Dear FEniCS community,
I’m currently working on the implementation of the Three Network Model for nonlinear viscoelasticity.
My code is structured following two similar FEniCS examples:
- Linear Viscoelasticity – COMET-FEniCS documentation
- Discussion on a viscoelastic problem – FEniCS Discourse
I’ve formulated a three-field variational problem to solve for the displacement field u and the two internal deformation gradient fields FvA and FvB.
However, I suspect there’s a problem with how I’m initializing or updating FvA and FvB, because when I print their values for debugging, both appear as zero matrices throughout the domain.
Has anyone encountered a similar issue or could suggest how to correctly initialize and evolve internal tensor fields like FvA and FvB in a mixed function space?
Thanks in advance for your help!
Here is the code:
from dolfinx import *
from dolfinx.io import gmshio
import pyvista
import math
import os
import sys
import pyvista
from dolfinx import mesh, fem, plot, default_scalar_type, log
from dolfinx.fem import dirichletbc, locate_dofs_topological, Function
from dolfinx.mesh import locate_entities_boundary
length = 10
width = 4
depth = 2
num_ele_along_depth = 4
size_ele = depth/num_ele_along_depth
n = [int(length/size_ele), int(width/size_ele), int(depth/size_ele)]
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([length, width, depth])], n, cell_type=mesh.CellType.hexahedron)
tdim = domain.topology.dim # Topological dimension
dim = domain.topology.dim - 1 # Facets are one dimension lower than the domain
######### Define the function space #########
element_u = element("CG", domain.ufl_cell().cellname(), 2, shape=(tdim,)) # Displacement field
element_FvA = element("DG", domain.ufl_cell().cellname(), 0, shape=(tdim,tdim)) # FvA field
element_FvB = element("DG", domain.ufl_cell().cellname(), 0, shape=(tdim,tdim)) # FvB field
mixedelement = mixed_element([element_u, element_FvA, element_FvB]) # Mixed element for the function space
M = fem.functionspace(domain, mixedelement)
V, _ = M.sub(0).collapse() #Displacement
print("Number of DoFs in displacement:", V.dofmap.index_map.size_global) #DoFs 9328
V1, V1_to_M1 = M.sub(1).collapse() #Fv field A
print("Number of DoFs in Fv field A:", V1.dofmap.index_map.size_global)
V2, V2_to_M1 = M.sub(2).collapse() #Fv field B
print("Number of DoFs in Fv field B:", V2.dofmap.index_map.size_global)
# Coordinate X = 0
def boundary_x0(x):
return np.isclose(x[0], 0.0)
facets_x0 = locate_entities_boundary(domain, dim, boundary_x0)
dofs_x0 = locate_dofs_topological((M.sub(0), V), dim, facets_x0)
zero_displacement = Function(V)
zero_displacement.x.array[:] = 0.0
bc_x0 = dirichletbc(zero_displacement, dofs_x0, M.sub(0))
bcs = [bc_x0]
####### VARIATIONAL FORMULATION #######
v = ufl.TestFunctions(M)
δu, δFvA, δFvB = v
m = fem.Function(M)
u, FvA, FvB = ufl.split(m)
print(f"u: {u.ufl_shape}")
print(f"FvA: {FvA.ufl_shape}")
print(f"FvB: {FvB.ufl_shape}")
# Saving the function at the previous time step
m_old = fem.Function(M) # to store all previous fields
u_old, Fv_oldA, Fv_oldB= ufl.split(m_old) # to access individual components
print(f"u_old: {u_old.ufl_shape}")
print(f"FvA_old: {Fv_oldA.ufl_shape}")
print(f"FvB_old: {Fv_oldB.ufl_shape}")
# ####### VARIATIONAL FORMULATION #######
#Traction vector
#Body force vector
