@Henrik_Nicolay_Finsb added the capability to get 1D mesh tags out of a 3D mesh in Extract edge tags and vertex tags from gmsh and return a NamedTuple by finsberg · Pull Request #3547 · FEniCS/dolfinx · GitHub
This commit is not in any release: if you build dolfinx from source and can update to the main branch, please do. If you can’t update or do not build dolfinx from source, a quick-and-dirty workaround that I have verified works on dolfinx 0.9.0 is to:
- copy the code from dolfinx/python/dolfinx/io/gmshio.py at 2f4a497e7a3ea03f4ed638eccdafbc31ac1336fe · finsberg/dolfinx · GitHub
- save it in a file, e.g. called
updated_gmshio.py
- remove
AdjacencyList
from lines 22 and and 455
#from dolfinx.io import gmshio # if you can update to dolfinx main
import updated_gmshio as gmshio # if you can't update to dolfinx main
import math
gmsh.model.add('DFG 3D')
#define dimension
length_member = 500
width_member = 100
depth_member = 100
diameter_longitudinal_rebar = 8
cover_spacing_longitudinal_rebar = 20
embedded_length_longitudinal_rebar = 500
diameter_transverse_rebar = 8
cover_spacing_transverse_rebar = 80
spacing_transverse_rebar = 200
additional_diameter_of_unbonded_region = 1
clear_spacing_between_longitudinal_and_transverse_rebar = 5
radius_of_transverse_rebar = 3 * diameter_transverse_rebar
#####tag list#####
#volume 1X0
tag_volume_longitudinal_rebar = 110
tag_volume_transverse_rebar = 120
tag_volume_concrete = 130
tag_volume_unbonded_region_1 = 140
tag_volume_unbonded_region_2 = 141
#Surface 1X00
tag_surface_longitudinal_rebar = 1100
tag_surface_transverse_rebar = 1200
#Line 1X000
tag_line_transverse_rebar = 12000
#Point 1X0000
tag_point_count_transverse_rebar = 120000
#volume 2X0
marker_volume_longitudinal_rebar = 210
marker_volume_transverse_rebar = 220
marker_volume_concrete = 230
#Surface 2X00
marker_surface_longitudinal_rebar = 2100
marker_surface_transverse_rebar = 2200
##### model concrete #####
domain_concrete = gmsh.model.occ.addBox(0, 0, 0, length_member, width_member, depth_member, tag=tag_volume_concrete)
##### generate concrete #####
gmsh.model.occ.synchronize()
def Calculate_transverse_rebar_positions(length_member, spacing_transverse_rebar):
if length_member % spacing_transverse_rebar == 0:
The_number_of_transverse_rebar = math.floor(length_member / spacing_transverse_rebar) - 1
remaining_length = length_member - The_number_of_transverse_rebar * spacing_transverse_rebar
cover_distance = remaining_length / 2
positions = [cover_distance + i * spacing_transverse_rebar for i in range(The_number_of_transverse_rebar + 1)]
return positions
position_transverse_rebar = Calculate_transverse_rebar_positions(length_member, spacing_transverse_rebar)
##### define points for straight line #####
point_straight_line_transverse_rebar=[[(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar), (cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar)],
[width_member-(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar), (cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar)],
[width_member-(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar), depth_member-(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar)],
[(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar), depth_member-(cover_spacing_transverse_rebar-diameter_transverse_rebar/2-clear_spacing_between_longitudinal_and_transverse_rebar)]
] # 모따기 아닌부분의 점좌표
##### define start points #####
corner_transverse_rebar = ['Bottom left', 'Bottom right', 'Top right', 'Top left']
list_point_position_individual_transverse_rebar = []
