KSP solver issue
I am having trouble running my heat diffusion simulation. PETSc error code 73 keeps appearing when running the simulation, saying that “[0] Object is in wrong state” and “[0] Not for unassembled matrix”, referring to the line which says:
solver.solve(b_vec, T_new)
Can someone please help? The full script code is given below.
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from dolfinx.fem import (Function, FunctionSpace, dirichletbc, locate_dofs_geometrical, Constant, form)
from dolfinx import mesh, fem
import pyvista as pv
def visualiseMesh(msh: mesh):
    Provides a 2D rendering file (.xdmf) to show the mesh structure.
    print("Plotting mesh in 3D using PyVista...")
    # Create XDMF file to save the mesh
    with XDMFFile(msh.comm, "mesh.xdmf", "w") as xdmf:
        xdmf.write_mesh(msh)
    # Extract the mesh topology (cell connectivity) and geometry (vertex coordinates)
    num_cells = msh.topology.index_map(msh.topology.dim).size_local
    cell_connectivity = msh.topology.connectivity(2, 0).array
    # Create the VTK-style connectivity array where the first value for each cell is the number of vertices
    vtk_cells = np.hstack([[3, *cell_connectivity[i:i+3]] for i in range(0, len(cell_connectivity), 3)])
    # Set the VTK cell types (5 corresponds to triangles)
    cell_types = np.full(num_cells, 5, dtype=np.uint8)
    # Get the vertex coordinates (geometry)
    points = msh.geometry.x
    # Convert the mesh into PyVista's UnstructuredGrid format
    grid = pv.UnstructuredGrid(vtk_cells, cell_types, points)
    # Plot the mesh using PyVista
    plotter = pv.Plotter()
    plotter.show()
def findHeatSolution(length, width, rho_param, c_p_param, k_param ):
    print("""
        Starting simulation
    print("Generating mesh...\n")
    # Creating the mesh (assuming a rectangular substrate for now)
    msh = mesh.create_rectangle(
        comm=MPI.COMM_WORLD,
        points=((0.0,0.0), (length, width)),
        n = (32, 16),
        cell_type=mesh.CellType.triangle,
    #visualiseMesh(msh)
    # Defining the function space V
    V = fem.FunctionSpace(msh, ("Lagrange", 1))
    # Defining trial and test functions u and v
    T_n = Function(V) # Temperature at previous time step
    u = ufl.TrialFunction(V) # u is the temperature at the current timestep (what we are trying to solve)
    n = ufl.FacetNormal(msh)
    delta_t = 0.1
    # Defining the localised heat source power dissipation (uW) and coordinates
    # STILL NEED TO CHANGE THESE VALUES TO BE READ IN, RATHER THAN HARDCODED
    # print("Defining the localised heat source power dissipation and coordinates... \n")
    P1, P2, P3 = 420, 250, 500
    x1, y1 = -50.0, 0.0
    x2, y2 = 0.0, 0.0
    x3, y3 = 50.0, 0.0
    def localized_heat_source(x, power1=P1, power2=P2, power3=P3, radius=0.05):
        return (
        power1 * np.exp(-((x[0] - x1) ** 2 + (x[1] - y1) ** 2) / (2 * radius ** 2))
        + power2 * np.exp(-((x[0] - x2) ** 2 + (x[1] - y2) ** 2) / (2 * radius ** 2))
        + power3 * np.exp(-((x[0] - x3) ** 2 + (x[1] - y3) ** 2) / (2 * radius ** 2))
   # Define the heat source as a Function in the FunctionSpace
    Q = Function(V)
    Q.interpolate(localized_heat_source)
    # Define the bilinear form (should contain unknowns u and v)
    a = (rho_param * c_p_param / delta_t) * u * v * ufl.dx + k_param * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - k_param * ufl.dot(ufl.grad(u), n) * v * ufl.ds
    # Define the linear form (including contributions from known T_n and Q)
    L = (rho_param * c_p_param / delta_t) * T_n * v * ufl.dx + Q * v * ufl.dx
    # Apply boundary conditions (e.g., Dirichlet with T=50 on all boundaries)
    boundary_conditions = [dirichletbc(PETSc.ScalarType(50.0), locate_dofs_geometrical(V, lambda x: np.full(x.shape[1], True)), V)]
    # Time-stepping parameters
    num_steps = 50  # Number of time steps
    time = 0.0
    with XDMFFile(MPI.COMM_WORLD, "heat_solution.xdmf", "w") as file:
        file.write_mesh(msh)
        file.write_function(T_n, time)
        # Assemble the matrix A
        A = fem.petsc.create_matrix(form(a))
        A_mat = fem.petsc.assemble_matrix(A, form(a), bcs=boundary_conditions)
        # Create a solver
        solver = PETSc.KSP().create(msh.comm)
        solver.setOperators(A_mat)  # Use the PETSc matrix
        solver.setType(PETSc.KSP.Type.CG)
        solver.setFromOptions()  # This is necessary to finalize the setup of the solver
        for step in range(num_steps):
            time += delta_t
            print(f"Time step {step + 1}/{num_steps}, Time: {time:.2f}")
            # Assemble the right-hand side vector (b)
            b = fem.petsc.create_vector(form(L))
            b_vec = fem.petsc.assemble_vector(b, form(L))
            # Apply boundary conditions to the vector b_vec
            fem.apply_lifting(b_vec, [form(a)], bcs=[boundary_conditions])
            b_vec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
            fem.set_bc(b_vec, boundary_conditions)
            # Create the solution vector
            T_new = Function(V).vector
            #print("\nSize of b_vec:", b_vec.size)
            #print("Size of T_new.vector:", T_new.vector.size)
            T_new.x.scatter_forward()
            # Update T_n for the next time step
            T_n.x.array[:] = T_new.x.array[:]
            # Save the current solution
            file.write_function(T_new, time)
    print("""
        Simulation complete
Add A_mat.assemble() (or A.assemble() as it is the same) after this call.