B = fem.Constant(domain, default_scalar_type((0, -1, 0)))
#Material parameters
Bulk_Modulus=default_scalar_type(1000) #Considered as compressible materials
K=fem.Constant(domain, Bulk_Modulus)
#Material parameters for network A
MUA= fem.Constant(domain, default_scalar_type(15.58)) #Shear modulus network A
LAMBDAL= fem.Constant(domain, default_scalar_type(6.28)) #Lambda lock -- the same for all networks
TAUHATA= fem.Constant(domain, default_scalar_type(11.57)) #tauhat
MA=fem.Constant(domain, default_scalar_type(9.51))
#Material parameters for network B
MUBI=fem.Constant(domain, default_scalar_type(47.25)) #Initial Shear modulus network B
MUBF=fem.Constant(domain, default_scalar_type(1.32)) #Final Shear modulus network B
BETA=fem.Constant(domain, default_scalar_type(4.19)) #BETA
TAUHATB=fem.Constant(domain, default_scalar_type(39.56))
MB=fem.Constant(domain, default_scalar_type(14.67))
#Material parameters for network C
MUC=fem.Constant(domain, default_scalar_type(6.27))
State_value_n= fem.functionspace(domain, ("Lagrange", 1))
State_value_d= fem.functionspace(domain, ("Lagrange", 1))
V_viss = fem.functionspace(domain, ("Lagrange", 1))
def inv_Langevin(ED_chainstretch):
# Padè approximation for the inverse Langevin function
ED_limited = ufl.min_value(ED_chainstretch, 0.99)
L_inv = (ED_limited*(3-ED_limited**2))/(1-ED_limited**2)
chainstretch_expr = fem.Expression(ED_limited, V_viss.element.interpolation_points())
chainstretch_fn = fem.Function(V_viss)
chainstretch_fn.interpolate(chainstretch_expr)
print("Max chain stretch:", np.max(np.abs(chainstretch_fn.x.array)))
return L_inv
# Cauchy stress tensor for the Eight Chain model
def cauchy_stress_EC(FF_local, shear_modulus, lambdalock, K_local):
# Identity tensor
I_local = ufl.variable(ufl.Identity(3))
C_local = ufl.variable(ufl.transpose(FF_local) * FF_local)
J_local = ufl.max_value(ufl.variable(ufl.det(FF_local)), 1e-8)
b_local=ufl.variable(FF_local*ufl.transpose(FF_local))
b_local_dist = ufl.variable((J_local**(-2/3))*b_local)
Ib1_local = ufl.variable(ufl.tr(b_local))
Ib1_dist_local = ufl.variable(ufl.tr(b_local_dist))
Ic1_local = ufl.variable(ufl.tr(C_local))
Ic1_dist_local = ufl.variable((J_local**(-2/3))*ufl.tr(C_local))
eff_dist_chainstrech= ufl.max_value(ufl.variable(ufl.sqrt(Ic1_dist_local/3)), 1e-8)
chainstretch_expr2 = fem.Expression(eff_dist_chainstrech, V_viss.element.interpolation_points())
chainstretch_fn2 = fem.Function(V_viss)
chainstretch_fn2.interpolate(chainstretch_expr2)
print("Max chain stretch 2:", np.max(np.abs(chainstretch_fn2.x.array)))
# Calcola l'argomento di inv_Langevin
langevin_arg_n = ufl.variable(eff_dist_chainstrech / lambdalock)
# Calcola anche il valore della funzione inv_Langevin sull'argomento
langevin_val_n = ufl.variable(inv_Langevin(langevin_arg_n))
# Interpola entrambi in funzioni FEM per il debug numerico
langevin_arg_expr_n = fem.Expression(langevin_arg_n, State_value_n.element.interpolation_points(), domain.comm)
langevin_val_expr_n = fem.Expression(langevin_val_n, State_value_n.element.interpolation_points(), domain.comm)
langevin_arg_fn_n = fem.Function(State_value_n)
langevin_val_fn_n = fem.Function(State_value_n)
langevin_arg_fn_n.interpolate(langevin_arg_expr_n)
langevin_val_fn_n.interpolate(langevin_val_expr_n)
# Stampa i valori estremi
print("[DEBUG] Langevin argument NUMERATORE (eff_dist_chainstrech / lambdalock):")
