Hello, I’m working on an FSI problem using DG for the fluid and CG for the solid. The issue is that when I run the FSI2 benchmark, I obtain an unreasonable velocity pattern. The force transfer also appears to be incorrect, especially in the x-direction. Meanwhile, the FSI1 benchmark is almost successful (converging to values close to the reference). Any advice on the issue itself would be greatly appreciated. Thanks a lot!
Without a code it’s rather hard to debug this, except if one is an expert in FSI. Maybe @ottarhellan or @Kei_Yamamoto can chime in if they have time and spot something obvious form the figures.
Thanks for the reply. However, the python script is not acceptable in forum. I send it to your email as attachment. I think the force transfer between the sub-mesh might be the key element.
You can upload python scripts by embedding them as
```python
# add code here
It’s a bit hard to tell what could be going on without more information about your setup. Is this a monolithic formulation where you solve everything all at once or are you doing a partitioned scheme? I have only ever used monolith ALE formulations, so if it is partitioned I might not be able to help much
I have a fenicsx solver for the monolithic ALE-formulation you can take a look at for help GitHub - ottarph/fenicsx_fsi_solver: A monolithic arbitrary Lagrangian-Eulerian fluid-structure interaction solver written in FEniCSx. · GitHub, though I don’t think it’s updated from version 0.9 to 0.10. The script in fsi2_biharmonic_diffmesh.py is the one capable of solving the FSI2 problem.
Thanks for the reply. I did a partitioned scheme and use the aitken iteration. The solver is here
FSI/FSI_DGCG__benchmarkFSI2.py at main · linjiayu777/FSI
. I think i could learn and try to modify the solver you provided as the monolithic DG version.
Thanks for the reply. I didn’t use parallel in this case. My primary view point is that owing to the large deformation of ALE mesh, some virtual source was generated to lock the flow. I do a partitioned scheme so it’s also influenced by the coupled algorithm the force transfer here is not conservative when the large deformation emerge
from dolfinx import fem, io, default_real_type
from dolfinx.io import gmsh as gmshio
from pathlib import Path
from dolfinx.fem.petsc import (assemble_matrix, apply_lifting, set_bc)
from dolfinx.mesh import create_submesh, locate_entities_boundary, meshtags
# ====================== Mesh Generation in Python ======================
# ================ Geometric Parameters ================
L = 2.5
H = 0.41
xc = 0.2
yc = 0.2
r = 0.05
fl = 0.35
ft = 0.02
half = ft / 2.0
gmsh.model.add("FSI_TurekHron")
fluid_marker = 1
solid_marker = 2
inlet_marker = 10
outlet_marker = 11
top_marker = 12
bottom_marker = 13
cylinder_marker = 14
interface_marker = 15 # Flag fluid-structure interface (fluid side)
flag_base_marker = 16
# ====================== Channel ======================
p1 = gmsh.model.geo.addPoint(0, 0, 0)
p2 = gmsh.model.geo.addPoint(L, 0, 0)
p3 = gmsh.model.geo.addPoint(L, H, 0)
p4 = gmsh.model.geo.addPoint(0, H, 0)
l1 = gmsh.model.geo.addLine(p1, p2)
l2 = gmsh.model.geo.addLine(p2, p3)
l3 = gmsh.model.geo.addLine(p3, p4)
l4 = gmsh.model.geo.addLine(p4, p1)
# ====================== Cylinder + Flag Connection Points ======================
p5 = gmsh.model.geo.addPoint(xc, yc, 0) # Cylinder center
dx = np.sqrt(r*r - half*half)
p14 = gmsh.model.geo.addPoint(xc + dx, yc - half, 0) # Lower connection point
p15 = gmsh.model.geo.addPoint(xc + dx, yc + half, 0) # Upper connection point
p6 = gmsh.model.geo.addPoint(xc + r, yc, 0) # Rightmost point
p7 = gmsh.model.geo.addPoint(xc, yc + r, 0)
p8 = gmsh.model.geo.addPoint(xc - r, yc, 0)
p9 = gmsh.model.geo.addPoint(xc, yc - r, 0)
# Cylinder Arcs
c5 = gmsh.model.geo.addCircleArc(p6, p5, p15) # Rightmost → upper connection
c6 = gmsh.model.geo.addCircleArc(p15, p5, p7)
c7 = gmsh.model.geo.addCircleArc(p7, p5, p8)
c8 = gmsh.model.geo.addCircleArc(p8, p5, p9)
c9 = gmsh.model.geo.addCircleArc(p9, p5, p14)
c10 = gmsh.model.geo.addCircleArc(p14, p5, p6)
# ====================== Flag ======================
p10 = gmsh.model.geo.addPoint(xc + r + fl, yc - half, 0) # Right lower
p11 = gmsh.model.geo.addPoint(xc + r + fl, yc + half, 0) # Right upper
l11 = gmsh.model.geo.addLine(p14, p10) # Flag lower edge
l12 = gmsh.model.geo.addLine(p10, p11) # Flag right end
l13 = gmsh.model.geo.addLine(p11, p15) # Flag upper edge
# ====================== Surface Definitions ======================
# solid_area
loop_flag = gmsh.model.geo.addCurveLoop([l11, l12, l13, -c5, -c10])
s2 = gmsh.model.geo.addPlaneSurface([loop_flag])
# fluid_area
loop_channel = gmsh.model.geo.addCurveLoop([l1, l2, l3, l4])
loop_cylinder = gmsh.model.geo.addCurveLoop([c5, c6, c7, c8, c9, c10])
loop_flag2 = gmsh.model.geo.addCurveLoop([l11, l12, l13, -c5, -c10])
s1 = gmsh.model.geo.addPlaneSurface([loop_channel, loop_cylinder, loop_flag2])
gmsh.model.geo.synchronize()
# =================== Physical Groups ======================
gmsh.model.addPhysicalGroup(2, [s1], fluid_marker)
gmsh.model.setPhysicalName(2, fluid_marker, "Fluid")
gmsh.model.addPhysicalGroup(2, [s2], solid_marker)
gmsh.model.setPhysicalName(2, solid_marker, "Solid")
gmsh.model.addPhysicalGroup(1, [l4], inlet_marker)
