I installed fenics on ubuntu 18.04 and I want to run the poisson demo on the ubuntu 18.04 terminal , unfortunately it gives the gives following message an i as a beginner do not know how to solve this,
I would be thankful if u could help me to run my first simulation with fenics.
Here is my command to run:
mhd@mhd-N552VW:/usr/share/dolfin/demo-python/documented/poisson$ python3 demo_poisson.py
Here is the result:
File “demo_poisson.py”, line 90, in
V = FunctionSpace(mesh, “Lagrange”, 1)
File “/usr/lib/python3/dist-packages/dolfin/function/functionspace.py”, line 33, in init
self._init_convenience(*args, **kwargs)
File “/usr/lib/python3/dist-packages/dolfin/function/functionspace.py”, line 100, in _init_convenience
self._init_from_ufl(mesh, element, constrained_domain=constrained_domain)
File “/usr/lib/python3/dist-packages/dolfin/function/functionspace.py”, line 43, in _init_from_ufl
mpi_comm=mesh.mpi_comm())
File “/usr/lib/python3/dist-packages/dolfin/jit/jit.py”, line 47, in mpi_jit
File “/usr/lib/python3/dist-packages/dolfin/jit/jit.py”, line 97, in ffc_jit
File “/usr/lib/python3/dist-packages/ffc/jitcompiler.py”, line 217, in jit
module = jit_build(ufl_object, module_name, parameters)
File “/usr/lib/python3/dist-packages/ffc/jitcompiler.py”, line 133, in jit_build
generate=jit_generate)
File “/usr/lib/python3/dist-packages/dijitso/jit.py”, line 178, in jit
params)
File “/usr/lib/python3/dist-packages/dijitso/build.py”, line 153, in build_shared_library
status, output = get_status_output(cmd)
File “/usr/lib/python3/dist-packages/dijitso/system.py”, line 41, in _get_status_output_subprocess
stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
File “/usr/lib/python3.6/subprocess.py”, line 709, in init
restore_signals, start_new_session)
File “/usr/lib/python3.6/subprocess.py”, line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘c++’: ‘c++’
