads = []
inverted = 0
for q in quads:
pts = points[q, :2]
# Calcola il baricentro
cx, cy = pts.mean(axis=0)
angles = np.arctan2(pts[:, 1] - cy, pts[:, 0] - cx)
order = np.argsort(angles)
q_new = q[order]
area = (
(pts[1,0] - pts[0,0]) * (pts[1,1] + pts[0,1]) +
(pts[2,0] - pts[1,0]) * (pts[2,1] + pts[1,1]) +
(pts[3,0] - pts[2,0]) * (pts[3,1] + pts[2,1]) +
(pts[0,0] - pts[3,0]) * (pts[0,1] + pts[3,1])
if area > 0:
q_new = q_new[[0, 3, 2, 1]]
inverted += 1
q_new = q_new[[0, 1, 2, 3]]
fixed_quads.append(q_new)
return np.array(fixed_quads, dtype=int)
def convert_med_to_xdmf(
med_file,
cell_file="mesh_domains.xdmf",
facet_file="mesh_boundaries.xdmf",
cell_type="quad",
facet_type="line",
Converte un file MED in XDMF correggendo l'ordine dei vertici
per compatibilità con FEniCS 2019.1 (quadrilateri antiorari)."""
msh = meshio.read(med_file)
correspondance_dict = msh.cell_tags
cell_data_types = msh.cell_data_dict["cell_tags"].keys()
for mesh_block in msh.cells:
if mesh_block.type == cell_type:
quads = mesh_block.data
quads_fixed = fix_quad_order(msh.points, quads)
meshio.write_points_cells(
cell_file,
msh.points,
[meshio.CellBlock(cell_type, quads_fixed)],
cell_data={"f": [-1 * msh.cell_data_dict["cell_tags"][cell_type]]},
elif mesh_block.type == facet_type:
facet_file,
msh.points,
[mesh_block],
cell_data={"f": [-1 * msh.cell_data_dict["cell_tags"][facet_type]]}, )
return correspondance_dict, cell_data_types
correspondance_dict, cell_data_types = convert_med_to_xdmf(
"...Mesh_Tun_EURO_FLiBe_NEW_quadr.med",
cell_file=".../mesh_domains.xdmf",
facet_file=".../mesh_boundaries.xdmf"
mesh = meshio.read(".../mesh_domains.xdmf")
print(mesh)
mesh_bnd = meshio.read(".../mesh_boundaries.xdmf")
print(mesh_bnd)
Thank you very much for your help!
Best regards,
Andrea.