gmsh.model.addPhysicalGroup(1, [l2], outlet_marker)
gmsh.model.addPhysicalGroup(1, [l3], top_marker)
gmsh.model.addPhysicalGroup(1, [l1], bottom_marker)
gmsh.model.addPhysicalGroup(1, [c5,c6,c7,c8,c9,c10], cylinder_marker)
gmsh.model.addPhysicalGroup(1, [l11,l12,l13], interface_marker)
# ====================== Mesh Setup ======================
obstacle_edges = [c5, c6, c7, c8, c9, c10, l11, l12, l13]
# Distance Field
gmsh.model.mesh.field.setNumbers(1, "EdgesList", obstacle_edges)
# Threshold Field
gmsh.model.mesh.field.setNumber(2, "IField", 1)
gmsh.model.mesh.field.setNumber(2, "LcMin", ft / 3.0) # 0.01
gmsh.model.mesh.field.setNumber(2, "LcMax", 0.1 * H) # 0.082
gmsh.model.mesh.field.setNumber(2, "DistMin", r/2)
gmsh.model.mesh.field.setNumber(2, "DistMax", 2 * H)
# Background Field
gmsh.model.mesh.field.add("Min", 3)
gmsh.model.mesh.field.setNumbers(3, "FieldsList", [2])
gmsh.model.mesh.field.setAsBackgroundMesh(3)
# ====================== Mesh Generation ======================
gmsh.model.mesh.generate(2) # Generate 2D mesh
#gmsh.write("mesh1.msh")
# ====================== Import DOLFINx ======================
mesh_data = gmshio.model_to_mesh(
gmsh.model,
MPI.COMM_WORLD,
rank=0,
gdim=2
parent_mesh = mesh_data.mesh
cell_tags = mesh_data.cell_tags
facet_tags = mesh_data.facet_tags
#------------------------Create Submesh-----------------------
tdim = parent_mesh.topology.dim
fluid_cells = cell_tags.indices[cell_tags.values == fluid_marker]
solid_cells = cell_tags.indices[cell_tags.values == solid_marker]
fluid_mesh, fluid_to_parent_cells, _, _ = create_submesh(parent_mesh, tdim, fluid_cells)
solid_mesh, solid_to_parent_cells, _, _ = create_submesh(parent_mesh, tdim, solid_cells)
def create_facet_tags(mesh, markers):
fdim = mesh.topology.dim - 1
facets = []
values = []
for marker, locator in markers.items():
entities = locate_entities_boundary(mesh, fdim, locator)
facets.append(entities)
values.append(np.full(len(entities), marker, dtype=np.int32))
if facets:
facets = np.hstack(facets)
values = np.hstack(values)
sort_idx = np.argsort(facets)
facet_tags = meshtags(mesh, fdim, facets[sort_idx], values[sort_idx])
facet_tags = meshtags(mesh, fdim, np.array([], dtype=np.int32), np.array([], dtype=np.int32))
return facet_tags
fluid_markers = {
inlet_marker: lambda x: np.isclose(x[0], 0.0, atol=1e-6),
outlet_marker: lambda x: np.isclose(x[0], L, atol=1e-6),
top_marker: lambda x: np.isclose(x[1], H, atol=1e-6),
bottom_marker: lambda x: np.isclose(x[1], 0.0, atol=1e-6),
cylinder_marker: lambda x: np.abs(np.sqrt((x[0]-xc)**2 + (x[1]-yc)**2) - r) < 1e-4,
interface_marker: lambda x: (np.abs(x[1] - (yc + half)) < 1e-4) |
(np.abs(x[1] - (yc - half)) < 1e-4) |
(np.abs(x[0] - (xc + r + fl)) < 1e-4)
facet_tags_fluid = create_facet_tags(fluid_mesh, fluid_markers)
attachment_x = xc + np.sqrt(r*r - half*half)
solid_markers = {
(np.abs(x[0] - (xc + r + fl)) < 1e-4),
flag_base_marker: lambda x: (
np.abs(np.sqrt((x[0]-xc)**2 + (x[1]-yc)**2) - r) < 1e-5) &
(np.abs(x[1] - yc) < half + 1e-5)
facet_tags_solid = create_facet_tags(solid_mesh, solid_markers)
output_dir = Path("output_turek_submesh")
output_dir.mkdir(exist_ok=True)
with io.XDMFFile(fluid_mesh.comm, output_dir / "fluid_mesh.xdmf", "w") as f:
f.write_mesh(fluid_mesh)
with io.XDMFFile(solid_mesh.comm, output_dir / "solid_mesh.xdmf", "w") as f:
f.write_mesh(solid_mesh)
################################### ALE #########################################
gdim = 2
ale_order = 2
V_ale = fem.functionspace(fluid_mesh, ("Lagrange", ale_order, (gdim,)))
d = fem.Function(V_ale, name="ale_displacement")
d_old = fem.Function(V_ale, name="ale_displacement")
v = fem.Function(V_ale, name="ale_velocity")
zero_disp = fem.Function(V_ale)
zero_disp.x.array[:] = 0.0
scale_det = True
scale_exp = 1.0
dx_ale = ufl.Measure("dx", domain=fluid_mesh)
# Material parameters (recommended to increase to adapt to amplitude=0.05)
a0 = fem.Constant(fluid_mesh, PETSc.ScalarType(15.0))
b0 = fem.Constant(fluid_mesh, PETSc.ScalarType(15.0)) #
kappa = fem.Constant(fluid_mesh, PETSc.ScalarType(40.0)) #
I = ufl.Identity(gdim)
F = I + ufl.grad(d)
F = ufl.variable(F)
#C = F.T * F
J = ufl.det(F)
Ic_bar = J**(-2.0/gdim) * ufl.tr(F.T * F)
#I1bar = ufl.tr(J**(-2.0/gdim) * C)
psi_dev = (a0 / (2.0 * b0)) * (ufl.exp(b0 * (Ic_bar - gdim)) - 1.0)
psi_vol = (kappa / 2.0) * (J - 1)**2
psi = psi_dev + psi_vol
if scale_det:
fac = (1.0 / J) ** scale_exp
fac = 1.0
P = ufl.diff(psi, F) * fac # First Piola-Kirchhoff stress
d_test = ufl.TestFunction(V_ale)
F_ale = ufl.inner(P, ufl.grad(d_test)) * dx_ale
ale_bcs = []
fdim = fluid_mesh.topology.dim - 1
# Inlet (fixed)
inlet_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(inlet_marker))
# Walls (fixed)
top_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(top_marker))
bottom_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(bottom_marker))
# Outlet (fixed)
outlet_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(outlet_marker))
# Obstacle (prescribed motion)
cylinder_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(cylinder_marker))
#obstacle_dofs = fem.locate_dofs_topological(V_ale, fdim, facet_tags_fluid.find(interface_marker))
bc_ale_inlet = fem.dirichletbc(zero_disp, inlet_dofs) # displacement = 0 #should we fix the inlet ?