print(" min =", np.min(langevin_arg_fn_n.x.array), "max =", np.max(langevin_arg_fn_n.x.array))
print("[DEBUG] NUMERATORE inv_Langevin(argument):")
print(" min =", np.min(langevin_val_fn_n.x.array), "max =", np.max(langevin_val_fn_n.x.array))
langevin_arg_d = ufl.variable(1/ lambdalock)
langevin_val_d = ufl.variable(inv_Langevin(langevin_arg_d))
langevin_arg_expr_d = fem.Expression(langevin_arg_d, State_value_d.element.interpolation_points(), domain.comm)
langevin_val_expr_d = fem.Expression(langevin_val_d, State_value_d.element.interpolation_points(), domain.comm)
langevin_arg_fn_d = fem.Function(State_value_d)
langevin_val_fn_d = fem.Function(State_value_d)
langevin_arg_fn_d.interpolate(langevin_arg_expr_d)
langevin_val_fn_d.interpolate(langevin_val_expr_d)
print("[DEBUG] Langevin argument DENOMINATORE (eff_dist_chainstrech / lambdalock):")
print(" min =", np.min(langevin_arg_fn_d.x.array), "max =", np.max(langevin_arg_fn_d.x.array))
print("[DEBUG] DENOMINATORE inv_Langevin(argument):")
print(" min =", np.min(langevin_val_fn_d.x.array), "max =", np.max(langevin_val_fn_d.x.array))
numeratore = inv_Langevin(eff_dist_chainstrech/lambdalock)
denominatore = (inv_Langevin(1/lambdalock))
part1=(shear_modulus/(J_local*eff_dist_chainstrech))*((numeratore)/(denominatore))
part2=part1*(b_local_dist-((1/3)*Ib1_dist_local*I_local))
return part2 + K_local*(J_local-1)*I_local
State_value = fem.functionspace(domain, ("Lagrange", 1))
State_tensor= fem.functionspace(domain, ("Lagrange", 1, (tdim,tdim)))
State_vector = fem.functionspace(domain, ("Lagrange", 1, (tdim,)))
#Inizializzazione FvA
initial_stateFviA = ufl.Identity(3)
initial_stateFviA_exp = fem.Expression(initial_stateFviA, V1.element.interpolation_points(), domain.comm)
initial_stateFviA_fn = fem.Function(V1)
initial_stateFviA_fn.interpolate(initial_stateFviA_exp)
m_old.x.array[V1_to_M1] = initial_stateFviA_fn.x.array
#m.x.array[V1_to_M1] = initial_stateFviA_fn.x.array
initial_stateFviB = ufl.Identity(3) # V2: spazio per FvB
initial_stateFviB_exp = fem.Expression(initial_stateFviB, V2.element.interpolation_points(), domain.comm)
initial_stateFviB_fn = fem.Function(V2)
initial_stateFviB_fn.interpolate(initial_stateFviB_exp)
m_old.x.array[V2_to_M1] = initial_stateFviB_fn.x.array
print(np.isnan(m_old.x.array).any())
#m.x.array[V2_to_M1] = initial_stateFviB_fn.x.array
state_muB_in = MUBI #Initial shear modulus of network B
state_muB_current = fem.Constant(domain, default_scalar_type(0)) #Current state variable for the shear modulus of network B
tau_C=fem.Constant(domain, default_scalar_type(0.001))
freq = 0.05 # Time step size
deltaT = freq #time step size
d = len(u) # Spatial dimension
I = ufl.variable(ufl.Identity(d)) # Identity tensor
F_new = ufl.variable(I + ufl.grad(u))
##F=F_el*F_vi
FelasticA_new = ufl.variable(F_new*ufl.inv(FvA))
FelasticB_new = ufl.variable(F_new*ufl.inv(FvB))
Cv_Anew = ufl.variable(ufl.transpose(FvA)*(FvA))
Cv_Aold = ufl.variable(ufl.transpose(Fv_oldA)*(Fv_oldA)) #CvA at the previous time step
Cv_Bnew = ufl.variable(ufl.transpose(FvB)*(FvB))
Cv_Bold = ufl.variable(ufl.transpose(Fv_oldB)*(Fv_oldB)) #CvB at the previous time step
#Network A
Cauchy_stress_A = cauchy_stress_EC(FelasticA_new, MUA, LAMBDAL, K)
dev_stressA =(Cauchy_stress_A-((1/3)*ufl.tr(Cauchy_stress_A)*I))
eps = 1e-8
