Not converging when applying dirichlet BC instead of Force
Hello everyone,
in the following MWE I just want to solve the displacement of a rectangle and is based on the following example: Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation
The code works fine when I impose a force on the top edge. However the same code does not converge when I try to define a displacement controlling dirichlet BC (here called “bctopy”) instead of the force.
MWE:
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("ignore", QuadratureRepresentationDeprecationWarning)
domain = Rectangle(Point(0,0), Point(1,1))
nxy = 40
mesh = generate_mesh(domain, nxy)
# elastic parameters
kappa = Constant(71245)
mu    = Constant(27120)
lambda_= Constant(kappa - 2./3.*mu)
V = VectorFunctionSpace(mesh, "CG", 2)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=2, quad_scheme='default')
W = FunctionSpace(mesh, We)
sig = Function(W)
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
du_ = TrialFunction(V)
# Boundary conditions for mesh D2
class bottom(SubDomain):
        tol = 1e-13
        return abs(x[1]) < tol and on_boundary
class top(SubDomain):
        tol = 1e-13
        return abs(x[1]-1) < tol and on_boundary
Top = top()
Bottom = bottom()
boundaries.set_all(0)
Bottom.mark(boundaries,1)
Top.mark(boundaries,2)
loading  = Expression("t", t = 0.0, degree=1)
bcbot = DirichletBC(V, Constant((0.0,0.0)), boundaries, 1)
bctopx = DirichletBC(V.sub(0), Constant(0.0), boundaries, 2)
bctopy = DirichletBC(V.sub(1), loading, boundaries, 2)
bc_u  = [bcbot, bctopx, bctopy]
def F_ext(v):
    return loading*dot(n, v)*ds(2)
# Constitutive relation update
def eps(v):
    return sym(grad(v))
def sigma(eps_el):
    return lambda_*tr(eps_el)*Identity(2) + 2*mu*eps_el
sig = sigma(eps(u))
# Global problem and Newton-Raphson procedure
metadata = {"quadrature_degree": 2, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma(eps(du_)))*dxm
res = -inner(eps(v), sig)*dxm# + F_ext(v)
file_results = XDMFFile("plasticity_results.xdmf")
Nitermax, tol = 50, 1e-8  # parameters of the Newton-Raphson procedure
Uincr = 9E-2
Nincr = 10
j = 0
t = 0
while j < Nincr:
    j += 1
    t += Uincr
    loading.t = t
    A, Res = assemble_system(a_Newton, res, bc_u)
    nRes0 = Res.norm("l2")
    nRes = nRes0
    print("Increment:", str(j))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "mumps")
        u.assign(u+du)
        nRes = Res.norm("l2")
        print("    Residual:", nRes)
        niter += 1
    file_results.write(u, t)
Dolfin version (installed via Docker): 2019.1.0
Ubunutu version: 20.04
Does anyone have an idea what the mistake is?
Your help is much appreciated.
Best,
Dejan
Dear future readers,
the solution for me was to switch to Fenicsx and to use the following custom Newton Solver
https://jsdokken.com/dolfinx-tutorial/chapter4/newton-solver.html