bc_ale_top = fem.dirichletbc(zero_disp, top_dofs) # displacement = 0
bc_ale_bottom = fem.dirichletbc(zero_disp, bottom_dofs)
bc_ale_outlet = fem.dirichletbc(zero_disp, outlet_dofs)
bc_ale_cylinder = fem.dirichletbc(zero_disp, cylinder_dofs)
bcs_ale = [bc_ale_inlet, bc_ale_outlet, bc_ale_bottom, bc_ale_top, bc_ale_cylinder]
petsc_options_ALE = {
"snes_type": "newtonls",
"snes_linesearch_type": "basic",
"snes_stol": 1e-12,
"snes_atol": 1e-10,
"snes_rtol": 1e-8,
"snes_max_it": 20,
"ksp_type": "preonly",
"pc_type": "lu",
"snes_monitor": None,
ALE_problem = NonlinearProblem(
F_ale,
d,
bcs=bcs_ale,
petsc_options=petsc_options_ALE,
petsc_options_prefix = "ALE_solver"
################################## Fluid ######################################
k = 2
ve = element("Discontinuous Lagrange", fluid_mesh.basix_cell(), k, shape=(gdim,))
pe = element("Discontinuous Lagrange", fluid_mesh.basix_cell(), k-1)
me = mixed_element([ve, pe])
VQ = fem.functionspace(fluid_mesh, me)
up = ufl.TrialFunction(VQ)
vq = ufl.TestFunction(VQ)
u, p = ufl.split(up)
v, q = ufl.split(vq)
dt = fem.Constant(fluid_mesh, default_real_type(0.05))
rho = fem.Constant(fluid_mesh, PETSc.ScalarType(1000.0))
nu = fem.Constant(fluid_mesh, PETSc.ScalarType(1))
alpha = fem.Constant(fluid_mesh, PETSc.ScalarType(50*k**2)) # shall we increase penalty for stability
alpha_bd = alpha * 10
h = ufl.CellDiameter(fluid_mesh)
n_vec = ufl.FacetNormal(fluid_mesh)
ds_fluid = ufl.Measure("ds", domain=fluid_mesh, subdomain_data=facet_tags_fluid)
dS_fluid = ufl.Measure("dS", domain=fluid_mesh)
dx_fluid = ufl.Measure("dx", domain = fluid_mesh)
ds_inlet = ds_fluid(inlet_marker)
ds_top = ds_fluid(top_marker)
ds_bot = ds_fluid(bottom_marker)
ds_interface = ds_fluid(interface_marker)
ds_cylinder = ds_fluid(cylinder_marker)
ds_outlet = ds_fluid(outlet_marker)
V0, _ = VQ.sub(0).collapse()
class InletVelocity:
def __init__(self):
self.t = 0.0
def __call__(self, x):
values = np.zeros((gdim, x.shape[1]), dtype=PETSc.ScalarType)
U_bar = 1.0
ramp_time = 1
ramp = 0.5 * (1.0 - np.cos(np.pi * min(self.t, ramp_time) / ramp_time)) if self.t < ramp_time else 1.0
factor = 1.5 * U_bar * 4.0 * x[1] * (H - x[1]) / (H ** 2)
values[0] = factor * ramp
values[1] = 0.0
return values
class ZeroVelocity:
return values
u_inlet_func = fem.Function(V0)
u_inlet_func.interpolate(InletVelocity())
zero_vel_func = fem.Function(V0)
zero_vel_func.interpolate(ZeroVelocity())
u_elem = fem.Function(V0, name="u_elem")
#------------------------Diffuse Term----------------------------
def jump(phi, n):
return ufl.outer(phi("+"), n("+")) + ufl.outer(phi("-"), n("-"))
# Interior face terms (interior penalty)
a_diffusion = nu * (
ufl.inner(ufl.grad(u), ufl.grad(v)) * dx_fluid
- ufl.inner(ufl.avg(ufl.grad(u)), jump(v, n_vec)) * dS_fluid
- ufl.inner(jump(u, n_vec), ufl.avg(ufl.grad(v))) * dS_fluid
+ (alpha / ufl.avg(h)) * ufl.inner(jump(u, n_vec), jump(v, n_vec)) * dS_fluid
# Dirichlet boundary terms (inlet + wall + obstacle) — only for trial u
boundary_ds = ds_inlet + ds_bot + ds_top + ds_interface + ds_cylinder
a_diffusion += nu * (
- ufl.inner(ufl.grad(u), ufl.outer(v, n_vec)) * boundary_ds
- ufl.inner(ufl.outer(u, n_vec), ufl.grad(v)) * boundary_ds
+ (alpha_bd / h) * ufl.inner(ufl.outer(u, n_vec), ufl.outer(v, n_vec)) * boundary_ds #always pay attention to the alpha_bd we used here!!!