list_point_position_total_transverse_rebar = []
for position in position_transverse_rebar:
for corner_index in range(len(corner_transverse_rebar)):
##### model straight point #####
gmsh.model.occ.addPoint(position, point_straight_line_transverse_rebar[corner_index][0], point_straight_line_transverse_rebar[corner_index][1], tag=tag_point_count_transverse_rebar)
list_point_position_individual_transverse_rebar.append(tag_point_count_transverse_rebar)
tag_point_count_transverse_rebar = tag_point_count_transverse_rebar + 1
list_point_position_total_transverse_rebar.append(list_point_position_individual_transverse_rebar)
list_transverse_rebar = []
list_loop_transverse_rebar = []
for position_index in range(len(position_transverse_rebar)):
##### model straight line #####
line1 = gmsh.model.occ.addLine(list_point_position_total_transverse_rebar[position_index][0], list_point_position_total_transverse_rebar[position_index][1], tag=tag_line_transverse_rebar)
transverse_rebar = (1, line1)
list_transverse_rebar.append(transverse_rebar)
tag_line_transverse_rebar = tag_line_transverse_rebar + 1
line2 = gmsh.model.occ.addLine(list_point_position_total_transverse_rebar[position_index][1], list_point_position_total_transverse_rebar[position_index][2], tag=tag_line_transverse_rebar)
transverse_rebar = (1, line2)
line3 = gmsh.model.occ.addLine(list_point_position_total_transverse_rebar[position_index][2], list_point_position_total_transverse_rebar[position_index][3], tag=tag_line_transverse_rebar)
transverse_rebar = (1, line3)
line4 = gmsh.model.occ.addLine(list_point_position_total_transverse_rebar[position_index][3], list_point_position_total_transverse_rebar[position_index][0], tag=tag_line_transverse_rebar)
transverse_rebar = (1, line4)
##### embed straight line #####
for transverse_rebar in list_transverse_rebar:
gmsh.model.mesh.embed(1, [transverse_rebar[1]], 3, tag_volume_concrete)
gmsh.model.occ.removeAllDuplicates()
volume_3D = gmsh.model.getEntities(dim=3)
##### allocate marker and name #####
gmsh.model.addPhysicalGroup(3, [tag_volume_concrete], marker_volume_concrete)
gmsh.model.setPhysicalName(3, marker_volume_concrete, 'volume_concrete')
gmsh.model.addPhysicalGroup(2, [1], 1)
dimension_list_transverse_rebar = [i[0] for i in list_transverse_rebar]
tag_list_transverse_rebar = [i[1] for i in list_transverse_rebar]
gmsh.model.addPhysicalGroup(1, tag_list_transverse_rebar, marker_volume_transverse_rebar)
gmsh.model.setPhysicalName(1, marker_volume_transverse_rebar, 'line_transverse_rebar')
resolution = min(diameter_longitudinal_rebar, diameter_transverse_rebar) / 2
gmsh.option.setNumber('Mesh.MeshSizeFromCurvature', 6)
gmsh.option.setNumber('Mesh.MeshSizeMin', 1 * resolution)
gmsh.option.setNumber('Mesh.MeshSizeMax', 10 * resolution)
gmsh.option.setNumber("Mesh.MshFileVersion", 4.1) # MSH 파일 버전 (4.1, 2.2 등)
gmsh.option.setNumber("Mesh.Binary", 0) # ASCII 형식 (Binary 사용 시 1)
#Generate mesh 3 : Cell, 2 : Facet, 1 : Edge
gmsh.model.mesh.generate(3)
mesh, *tags, names = gmshio.model_to_mesh(
gmsh.model, comm=MPI.COMM_WORLD, rank=0, gdim=3)
for i in range(len(tags)):
print(3 - i, tags[i])
Note that I had to add a useless (for you) facet marker with
because of [BUG]: #3547 does not handle missing tags for intermediate dimensions · Issue #3594 · FEniCS/dolfinx · GitHub . Subscribe to the discussion there for more updates, or even better contribute there with a minimal example or a test. Nonetheless, the two workarounds reported here should be enough for you to correctly get your cell and line tags in the meantime.
