Issue with using Quadratic(p=2) elements for a 1D advection diffusion problem
I am trying to solve a model advection-diffusion problem in Chapter 2 of the book " Finite Element Methods for Flow Problems" by Donea and Huerta.
the system is
\begin {equation} - u_x - \nu u_{xx} = 1\, \forall\, x\in [0,1] \end {equation}
with the boundary conditons
u(0) = 0
u(1) = 0
I am using \nu=0.02 and 5 elements for my solution
I have been able to match my solutions when solving the problem with linear elements(p=1). I am unable to get any sensible result when I try to use quadratic (p=2) elements
I basically change the element order by making the function space order from
   V = FunctionSpace ( my_mesh, 'CG', 1)
to
  V = FunctionSpace ( my_mesh, 'CG', 2)
to get the quadatic mesh
However, when I solve the system and plot the results, I am getting a piecewise linear plot
the actual figure from the source is ( see Pe=5) which is a squiggly solution.
I also tried plotting the nodes, elements, and coordinates for the mesh, but I was surprised to find that they were still 2 noded elements used for the calculation even when the degree was 2 in the FunctionSpace. Since I am using 5 elements, the quadratic 1D mesh should have 11 elements, but I have only 6. (See output after the code)
Could someone guide me on how to get the correct solution?
My code
from ufl import nabla_div
import pylab as plt
## convection_diffusion simulates a 1D convection diffusion problem in Fig 2.1
#    - a*ux - (nu ux),x = f in Omega = the unit interval.
#      u(0) = 0
#      u(1) = 0
#      f=1
my_nu=0.02
n_ele=5
#Define the mesh
my_mesh = UnitIntervalMesh ( n_ele )
#  Set the function space.
#  Set the trial and test functions.
u = TrialFunction ( V )
v = TestFunction ( V )
#  Set the nu value
mu = Constant ( my_nu )
s = Constant ( 1.0 )
#  Define the bilinear form and right hand side
aa= Constant ( 1.0 )
a = ( aa* v* u.dx(0) + mu * u.dx(0) * v.dx(0) ) * dx
L = s * v * dx
#  Define the boundary condition.
def boundary ( x ):
   value = x[0] < DOLFIN_EPS or 1.0 - DOLFIN_EPS < x[0]
   return value
bc = DirichletBC ( V, 0, boundary )
#  Solve- use default guess
uh = Function ( V )
#  Solve the system.
solve ( a == L, uh, bc )
#  Plot the solution.
h=1/n_ele
fig = plt.figure (dpi=110 )
ax = plt.subplot ( 111 )
plot (uh, label = 'Computed Pe=%.2f'% (1*h/2/my_nu  ))
ax.legend ( )
ax.grid ( True )
ax.set_ylim([0,1.5])
plt.title ( 'convection_diffusion solutions, # ele %d' % ( n_ele ) )
#  Write NODES, ELEMENTS and VALUES
node_num = my_mesh.num_vertices ( )
node_xy = my_mesh.coordinates ( )
print ( "Nodes")
for row in node_xy:
      print(row)
print ( "Elements")
#  Print ELEMENTS array
element_num = my_mesh.num_cells ( )
element_node = my_mesh.cells ( )
for row in element_node:
           print(row)
print ( " Nodal Values")
#  Create a VALUES array, and write it to a file.
u_nodal_values = uh.vector ( )
u_array = u_nodal_values.get_local ( )
value_num = my_mesh.num_vertices ( )
node_value = np.zeros ( node_num )
for i in range ( 0, value_num ):
    print(u_array[i] )
Output from Code
Nodes
[ 0.]
[ 0.2]
[ 0.4]
[ 0.6]
[ 0.8]
[ 1.]
Elements
[0 1]
[1 2]
[2 3]
[3 4]
[4 5]
Nodal Values
0.0
0.49944096704
1.12402169232
0.510899864052
0.769494036811
0.374829298033
Standard plots in FEniCS evaluate the function at the vertices of the mesh. It’s a simple visualisation only since it’s cheap. For more complicated visualisations you should investigate more sophsticated plotting libraries/packages like pyvista or paraview. In this 1D case it’s pretty easy to plot the high order bases though. See the last few lines of the attached code.
import pylab as plt
#      u(0) = 0
#      u(1) = 0
#      f=1
my_nu=0.02
n_ele=5
#Define the mesh
#  Set the nu value
L = s * v * dx
def boundary ( x ):
   return value
uh = Function ( V )
#  Solve the system.
x_plt = np.linspace(0, 1, 100)
uh_plt = np.fromiter(map(uh, x_plt), dtype=np.double)
plt.plot(x_plt, uh_plt)
@nate , thank you! So essesntially FENICS is solving the system with the correct element solution, but the plot tools use the end nodes of the elements for a basic visualization if i am correct?
I had also tried exporting the results as a Paraview pvd file to check the results. The code I used was
vtkfile = File('Pe.pvd")
vtkfile << uh
However, this sitll gives the old incorrect output. Is there a way to get the results correctly?
You should use XDMFFile and write checkpoint, as for instance showed here: When using CG degree 1, the result corresponds to degree 2 - #10 by dokken