a_pressure = -ufl.inner(p, ufl.div(v)) * dx_fluid + ufl.inner(ufl.avg(p), ufl.jump(v, n_vec)) * dS_fluid
alpha_p = fem.Constant(fluid_mesh, PETSc.ScalarType(3)) # or 0.1~5
a_pressure_plty = + alpha_p / ufl.avg(h) * ufl.dot(ufl.jump(p, n_vec), ufl.jump(q, n_vec)) * dS_fluid
a_pressure += a_pressure_plty
a_continuity = -ufl.inner(ufl.div(u), q) * dx_fluid + ufl.inner(ufl.jump(u, n_vec), ufl.avg(q)) * dS_fluid
a_continuity_bd = ufl.inner(ufl.dot(u, n_vec), q) * boundary_ds
a_continuity += a_continuity_bd
a_stokes = a_stokes = a_diffusion + a_pressure + a_continuity
L_continuity_bd = (
ufl.inner(ufl.dot(u_inlet_func, n_vec), q) * ds_inlet # inlet
- ufl.inner(ufl.dot(zero_vel_func, n_vec), q) * (ds_top + ds_bot + ds_cylinder) # wall
+ ufl.inner(ufl.dot(u_elem, n_vec), q) * ds_interface # obstacle: u = w → +u_elem
L_diffusion_bd = nu * (
# inlet (g = u_inlet_func)
- ufl.inner(ufl.outer(u_inlet_func, n_vec), ufl.grad(v)) * ds_inlet
+ (alpha_bd / h) * ufl.inner(ufl.outer(u_inlet_func, n_vec), ufl.outer(v, n_vec)) * ds_inlet
# wall (g = 0)
- ufl.inner(ufl.outer(zero_vel_func, n_vec), ufl.grad(v)) * (ds_top + ds_bot)
+ (alpha_bd / h) * ufl.inner(ufl.outer(zero_vel_func, n_vec), ufl.outer(v, n_vec)) * (ds_bot + ds_top + ds_cylinder)
# obstacle (g = u_elem = w) ← must be +u_elem
- ufl.inner(ufl.outer(u_elem, n_vec), ufl.grad(v)) * ds_interface
+ (alpha_bd / h) * ufl.inner(ufl.outer(u_elem, n_vec), ufl.outer(v, n_vec)) * ds_interface
L_stokes = L_continuity_bd + L_diffusion_bd
#----------------------Convection and Time-----------------------
u_n = fem.Function(V0, name="u_n") # u^n
u_nm1 = fem.Function(V0, name="u_nm1")
u_star = fem.Function(V0, name="u_star") #extrapolation velocity
u_star_rel = fem.Function(V0, name="rel_u_star")
#u_rel = fem.Function(V0, name="rel_u")
u_n.x.array[:] = 0.0
#u_rel = u - u_elem
#u_star.x.array[:] = u_star.x.array[:] - u_elem.x.array[:]
u_star_rel = u_star - u_elem
lmbda = ufl.conditional(ufl.gt(ufl.dot(u_star_rel, n_vec), 0), 1, 0)
u_uw = lmbda("+") * u("+") + lmbda("-") * u("-")
term_conv_vol = -rho * ufl.inner(u, ufl.div(ufl.outer(v, u_star_rel))) * dx_fluid
term_conv_surf = rho * ufl.inner(ufl.dot(u_star_rel, n_vec)("+") * u_uw, v("+")) * dS_fluid + \
rho * ufl.inner(ufl.dot(u_star_rel, n_vec)("-") * u_uw, v("-")) * dS_fluid
term_conv_bd = rho * ufl.inner(ufl.dot(u_star_rel, n_vec) * lmbda * u, v) * (boundary_ds + ds_outlet)
a_conv = term_conv_vol + term_conv_surf + term_conv_bd
L_conv = - rho * ufl.inner(ufl.dot(u_star_rel, n_vec) * (1 - lmbda) * u_inlet_func, v) * ds_inlet \
- rho * ufl.inner(ufl.dot(u_star_rel, n_vec) * (1 - lmbda) * u_elem, v) * ds_interface \
- rho * ufl.inner(ufl.dot(u_star_rel, n_vec) * (1 - lmbda) * zero_vel_func, v) * (ds_bot + ds_top + ds_cylinder)
#--------------------------Time Discretization---------------------------
term_time_lhs_bdf1 = rho * ufl.inner(u/dt, v) * ufl.dx
term_time_rhs_bdf1 = rho * ufl.inner(u_n/dt, v) * ufl.dx
# Backward Euler
# BDF2: (3u^n+1 - 4u^n + u^{n-1}) / (2*dt)
term_time_lhs_bdf2 = rho * (3.0/ (2.0 * dt)) * ufl.inner(u,v) * ufl.dx
term_time_rhs_bdf2 = rho * (4.0/ (2.0 * dt)) * ufl.inner(u_n, v) * ufl.dx \
- rho * (1.0 / (2.0 * dt)) * ufl.inner(u_nm1, v) * ufl.dx
#-------------------------Form Assembly---------------------------
a_ns_bdf1 = a_stokes + term_time_lhs_bdf1 + a_conv
L_ns_bdf1 = L_stokes + term_time_rhs_bdf1 + L_conv
a_ns_bdf2 = a_stokes + a_conv + term_time_lhs_bdf2
L_ns_bdf2 = L_stokes + L_conv + term_time_rhs_bdf2
a_ns_form_bdf1 = fem.form(a_ns_bdf1)
L_ns_form_bdf1 = fem.form(L_ns_bdf1)
a_ns_form_bdf2 = fem.form(a_ns_bdf2)
L_ns_form_bdf2 = fem.form(L_ns_bdf2)
#-----------------------------Solver Setup-----------------------------
up_h = fem.Function(VQ)
u_h, p_h = up_h.sub(0), up_h.sub(1)
def create_solver(a_form):
A = dolfinx.fem.petsc.create_matrix(a_form)
ksp = PETSc.KSP().create(fluid_mesh.comm)
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
ksp.setOperators(A)
pc.getFactorMatrix().setMumpsIcntl(14, 80)
pc.getFactorMatrix().setMumpsIcntl(24, 1)
pc.getFactorMatrix().setMumpsIcntl(25, 0)
return A, ksp
A1, ksp1 = create_solver(a_ns_form_bdf1)
A2, ksp2 = create_solver(a_ns_form_bdf2)
a_form = fem.form(a_ns_bdf1)
L_form = fem.form(L_ns_bdf1)
A,ksp = create_solver(a_form)
