Iterative solver diverging
Hi, I am trying to build a displacement-controlled version of this tutorial Elasto-plastic analysis of a 2D von Mises material in which the author has used external force.
I tried to follow these posts Plasticity in fenics and Custom Newton Solver problem with Dirichlet conditions where @bleyerj states that to make a displacement controlled model, we need to keep 2 things in mind -
  1. Add a DirichletBC with imposed value equal to the displacement increment over the time step and not the total displacement.
  2. Only the first iteration should have a non-zero DirichletBC all other iterations must be computed with zero DirichletBC, otherwise you will accumulate imposed displacements over all iterations and will not converge.
Following both advices, I modified the loop like this -
Nitermax, tol = 200, 1e-8  # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr+1)[1:]**0.5
results = np.zeros((Nincr+1, 2))
for (i, t) in enumerate(load_steps):
    loading.t = t
    A, Res = assemble_system(a, L, bc_u)
    for bc in bc_u:
        bc.apply(du.vector())
        bc.homogenize()
    nRes0 = Res.norm("l2")
    nRes = nRes0
    print("Increment:", str(i+1))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "mumps")
        Du.assign(Du+du)
        deps = eps(Du)
        sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
        local_project(sig_, W, sig)
        local_project(n_elas_, W, n_elas)
        local_project(beta_, W0, beta)
        nRes = Res.norm("l2")
        print("    Residual:", nRes)
        niter += 1
    u.assign(u+Du)
    p.assign(p+local_project(dp_, W0))
    sig_old.assign(sig)
    p_avg.assign(project(p, P0))
    results[i+1, :] = (u(0.5, 1.)[1], t)
But the solver diverges, I think I’ve not understood both the points due to which there is divergence. Therefore, I request to kindly give me suggestions on the same.
Thanks.
PS: Here is my MWE-
parameters["form_compiler"]["representation"] = 'quadrature'
parameters["form_compiler"]["representation"] = "tsfc"
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
# elastic parameters
E = Constant(70e3 )
nu = 0.3
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
Et = E/100.  # tangent modulus
H = E*Et/(E-Et)  # hardening modulus
sig0 = Constant(250.)
domain= Rectangle(Point(0., 0.), Point(1., 1.))
mesh = generate_mesh(domain, 20)
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
P0 = FunctionSpace(mesh, "DG", 0)
p_avg = Function(P0, name="Plastic strain")
# Boundary conditions
class top(SubDomain):
        return on_boundary and near(x[1], 1., 1e-8)
class bot(SubDomain):
        return on_boundary and near(x[1], 0., 1e-8)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
top().mark(boundaries, 1)
bot().mark(boundaries, 2)
loading = Expression("t", t = 0.0, degree=1)
bc_top = DirichletBC(V.sub(1), loading, boundaries, 1)
bc_bottom = DirichletBC(V, Constant((0., 0.)), boundaries, 2)
bc_u = [bc_bottom, bc_top]
def eps(v):
    e = sym(grad(v))
    return as_tensor([[e[0, 0], e[0, 1], 0],
                      [e[0, 1], e[1, 1], 0],
                      [0, 0, 0]])
def sigma(eps_el):
    return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
    return as_tensor([[X[0], X[3], 0],
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
    sig_n = as_3D_tensor(old_sig)
    sig_elas = sig_n + sigma(deps)
    s = dev(sig_elas)
    sig_eq = sqrt(3/2.*inner(s, s))
    f_elas = sig_eq - sig0 - H*old_p
    dp = ppos(f_elas)/(3*mu+H)
    n_elas = s/sig_eq*ppos(f_elas)/f_elas
    beta = 3*mu*dp/sig_eq
    new_sig = sig_elas-beta*s
    return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
           as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
           beta, dp
def sigma_tang(e):
    N_elas = as_3D_tensor(n_elas)
    return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a = inner(eps(v), sigma_tang(eps(u_)))*dxm
L = -inner(eps(u_), as_3D_tensor(sig))*dxm
    dv = TrialFunction(V)
    v_ = TestFunction(V)
    a_proj = inner(dv, v_)*dxm
    b_proj = inner(v, v_)*dxm
    solver.factorize()
    if u is None:
        solver.solve_local_rhs(u)
        return u
        return
Nincr = 20
    loading.t = t
    for bc in bc_u:
        bc.homogenize()
    nRes = nRes0
    niter = 0
        Du.assign(Du+du)
        deps = eps(Du)
        niter += 1
    u.assign(u+Du)
    sig_old.assign(sig)
Hi, so I tried to use this logic -
at first iteration -> nonzero DBC
second iteration onwards -> zero DBC -> homogenize them
In the code, I made the following changes but still it diverges -
Nincr = 20
    loading.t = t
    nRes = nRes0
    niter = 0
        Du.assign(Du+du)
        deps = eps(Du)
        if niter >= 1:
            for bc in bc_u:
                bc.apply(Du.vector())
                bc.homogenize()
        niter += 1
    u.assign(u+Du)
    sig_old.assign(sig)
I don’t know what mistake I’m making, any pointers about the same would be highly appreciable.
Thanks.
Okay, so I tried to make a simpler version of the problem to track down the issue and changed my boundary conditions to -
bc_top = DirichletBC(V.sub(1), Constant(1.), boundaries, 1)
Modified the loop to -
Nitermax, tol = 200, 1e-6 # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = [1., 2., 3.]
for (i,t) in enumerate(load_steps):
    err0 = Res.norm("l2")
    err1 = err0
    print(err1/ err0)
    print("Increment:", str(i + 1))
    ## 1st iteration with nonzero DirichletBC conditions
    Du.interpolate(Constant((0, 0.1)))
    niter = 0
    while err1/err0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "umfpack")
        Du.assign(Du+du)
        deps = eps(Du)
        err1 = Res.norm("l2")
        print(err1/err0)
        ## 2nd iteration onwards => zero DirichletBC conditions
        for bc in bc_u:
            bc.homogenize()
        niter += 1
    u.assign(u+Du)
    sig_old.assign(sig)
Now the issue is I am getting NaN from 3rd iteration, I also tried looking up Default absolute tolerance and relative tolerance and specially what to do in nan values case, it says to change the inital guess to a non-zero value but I’m not quite sure how to do that, therefore I’m stuck.
Any help would be highly appreciable.
Thanks.