tau_A = ufl.sqrt(ufl.tr(ufl.dot(dev_stressA,dev_stressA))) #Frobenius norm
hydr_pressure_A = -ufl.tr(Cauchy_stress_A)/3
RampA = (hydr_pressure_A+ufl.sqrt(hydr_pressure_A**2))/2
argA= ufl.conditional(ufl.gt(tau_A/(TAUHATA + RampA) - tau_C, 0.0),
0.0)
deltagammaA =(argA)**MA #Delta gamma A
f_A = 2*ufl.transpose(Fv_oldA)*deltagammaA*(dev_stressA/tau_A) * Fv_oldA
#Network B
state_muB_current = - BETA*(state_muB_in-MUBF)*(deltagammaA)*deltaT + state_muB_in
Cauchy_stress_B= cauchy_stress_EC(FelasticB_new, state_muB_current, LAMBDAL, K)
dev_stressB=(Cauchy_stress_B-((1/3)*ufl.tr(Cauchy_stress_B)*I))
tau_B=ufl.sqrt(ufl.tr(ufl.dot(dev_stressB,dev_stressB))) #Frobenius norm
hydr_pressure_B=-ufl.tr(Cauchy_stress_B)/3 #Ho levato qui il meno
RampB=(hydr_pressure_B+ufl.sqrt(hydr_pressure_A**2))/2
argB= ufl.conditional(ufl.gt(tau_B/(TAUHATB + RampB) - tau_C, 0.0),
0.0)
deltagammaB =(argB)**MB #Delta gamma B
f_B = 2*ufl.transpose(Fv_oldB)*deltagammaB*(dev_stressB/tau_B) * Fv_oldB
# Network C
CS_NetworkC = cauchy_stress_EC(F_new, MUC, LAMBDAL, K)
deltaCvA=(Cv_Anew-Cv_Aold)
deltaCvB=(Cv_Bnew-Cv_Bold)
def δe(test_function_local):
return ufl.sym(ufl.grad(test_function_local)) #Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
ds = ufl.Measure('ds', domain=domain, metadata=metadata)
dx = ufl.Measure("dx", domain=domain, metadata=metadata) # Elementarily volume
F_int_A= ufl.inner(Cauchy_stress_A, δe(δu))*dx + ufl.inner(deltaCvA,δFvA)*dx - deltaT*ufl.inner(f_A, δFvA)*dx
F_int_B= ufl.inner(Cauchy_stress_B, δe(δu))*dx + ufl.inner(deltaCvB,δFvB)*dx - deltaT*ufl.inner(f_B, δFvB)*dx
F_int_C= ufl.inner(CS_NetworkC, δe(δu))*dx
F_ext= - ufl.inner(δu, B) * dx - ufl.inner(δu, T) * ds
Variational= F_int_A + F_int_C + F_ext
def bc_vec_moving(x, rate, time):
x = np.asarray(x)
dim = x.shape[0]
num_points = x.shape[1]
disp = np.zeros((dim, num_points), dtype=PETSc.ScalarType)
disp[0, :] = rate * time # Spostamento lungo x
return disp
def boundary_xL(x):
return np.isclose(x[0], length)
facets_xL = locate_entities_boundary(domain, dim, boundary_xL)
dofs_xL = locate_dofs_topological((M.sub(0), V), dim, facets_xL)
######## VISUALIZATION ########
#Function space for visualization
V_vis = fem.functionspace(domain, ("Lagrange", 1, (3,)))
TS = fem.functionspace(domain, ("DG", 0,(3, 3))) #True stress tensor
print(f"Number of DoFs in True Stress Tensor: {TS.dofmap.index_map.size_global}")
uh_vis_list = []
true_stress_vis_list =[]
with io.XDMFFile(domain.comm, "Viscoplasticity/results_1.xdmf", "w") as outfile:
outfile.write_mesh(domain) # write mesh once
t_end = 0.20 # Total simulation time
t = 0.10
step = 1
list_bc_m = []
while t <= t_end:
print(f"Time step {step}, time: {t:.2f}")
#### DEBUG NUMERICO u
arg_expr_n = fem.Expression(u, State_vector.element.interpolation_points(), domain.comm)
arg_fn_n = fem.Function(State_vector)
arg_fn_n.interpolate(arg_expr_n)
print("[DEBUG] u:")
print(" min =", np.min(arg_fn_n.x.array), "max =", np.max(arg_fn_n.x.array))
print("u new at first cell:", arg_fn_n.x.array[:3].reshape(3))
#### DEBUG NUMERICO F_new
arg_expr_n = fem.Expression(F_new, State_tensor.element.interpolation_points(), domain.comm)
arg_fn_n = fem.Function(State_tensor)
print("[DEBUG] F_new:")
print("F new tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO det(F_new)
detF_expr = fem.Expression(ufl.det(F_new), State_value.element.interpolation_points(), domain.comm)