################################# SOLID ##################################
V_solid = fem.functionspace(solid_mesh, ("Lagrange", 2, (gdim,)))
d_solid = fem.Function(V_solid, name = "solid_displacement")
v_solid = fem.Function(V_solid, name = "solid_velocity")
a_solid = fem.Function(V_solid, name = "solid_acceleration")
d_solid_old = fem.Function(V_solid)
v_solid_old = fem.Function(V_solid)
a_solid_old = fem.Function(V_solid)
d_solid_test = ufl.TestFunction(V_solid)
E_mod = 1.4e6
nu_val = 0.4
mu_s = fem.Constant(solid_mesh, E_mod / (2 * (1 + nu_val)))
#kappa_s = fem.Constant(solid_mesh, E_mod / (3 * (1 - 2 * nu_val)))
lambda_s = E_mod * nu_val / ((1.0 + nu_val) * (1.0 - 2.0 * nu_val))
# Measures
dx_solid = ufl.Measure("dx", domain = solid_mesh)
# dx_solid = ufl.Measure("dx", domain=solid_mesh,
# metadata={"quadrature_degree": 2})
ds_solid = ufl.Measure("ds", domain = solid_mesh, subdomain_data=facet_tags_solid)
# Hyperelastic
I_s = ufl.Identity(gdim)
F_s = I_s + ufl.grad(d_solid)
C_s = F_s.T * F_s
E_s = 0.5 * (C_s - I_s)
S_s = lambda_s * ufl.tr(E_s) * I_s + 2.0 * mu_s * E_s
P_s = F_s * S_s
rho_s = fem.Constant(solid_mesh, PETSc.ScalarType(10000.0))
n_solid = ufl.FacetNormal(solid_mesh)
dt_solid = dt
beta = fem.Constant(solid_mesh, PETSc.ScalarType(0.25))
gamma = fem.Constant(solid_mesh, PETSc.ScalarType(0.55))
#gamma = fem.Constant(solid_mesh, PETSc.ScalarType(0.6)) # Introduce low-frequency dissipation
beta = fem.Constant(solid_mesh, PETSc.ScalarType(0.25 * (gamma + 0.5)**2))
a_expr_s = (1.0 / (beta * dt_solid**2)) * (d_solid - d_solid_old
- dt_solid * v_solid_old - (0.5 - beta) * dt_solid**2 * a_solid_old)
#F_solid = ufl.inner(P_s, ufl.grad(d_solid_test)) * dx_solid
F_solid = (rho_s * ufl.inner(a_expr_s, d_solid_test) * dx_solid +
ufl.inner(P_s, ufl.grad(d_solid_test)) * dx_solid)
#----------------------------Force Application----------------------------
I_f = ufl.Identity(gdim)
V_tensor_f = fem.functionspace(fluid_mesh, ("CG", 1, (gdim, gdim)))
sigma_f_exact = -p_h * I_f + nu * (ufl.grad(u_h) + ufl.grad(u_h).T)
u_sig = ufl.TrialFunction(V_tensor_f)
v_sig = ufl.TestFunction(V_tensor_f)
a_sig = ufl.inner(u_sig, v_sig) * dx_fluid
L_sig = ufl.inner(sigma_f_exact, v_sig) * dx_fluid
import dolfinx.fem.petsc
stress_prob = fem.petsc.LinearProblem(a_sig, L_sig, bcs=[],
petsc_options={"ksp_type": "cg", "pc_type": "jacobi"},
petsc_options_prefix="stress_solver")
sigma_f_smooth = stress_prob.solve()
# ====================== Transfer to Solid Side ======================
dx_solid = ufl.Measure("dx", domain=solid_mesh)
ds_solid = ufl.Measure("ds", domain=solid_mesh, subdomain_data=facet_tags_solid)
V_tensor_s = fem.functionspace(solid_mesh, ("CG", 1, (gdim, gdim)))
sigma_s_smooth = fem.Function(V_tensor_s, name="solid_stress_tensor")
# Perform non-matching interpolation
cells_solid = np.arange(solid_mesh.topology.index_map(solid_mesh.topology.dim).size_local, dtype=np.int32)
interp_data = dolfinx.fem.create_interpolation_data(V_tensor_s, V_tensor_f, cells=cells_solid, padding=1e-5)
sigma_s_smooth.interpolate_nonmatching(sigma_f_smooth, cells_solid, interp_data)
sigma_s_smooth.x.scatter_forward()
n_s = ufl.FacetNormal(solid_mesh)
n_f = ufl.FacetNormal(fluid_mesh)
traction_f_expr = -ufl.dot(sigma_f_smooth, n_f)
traction_s_expr = ufl.dot(sigma_s_smooth, n_s)
# J_s = ufl.det(F_s) # Solid deformation gradient determinant
# traction_ref = J_s * ufl.dot(traction_s_expr, ufl.inv(F_s).T) # First Piola-Kirchhoff traction
# F_solid -= ufl.inner(traction_ref, d_solid_test) * ds_solid(interface_marker)
#_solid -= ufl.inner(traction_s, d_solid_test) * ds_solid(interface_marker)
J_s = ufl.det(F_s)
F_inv_T = ufl.inv(F_s).T
P_fluid = J_s * ufl.dot(sigma_s_smooth, F_inv_T)
traction_ref = ufl.dot(P_fluid, n_s)
First section
#-----------------------------Dirichlet BC Application-----------------------
# Specifically check the base marker
base_facets = facet_tags_solid.find(flag_base_marker)
print(f"flag_base_marker (value {flag_base_marker}) found {len(base_facets)} facets")
zero = fem.Function(V_solid)
zero.x.array[:] = 0.0
base_dofs = fem.locate_dofs_topological(V_solid, fdim, facet_tags_solid.find(flag_base_marker))
bc_base = fem.dirichletbc(zero, base_dofs)
petsc_options = {
"snes_linesearch_type": "bt", #bt?
