I installed Fenics on Windows Subsystem for Linux (Ubuntu 18.04), using
sudo apt-get install software-properties-common
sudo apt-get update
sudo apt-get install --no-install-recommends fenics
I tried to run demo code ft01_poisson.py
mesh = UnitSquareMesh(8, 8)
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
but first I got an error importing matplotlib, which I solved by installing it through
sudo apt-get install python3-matplotlib
(I’m running the demo code in Python3).
Then I got and error with FunctionSpace, which was solved adding
in the preamble (I don’t know if it was the right way to solve it).
After that I got the following error at Expression line
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 167, in compile_class
mpi_comm=mpi_comm)
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 47, in mpi_jit
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 103, in dijitso_jit
return dijitso.jit(*args, **kwargs)
File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 178, in jit
params)
File "/usr/lib/python3/dist-packages/dijitso/build.py", line 153, in build_shared_library
status, output = get_status_output(cmd)
File "/usr/lib/python3/dist-packages/dijitso/system.py", line 41, in _get_status_output_subprocess
stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
File "/usr/lib/python3.6/subprocess.py", line 709, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.6/subprocess.py", line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'c++': 'c++'
File "<stdin>", line 1, in <module>
File "/usr/lib/python3/dist-packages/dolfin/function/expression.py", line 376, in __init__
File "/usr/lib/python3/dist-packages/dolfin/function/jit.py", line 158, in compile_expression
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 170, in compile_class
raise RuntimeError("Unable to compile C++ code with dijitso")
Thanks in advance for any clue.