detF_fn = fem.Function(State_value)
detF_fn.interpolate(detF_expr)
print(f"[t = {t:.2f}] det(F): min={np.min(detF_fn.x.array)}, max={np.max(detF_fn.x.array)}")
#### DEBUG NUMERICO FelasticA_new
arg_expr_n = fem.Expression(FelasticA_new, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] FelasticA_new:")
print("Felastic new tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO FvA
arg_expr_n = fem.Expression(FvA, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] FvA:")
print("FvA tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO FvA_old
arg_expr_n = fem.Expression(Fv_oldA, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] FvA_old:")
print("FvA_old tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO Cv_Anew
arg_expr_n = fem.Expression(Cv_Anew, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] Cv_Anew :")
print("Cv_Anew tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO Cv_Aold
arg_expr_n = fem.Expression(Cv_Aold, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] Cv_Aold:")
print("Cv_Aold tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO Cauchy_stress_A
arg_expr_n = fem.Expression(Cauchy_stress_A, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] Cauchy_stress_A:")
print("Cauchy_stress_A tensor at first cell:", arg_fn_n.x.array[:9].reshape(3, 3))
#### DEBUG NUMERICO tau_A
arg_expr_n = fem.Expression(tau_A, State_value.element.interpolation_points(), domain.comm)
arg_fn_n = fem.Function(State_value)
print("[DEBUG] tau_A:")
#### DEBUG NUMERICO hydr_pressure_A
arg_expr_n = fem.Expression(hydr_pressure_A, State_value.element.interpolation_points(), domain.comm)
print("[DEBUG] hydr_pressure_A:")
#### DEBUG NUMERICO RampA
arg_expr_n = fem.Expression(RampA, State_value.element.interpolation_points(), domain.comm)
print("[DEBUG] RampA:")
#### DEBUG NUMERICO argA
arg_expr_n = fem.Expression(argA, State_value.element.interpolation_points(), domain.comm)
print("[DEBUG] argA:")
#### DEBUG NUMERICO deltagammaA
arg_expr_n = fem.Expression(deltagammaA, State_value.element.interpolation_points(), domain.comm)
print("[DEBUG] deltagammaA:")
print(ufl.shape(deltagammaA))
#### DEBUG NUMERICO f_A
arg_expr_n2 = fem.Expression(f_A, State_tensor.element.interpolation_points(), domain.comm)
arg_fn_n2 = fem.Function(State_tensor)
arg_fn_n2.interpolate(arg_expr_n2)
print("[DEBUG] f_A:")
print(" min =", np.min(arg_fn_n2.x.array), "max =", np.max(arg_fn_n2.x.array))
#### DEBUG NUMERICO CS_NetworkC
arg_expr_n = fem.Expression(CS_NetworkC, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] CS_NetworkC:")
CS_TNM = Cauchy_stress_A + Cauchy_stress_B + CS_NetworkC
# DEBUG NUMERICO deltaCvA
arg_expr_n = fem.Expression(deltaCvA, State_tensor.element.interpolation_points(), domain.comm)
print("[DEBUG] deltaCvA:")
##RISOLUZIONE
problem = NonlinearProblem(Variational, m, bcs)
solver = NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-8 #Sets the absolute tolerance (stopping criterion when the residual is small)
solver.rtol = 1e-8 #Sets the relative tolerance (stopping criterion based on relative change)
solver.max_it = 500 #Sets the maximum number of iterations
solver.convergence_criterion = "incremental" #Sets the convergence criterion to incremental
num_its, converged = solver.solve(m)
#num_its stores the number of Newton iterations required for convergence.