"snes_stol": 1e-12,
"snes_atol": 1e-10,
"snes_rtol": 1e-8,
"snes_max_it": 20,
"pc_type": "lu",
solid_problem = NonlinearProblem(
F_solid,
d_solid,
bcs=[bc_base],
petsc_options=petsc_options,
petsc_options_prefix = "solid_solver"
############################### Assistance #####################################
d_interface = fem.Function(V_ale, name = "d_interface_fluid")
cells_fluid = np.arange(
fluid_mesh.topology.index_map(fluid_mesh.topology.dim).size_local,
dtype = np.int32)
interp_data_solid_to_ale = dolfinx.fem.create_interpolation_data(
V_ale, # target: fluid ALE space
V_solid, # source: solid space
cells=cells_fluid,
padding=1e-5
def update_ale_interface_bc():
d_interface.interpolate_nonmatching(
d_solid,
cells_fluid,
d_interface.x.scatter_forward()
interface_dofs = fem.locate_dofs_topological(
bc_ale_interface = fem.dirichletbc(d_interface, interface_dofs)
bcs_ale_new = [bc_ale_inlet, bc_ale_top, bc_ale_bottom, bc_ale_outlet, bc_ale_cylinder, bc_ale_interface]
return bcs_ale_new
V0_fluid = V0 #fem.functionspace(fluid_mesh, ("Lagrange", 1, (gdim,)))
#u_elem = fem.Function(V0_fluid, name="mesh_velocity") # u_mesh = (d - d_old)/dt
d_elem = fem.Function(fem.functionspace(fluid_mesh, ("Lagrange", 1, (gdim,))))
def project_mesh_velocity():
u_expr = (d - d_old) / float(dt.value)
trial = ufl.TrialFunction(V0_fluid)
test = ufl.TestFunction(V0_fluid)
dx_proj = ufl.Measure("dx", domain = fluid_mesh)
a_proj = ufl.inner(trial, test) * dx_proj
L_proj = ufl.inner(u_expr, test) * dx_proj
proj_problem = fem.petsc.LinearProblem(
a_proj,
L_proj,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"},
petsc_options_prefix = "ale_velocity_projector")
return proj_problem.solve()
folder = Path("results_FSI_submesh")
folder.mkdir(exist_ok=True, parents=True)
V_u_vis = fem.functionspace(fluid_mesh, ("CG", 2, (gdim,)))
V_p_vis = fem.functionspace(fluid_mesh, ("CG", 1))
V_d_vis = fem.functionspace(fluid_mesh, ("CG", 2, (gdim,)))
V_solid_vis = fem.functionspace(solid_mesh, ("CG", 2, (gdim,)))
Vf_fluid_vis = fem.functionspace(fluid_mesh, ("CG", 1, (gdim,)))
Vf_solid_vis = fem.functionspace(solid_mesh, ("CG", 1, (gdim,)))
u_vis = fem.Function(V_u_vis, name="velocity")
p_vis = fem.Function(V_p_vis, name="pressure")
d_vis = fem.Function(V_d_vis, name="ALE_displacement")
d_solid_vis = fem.Function(V_solid_vis, name="solid_displacement")
T_fluid_vis = fem.Function(Vf_fluid_vis, name="traction_f")
T_solid_vis = fem.Function(Vf_solid_vis, name="traction_s")
vtx_u = io.VTXWriter(fluid_mesh.comm, folder / "u.bp", u_vis)
vtx_p = io.VTXWriter(fluid_mesh.comm, folder / "p.bp", p_vis)
vtx_combined = io.VTXWriter(fluid_mesh.comm, folder / "fluid_ale.bp", [u_vis, d_vis], engine="BP4")
vtx_solid = io.VTXWriter(solid_mesh.comm, folder / "solid.bp", d_solid_vis)
vtx_T_f = io.VTXWriter(fluid_mesh.comm, folder / "T_f.bp", T_fluid_vis)
vtx_T_s = io.VTXWriter(solid_mesh.comm, folder / "T_s.bp", T_solid_vis)
#-------------------------History ux uy-------------------------
from dolfinx import geometry
tip_x = xc + r + fl
tip_y = yc
tip_point = np.array([[tip_x, tip_y, 0.0]], dtype=PETSc.ScalarType) # Note 3D coordinates
tdim = solid_mesh.topology.dim
bb_tree = geometry.bb_tree(solid_mesh, tdim)
cell_tree = geometry.bb_tree(solid_mesh, tdim)
midpoint_tree = geometry.bb_tree(solid_mesh, tdim)
tip_cell = geometry.compute_closest_entity(cell_tree, midpoint_tree, solid_mesh, tip_point)
solid_tip_history = []
interface_force = []
flag_force = []
inertia_force_vector = rho_s * a_expr_s
external_force_vector = traction_ref
inertia_mag_form = fem.form(ufl.sqrt(ufl.inner(inertia_force_vector, inertia_force_vector)) * dx_solid)
external_mag_form = fem.form(ufl.sqrt(ufl.inner(external_force_vector, external_force_vector)) * ds_solid(interface_marker))
inertia_ratio_history = []
################################### Time Loop ###############################
max_fsi_iter = 50
fsi_tol = 1e-6
inlet_vel = InletVelocity() # Instance with .t attribute
x_ref_fluid = fluid_mesh.geometry.x.copy()
u_n.interpolate(fem.Function(V0))
d_old.x.array[:] = 0.0
d_solid_old.x.array[:] = 0.0
t = 0.0
step = 0
dt.value = 0.05
dt_val = float(dt.value)
#T = dt_val * 50 #40 is the end of the ramp
T = 15.0
while t < T:
inlet_vel.t = float(t) # inlet_vel is the instance created below
u_inlet_func.interpolate(inlet_vel)
#print(step,t)
if step == 0:
a_form = a_ns_form_bdf1
L_form = L_ns_form_bdf1
A, ksp = A1, ksp1
a_form = a_ns_form_bdf2
L_form = L_ns_form_bdf2
A, ksp = A2, ksp2
A.zeroEntries()
assemble_matrix(A, a_form)
ksp.setOperators(A)
b = dolfinx.fem.assemble_vector(L_form)
ksp.solve(b.petsc_vec, up_h.x.petsc_vec)
up_h.x.scatter_forward()
if t >= 2.0:
# change of the timestep has impact on the stability keep same will be better
if t < 5.0:
dt.value = 0.02
elif t < 7.5:
dt.value = 0.01
dt.value = 0.005
aitken_residual_old = None
aitken_omega = 0.5
d_interface_old = d_interface.x.array.copy()
d_solid_prev_iter = d_solid_old.x.array.copy()
#---------------------fsi Aitken iter for the add_mass-------------------
for fsi_iter in range(max_fsi_iter):
print(f" FSI iter {fsi_iter+1}/{max_fsi_iter} at t={t:.4f}")
solid_nit = solid_problem.solve()
d_solid.x.scatter_forward()
d_solid_solver = d_solid.x.array.copy()
residual = d_solid_solver - d_solid_prev_iter
if fsi_iter == 0:
d_solid.x.array[:] = aitken_omega * d_solid_solver + (1.0 - aitken_omega) * d_solid_prev_iter
d_solid_prev_iter = d_solid.x.array.copy()
aitken_residual_old = residual.copy()
residual_old = aitken_residual_old
delta_r = residual - residual_old
norm_delta_r = np.dot(delta_r, delta_r)
if norm_delta_r > 1e-14:
aitken_omega *= -np.dot(residual_old, delta_r) / norm_delta_r
aitken_omega = max(0.1, min(aitken_omega, 1.0))
aitken_omega = 0.5
d_solid.x.array[:] = d_solid_prev_iter + aitken_omega * residual
# ALE mesh motion
fluid_mesh.geometry.x[:] = x_ref_fluid
bcs_ale_new = update_ale_interface_bc()
F_ale,
d,
bcs=bcs_ale_new,
petsc_options_prefix="ALE_solver"
ale_nit = ALE_problem.solve()
d_elem.interpolate(d)
new_u_elem = project_mesh_velocity()
u_elem.x.array[:] = new_u_elem.x.array[:]
u_elem.x.scatter_forward()
fluid_mesh.geometry.x[:, :gdim] = x_ref_fluid[:, :gdim] + d_elem.x.array.reshape((-1, gdim))
A.zeroEntries()
ksp.setOperators(A)
traction_f_expr_step = -ufl.dot(sigma_f_smooth, n_f)
traction_s_expr_step = ufl.dot(sigma_s_smooth, n_s)
total_force_f_x = fem.assemble_scalar(fem.form(
ufl.inner(traction_f_expr_step, e_x) * ds_fluid(interface_marker)
total_force_f_y = fem.assemble_scalar(fem.form(
ufl.inner(traction_f_expr_step, e_y) * ds_fluid(interface_marker)
total_force_s_x = fem.assemble_scalar(fem.form(
ufl.inner(traction_s_expr_step, e_x) * ds_solid(interface_marker)
total_force_s_y = fem.assemble_scalar(fem.form(
ufl.inner(traction_s_expr_step, e_y) * ds_solid(interface_marker)
force_res = np.sqrt(
(total_force_f_x - total_force_s_x)**2 +
(total_force_f_y - total_force_s_y)**2
# Normalization (optional)
norm_force = np.sqrt(total_force_f_x**2 + total_force_f_y**2) + 1e-10
rel_force_res = force_res / norm_force
# Convergence check
d_diff = np.linalg.norm(d_interface.x.array - d_interface_old) / (np.linalg.norm(d_interface.x.array) + 1e-12)
print(f" interface disp change = {d_diff:.2e}")
print(f" force change = {rel_force_res:.2e}")
if d_diff < fsi_tol:
print(f" FSI converged in {fsi_iter+1} iterations at t={t:.4f}")
break
d_interface_old[:] = d_interface.x.array.copy()
# Newmark time integration (velocity / acceleration update)
a_new = (1.0 / (beta * dt_solid**2)) * (d_solid.x.array - d_solid_old.x.array
- float(dt_solid) * v_solid_old.x.array
- (0.5 - beta) * float(dt_solid)**2 * a_solid_old.x.array)
a_solid.x.array[:] = a_new
v_new = v_solid_old.x.array + float(dt_solid) * ((1 - gamma) * a_solid_old.x.array
+ gamma * a_solid.x.array)
v_solid.x.array[:] = v_new
u_nm1.x.array[:] = u_n.x.array[:]
u_n.interpolate(u_h)
if step >= 1:
u_star.x.array[:] = 2.0 * u_n.x.array[:] - u_nm1.x.array[:]
u_star.x.array[:] = u_n.x.array[:]
d_old.x.array[:] = d.x.array[:]
d_solid_old.x.array[:] = d_solid.x.array.copy()
v_solid_old.x.array[:] = v_solid.x.array.copy()
a_solid_old.x.array[:] = a_solid.x.array.copy()
# Record flag tip displacement (as in original FSI2)
tip_disp = d_solid.eval(tip_point, tip_cell)
ux_tip = tip_disp[0]
uy_tip = tip_disp[1]
solid_tip_history.append([float(t), ux_tip, uy_tip])
print(f"Flag tip t = {t:.4f} | ux = {ux_tip:.6e} uy = {uy_tip:.6e}")
#------------------------History FD, FL-----------------------------
ds_obstacle = ds_fluid(interface_marker) + ds_fluid(cylinder_marker)
sigma_f = -p_h * I_f + nu * (ufl.grad(u_h) + ufl.grad(u_h).T)
force_on_body = - sigma_f * n_f
# Total force (unit: N)
drag_form = ufl.inner(- sigma_f * n_f, ufl.as_vector([1.0, 0.0])) * ds_obstacle
lift_form = ufl.inner(- sigma_f * n_f, ufl.as_vector([0.0, 1.0])) * ds_obstacle
F_D = dolfinx.fem.assemble_scalar(dolfinx.fem.form(drag_form))