#converged is True if the solver successfully found a solution, otherwise False
if not converged:
print(f"Solver failed at step {step}. Iterations: {num_its}")
assert (converged) #Test if a condition returns True, if not, it raises an AssertionError
print(f"Time step {step}, Number of iterations {num_its}, Displacement: {displacement_rate*t}")
m.x.scatter_forward()
# Update the state variables
#initial_stateFviA = StateFviA_new
initial_stateFviA_expr = fem.Expression(FvA, State_tensor.element.interpolation_points(), domain.comm)
initialstateFviA = fem.Function(State_tensor)
initialstateFviA.interpolate(initial_stateFviA_expr)
Fv_oldA.x.array[:] = initialstateFviA.x.array[:]
assert not np.isnan(initial_stateFviA.x.array).any(), "NaN in StateFviA"
#initial_stateFviB = StateFviB_new
initial_stateFviB_expr = fem.Expression(FvB, State_tensor.element.interpolation_points(), domain.comm)
initialstateFviB = fem.Function(State_tensor)
initialstateFviB.interpolate(initial_stateFviB_expr)
Fv_oldB.x.array[:] = initialstateFviB.x.array[:]
assert not np.isnan(initial_stateFviB.x.array).any(), "NaN in StateFviB"
#state_muB_in = Stateshear_modulusB_T
state_muB_in_expr = fem.Expression(state_muB_current, State_value.element.interpolation_points(), domain.comm)
state_muB_in = fem.Function(State_value)
state_muB_in.interpolate(state_muB_in_expr)
assert not np.isnan(state_muB_in.x.array).any(), "NaN in muB"
TrueStress_expr = fem.Expression(CS_TNM, TS.element.interpolation_points())
stress_tensor_fn = fem.Function(TS)
stress_tensor_fn.interpolate(TrueStress_expr)
print("True stress tensor at first cell:", stress_tensor_fn.x.array[:9].reshape(3, 3))
true_stress_copy = fem.Function(TS)
true_stress_copy.x.array[:] = stress_tensor_fn.x.array[:]
true_stress_vis_list.append(true_stress_copy)
cs_array = stress_tensor_fn.x.array[:]
assert not np.isnan(cs_array).any(), "NaN in CS_TNM"
max_stress = np.max(np.abs(cs_array))
if max_stress > 1e6:
print(f"⚠️ Warning: High stress detected: {max_stress:.2e}")
print("Saved true stress solution")
# Update the previous solution
# Save a copy of the solution to keep history
u, FvA, FvB = m.split()
uh = m.sub(0).collapse()
uh_vis = fem.Function(V_vis)
uh_vis.interpolate(uh)
uh_copy = fem.Function(V_vis)
uh_copy.x.array[:] = uh_vis.x.array[:] # copia dei dati
uh_vis_list.append(uh_copy)
print("Saved displacement solution")
print("Max displacement norm:", np.max(np.abs(uh_vis.x.array)))
time_step = step
t += deltaT
step += 1
# WRITE XDMFFile
uh.name = "Displacement"
stress_tensor_fn.name = "TrueStress"
outfile.write_function(uh_vis, time_step)
outfile.write_function(stress_tensor_fn, time_step)
outfile.close()
print("Simulation completed")
Here is the output from my debug prints:
[DEBUG] u:
min = 0.0 max = 0.0
u new at first cell: [0. 0. 0.]
[DEBUG] F_new:
min = 0.0 max = 1.0
F new tensor at first cell: [[1. 0. 0.]
[0. 1. 0.]
[0. 0. 1.]]
[t = 0.10] det(F): min=1.0, max=1.0
min = nan max = nan
Felastic new tensor at first cell: [[nan nan nan]
[nan nan nan]
[nan nan nan]]
[DEBUG] FvA:
min = 0.0 max = 0.0
FvA tensor at first cell: [[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]]
[DEBUG] FvA_old:
min = 0.0 max = 1.0
FvA_old tensor at first cell: [[1. 0. 0.]
[0. 1. 0.]
[0. 0. 1.]]
[DEBUG] Cv_Anew :
min = 0.0 max = 0.0
Cv_Anew tensor at first cell: [[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]]
[DEBUG] Cv_Aold:
min = 0.0 max = 1.0
Cv_Aold tensor at first cell: [[1. 0. 0.]
[0. 1. 0.]
[0. 0. 1.]]
min = nan max = nan
Cauchy_stress_A tensor at first cell: [[nan nan nan]
[nan nan nan]
[nan nan nan]]
[DEBUG] tau_A:
min = nan max = nan
min = nan max = nan
[DEBUG] RampA:
min = nan max = nan
[DEBUG] argA:
min = 0.0 max = 0.0
min = 0.0 max = 0.0
[DEBUG] f_A:
min = nan max = nan
min = 0.0 max = 0.0
[DEBUG] deltaCvA:
min = -1.0 max = 0.0
[2025-05-30 18:09:48.376] [info] Requesting connectivity (2, 0) - (3, 0)
[2025-05-30 18:09:48.377] [info] Requesting connectivity (3, 0) - (2, 0)
[2025-05-30 18:09:52.047] [info] Column ghost size increased from 0 to 0
[2025-05-30 18:09:52.310] [info] PETSc Krylov solver starting to solve system.
[2025-05-30 18:09:54.668] [info] PETSc Krylov solver starting to solve system.
[2025-05-30 18:09:56.433] [info] Newton iteration 2: r (abs) = inf (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
[2025-05-30 18:09:56.700] [info] PETSc Krylov solver starting to solve system.