F_L = dolfinx.fem.assemble_scalar(dolfinx.fem.form(lift_form))
drag_form1 = ufl.inner(- sigma_f * n_f, ufl.as_vector([1.0, 0.0])) * ds_fluid(interface_marker)
lift_form1= ufl.inner(- sigma_f * n_f, ufl.as_vector([0.0, 1.0])) * ds_fluid(interface_marker)
F_D1 = dolfinx.fem.assemble_scalar(dolfinx.fem.form(drag_form1))
F_L1 = dolfinx.fem.assemble_scalar(dolfinx.fem.form(lift_form1))
e_x = ufl.as_vector([1.0, 0.0])
e_y = ufl.as_vector([0.0, 1.0])
total_force_f = fem.assemble_scalar(fem.form(
ufl.inner(traction_f_expr_step, n_f) * ds_fluid(interface_marker)
total_force_s = fem.assemble_scalar(fem.form(
ufl.inner(traction_s_expr_step, n_s) * ds_solid(interface_marker)
interface_force.append([float(t), F_D, F_L, F_D1, F_L1])
print(f"FD = {F_D:.6e} | FL = {F_L:.6e} |FD1 = {F_D1:.6e} | FL1 = {F_L1:.6e} ")
flag_force.append([float(t), total_force_f_x, total_force_f_y, total_force_s_x, total_force_s_y])
print(f"total_force_f = {total_force_f:.6e} | total_force_s = {total_force_s:.6e} ")
print(f"Interface force (fluid) Fx={total_force_f_x:.4f} Fy={total_force_f_y:.4f}")
print(f"Interface force (solid) Fx={total_force_s_x:.4f} Fy={total_force_s_y:.4f}")
mag_inertia = solid_mesh.comm.allreduce(dolfinx.fem.assemble_scalar(inertia_mag_form), op=MPI.SUM)
mag_external = solid_mesh.comm.allreduce(dolfinx.fem.assemble_scalar(external_mag_form), op=MPI.SUM)
if mag_external > 1e-12:
inertia_ratio = mag_inertia / mag_external
inertia_ratio = 0.0
print(f"intertia_ratio = {inertia_ratio}")
step += 1
t += float(dt.value)
print(step, t)
history_array = np.array(solid_tip_history)
inertia_ratio_history.append([float(t), mag_inertia, mag_external, inertia_ratio])
np.savetxt(folder / "solid_tip_history.txt",
history_array,
header="time ux uy",
comments='',
fmt='%.8f')
np.savetxt(folder / "interface_history.txt",
interface_force,
header="time F_D F_L F_D1 F_L1",
comments='',
fmt='%.8f')
np.savetxt(folder / "flagforce_history.txt",
flag_force,
header="time total_force_f_x total_force_f_y total_force_s_x total_force_s_y",
comments='',
fmt='%.8f')
np.savetxt(folder / "inertia_ratio_history.txt",
np.array(inertia_ratio_history),
header="time mag_inertia mag_external ratio",
comments='',
fmt='%.8f')
#--------------------Output--------------------------
if step % 5 == 0 or step == 1:
u_vis.interpolate(u_h.collapse())
p_vis.interpolate(p_h.collapse())
d_vis.interpolate(d)
d_solid_vis.interpolate(d_solid)
#T_fluid_vis.interpolate(traction_f_smooth)
#T_solid_vis.interpolate(traction_s)
vtx_u.write(t)
vtx_p.write(t)
vtx_solid.write(t)
vtx_combined.write(t)
vtx_T_f.write(t)
vtx_T_s.write(t)
second section
Hi, would you mind give me some advice about force transfer method of my partitioned solver.
J_s = ufl.det(F_s)
Thanks a lot! and this is the full code. FSI/FSI_DGCG__benchmarkFSI2.py at main · linjiayu777/FSI · GitHub
Two things that came to my mind:
- Why DG for fluid and CG for solid? In monolithic formulation, I know people use CG for fluid and CG/DG for solid, but I never heard of your combination. Is there mathematical foundation behind such a choice?
- Are you aware of the “added-mass effect”? It is a known numerical instability that appears with the partiontioned FSI, but not with the monolithic approach. Perhpas, it may be worth reading this: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.ices.utexas.edu/media/reports/2004/0402.pdf
I’ve never used a partitioned scheme, so I’ve never implemented a force transfer unfortunately. However, it seems strange to me to represent the forces as continuous galerkin functions. They are based on grad(u) and should therefore be discontinuous in my mind.
Another idea might be to solve the stress problem using a direct solver like MUMPS. And can’t you just interpolate sigma_f_exact directly instead of first solving a linear problem?
These things might just be necessary details of partitioned FSI that I don’t know about though.
Thanks for the reply. From my viewpoint, DG could be more suitable for convection-dominated issues and problems where discontinuities emerge. Yes, I note the “added-mass effect” problem, so I used the Aitken algorithm here. I think the main issue is the force transfer. I’ll try using preCICE for that in the next stage, where a more conservative transfer algorithm, such as the mortar method, will be adopted.
Appreciate your suggestion. I’ll recheck that. Conservative transfer is the key point, especially for large deformation. I think I could try preCICE.
